dietmar Posted November 27, 2006 Posted November 27, 2006 Hi,I’m working on 24 channel LCD displays for my tascam US2400 controller. I’ve build 3 CoreModules with two LCDs for each. I’m using Nuendo and for the first LCD test I’ve routed the Midi Out of the three Mackie Controls from the tascam controller to the CoreModules and this worked perfect but I had no response to the tascam controller anymore. So I’ve installed Midi OX and Midi yoke and routed the midi out from the three mackie controls in nuendo to midi OX and split the midi out to the tascam controller and to the core modules.The US2400 controller and the display on Mackie control port1 are working fine but the CoreModules on Mackie control 2 and 3 are not working any more and I’ve no idea why. It seems to be a problem with the midi OX but I’ve the same routing settings for all three midi ports in Midi OX. I also get strange signs on the display of Mackie Port one when I start nuendo but when I change the pan value I get the right display. Has anyone an idea? I'm not using the midi out for the CoreModules because I'm just usingthe displays at the core module and no buttons.Regards, Dietmar
TK. Posted November 29, 2006 Posted November 29, 2006 Hi Dietmar,I'm not completely sure, but it could be that you forgot to change the emulation mode to "Mackie Control XT" for the second and third core (LC_EMULATION_ID should be set to 0x15) - if Nuendo can only handle one master unit, this would be the solutionIf this isn't the solution, I have no other idea...Best Regards, Thorsten.
dietmar Posted November 29, 2006 Author Posted November 29, 2006 I've already tried it, it doesn't work. But I found out that when I route with midi OX just the displays,start nuendo, and rote the mixer after the startup, than the displayswork.But this solution makes the startup of Nuendo very complicate.
dietmar Posted December 22, 2006 Author Posted December 22, 2006 Does anyone know a software like midi ox who can split a virtual midiport( midi yoke) to two midi ports?Because midi ox does not work correct with the core module.
doc Posted December 22, 2006 Posted December 22, 2006 Just a quick thought on your problem:If I'm right, you don't use the connector J5 of the cores. Right?Please ensure in that case, that the pins A0 through A7 of Connector J5 from the core are grounded.This just because you wrote something about strange signals. It may be a try to ground the analog signals of the cores (J5. Pin A0 to A7)greetsDOC
dietmar Posted December 22, 2006 Author Posted December 22, 2006 Yes,you are right.I will try it.Thanks
RichT Posted December 29, 2006 Posted December 29, 2006 Hi Dietmar,I'm very interested to see your results with your build, I myself am looking for a scribble strip / meter bridge solution for our us2400. Would you be willing to share photos of your build and perhaps a plan of how you went about it?Thanks in advance,Rich Tamblyn
dietmar Posted January 4, 2007 Author Posted January 4, 2007 I'will post it in tascamforums.com, but it will take some time becauseI've to fight with many problems by splitting the output signals of with midi ox.Dietmar
Screaming_Rabbit Posted January 5, 2007 Posted January 5, 2007 Why not use an external MIDI-Thru to split the signal?http://www.ucapps.de/midibox/midi_thru.gif- connect the MIDI Out from your host to A3/B3- connect the output of Y3 to A1/B1 and A2/B2- so you'll get 3 "amplified" MIDI Outs at Y1, Y2 and Y4Google for "DIY MIDI Thru"... I once saw some complete DIY shematicsGreets, Roger
dietmar Posted January 12, 2007 Author Posted January 12, 2007 My Tascam Controller has just USB input and no Midi port!
RichT Posted January 22, 2007 Posted January 22, 2007 Hi Dietmar,Did you see over at the Tascam forum that downtownpauly had managed to translate the output of the Native mode of the US2400 thru MidiOX and MidiYOKE to allow you to personalise every function of the unit within Nuendo?Here's the link: http://tascamforums.com/index.php?showtopic=16036&st=0I wonder if this would help your development of the LCD screens?How is it all coming along? Any pics? :)Cheers,Rich
RezMax Posted August 23, 2012 Posted August 23, 2012 (edited) hey, tascam forum has been abandoned, any idea how to find out more about getting scribble strip and meters for the US-2400? This is my custom console I had built to fit the US-2400 as a flush-mount rather than table-top. The space I have to work with is limited but I think the best option is running 3 10" LCD screens and use data sent via MIDI if possible. Please let me know where to go from there if possible. Thanks. RezMax Edited August 23, 2012 by RezMax
