Goblinz Posted August 17, 2007 Report Posted August 17, 2007 I found some info on getting lowcost PCBS produced in China and though that it may be of benefit to people on here... Here's a round-up http://research.techkwondo.com/?p=337, giving details of the ordering process and here's the link to the company http://www.goldphoenixpcb.biz/quote2.php Obviously this isn't going to be as cheap as producing the boards yourself. They do a 1000Cmsq board, and you can send in a PCB design, and then they will replicate it and lay it out on the board as many times as possible. They can do more than one design on the board for an extra fee. It looks like they even cut them all out for you too. They do 4 layer boards too........please could somebody let me know how you can get 4 layers on to a board... do you have to sandwich layers? Anyway, a board of 1000cmSQ, with the same design replicated, with a single side silk screen will cost just short of $110 which seems really good, especially if a few people got together to get some boards done. there's free shipping to the states or very reasonable shipping elsewhere. Hope this is of help. G
bugfight Posted August 17, 2007 Report Posted August 17, 2007 this is indeed a good price.a few questions:anybody used this company already? wilba? smash?this is the company sparkfun uses...what is "maximum 15% fail rate"?1 in 6 boards will have a bad trace?
Wilba Posted August 17, 2007 Report Posted August 17, 2007 I used Gold Phoenix for the MB-6582 prototype and current run of PCBs. So does SparkFun (and BatchPCB which you might want to try for small one-offs).Their prototyping service is good value, but pay attention to the extra fee for "multi-project" i.e. if you are combining more than one PCB design on the panel. They do route them all out for you. If you were just filling a panel with one design then you don't pay the "multi-project" cost. Obviously this isn't going to be as cheap as producing the boards yourself.Please tell me how to produce 2-layer plated through holes with solder mask yourself. Then tell me how to do it cheaper than $110. ;D
Goblinz Posted August 18, 2007 Author Report Posted August 18, 2007 Well.. maybe not professionally finished0 boards of that quality. How does this layer ing thing work, it's not a term we used in GCSE electronics. I thought double layered was the same as a double sided board... How can you get 4 layers on a board? G
TheAncientOne Posted August 18, 2007 Report Posted August 18, 2007 How does this layer ing thing work, it's not a term we used in GCSE electronics. I thought double layered was the same as a double sided board... How can you get 4 layers on a board?Thye make several thin PCB's, laminate them together and then drill, and do the via's, (the inter-board connections), and through hole plating. For more exotic boards you cahave 'buried' via's where the join doesn't go right through.Usually only used for very high density boards, especially when using chips in BGA (ball grid array) packages. Not home stuff - BGA's need soldering in a reflow oven (you can't get and iron under a chip).This is why some of the higher end DSP and FPGA's aren't easy to use for one-off's.If you want to get really mad, you could look at multi layer flexible....Designing for these boards is a bit of a black art, often involving Radio frequency work, on high speed motherboards - face it, 1066MHz Front Side Bus is a higher frequency than early Radar. This is why you see those wiggly track on modern motherboards - to keep them all the same length, so that the signals arrive together.
Goblinz Posted August 18, 2007 Author Report Posted August 18, 2007 Great, thanks for the explanation, I thought it would be something like that, but could not get me head around the complexity of even thinking about designing an 8 layered board. I don't think I'll ever need to go beyone a dual sided board. G
Therezin Posted August 21, 2007 Report Posted August 21, 2007 I've not used them (gold phoenix) myself, but the guy in my local electronics shop can't recommend them highly enough.
Davo Posted August 21, 2007 Report Posted August 21, 2007 Great, thanks for the explanation, I thought it would be something like that, but could not get me head around the complexity of even thinking about designing an 8 layered board. I don't think I'll ever need to go beyone a dual sided board.Another thing about layers -- The reason for four layers is almost always to have power and ground appear on their own layers. Then wherever they're needed, a via is poked through. This makes routing much easier with more complex boards. Those two extra layers are entirely copper except where vias go through that aren't supposed to be connected to it. Layers more than that are usually used to cut down on vias when things get even denser (like modern computer motherboards).
TheAncientOne Posted August 21, 2007 Report Posted August 21, 2007 The power layers with all that copper are also the reason it's nearly impossible to replace bulging electrolytics on some motherboards - you just can't get enough heat in to desolder the parts.(I binned an AMD motherboard yesterday for that reason)
