jeroddumas Posted June 1, 2003 Author Posted June 1, 2003 Yeah If I could get my hands on the protocol for the CM motormix then I would be in business. The problem is none of these companys want to share. :'( :'( :'( But that is not unexpected.
ilmenator Posted June 1, 2003 Posted June 1, 2003 If you have a CM Motormix at hand and have two MIDI monitors (like a PC with two free MIDI ports and two instances of MidiOx software, or two PIC-MIDI monitors from Thorsten with large enough displays) then you could monitor the MIDI signals going to and fro' the controller box. It should be fairly easy to decipher the protocol then. It's just MIDI, anyhow...Regards, ilmenator
jeroddumas Posted June 2, 2003 Author Posted June 2, 2003 Yeah I got to get my hands on a Motor mix or HUI. That's the tricky part. :-[ :-[ :-[
jeroddumas Posted June 2, 2003 Author Posted June 2, 2003 Well I think I have figured some of the Protocol out for the HUI surface. It seems as though motorfader positions are sent using 2 corresponding CC. Example: for fader one Midi Ox shows.b0 00 positionb0 20 positionIs there anyway to program this into MIOS. If so Thorston could you please post an example. I haven't pounded together my MB yet, but I would really like to know if this is possible. Also is there anyway to make this work with Vmidibox. :-/ :-/?? The final thing that I have noticed is that HUI interface sends a note on message constantly for the computer to respond to. That should be no problem for the MIOS code correct?? I'm a programming dummy, but a fast learner, so with a few examples i think i could figure this thing out. The buttons also send two events. Haven't got that far yet though as I am cheating this thing without the control surface.
TK. Posted June 2, 2003 Posted June 2, 2003 Hi,I would like to integrate a HUI option into the MIDIbox LC, but before I begin with the implementation please give me a list of all controllers - I don't own pro tools.If you would like to experiement, you could change the USER_AIN_NotifyChange function (-> lc_mf.inc) in the following way:after "call MIOS_MIDI_BeginStream" write: ;; for MIDIbox Link: notify begin of stream call MIOS_MIDI_BeginStream ;; finally send value: B0 00+<fader> LSB 20+<fader> MSB movlw 0xb0 call MIOS_MIDI_TxBufferPut movlw 0x00 addwf LC_FADER_NUMBER, W call MIOS_MIDI_TxBufferPut movf LC_FADER_POS_L, W call MIOS_MIDI_TxBufferPut movlw 0x20 addwf LC_FADER_NUMBER, W call MIOS_MIDI_TxBufferPut movf LC_FADER_POS_H, W call MIOS_MIDI_TxBufferPut ;; for MIDIbox Link: notify end of stream call MIOS_MIDI_EndStream ;; thats all return Best Regards, Thorsten.P.S.: the second 0xb0 has not to be sent by the MIDIbox, it will be inserted automatically by the MIDI receiver - keyword: "running mode"
jeroddumas Posted June 2, 2003 Author Posted June 2, 2003 Actually I'm trying to get all of the controllers together to send to you. I am gonna try to get a HUI unit from the local music store for "testing" ;D ;DThis way I can run through midi-ox and get all of the controllers for all of the functions. I can get the controllers from pro tools and send them to you, but this will not cover shifting banks and so forth. Maybe there is someone else in the forum who can give a hand with this. I will try and get the contrills that i can get to you by the end of this week. Thanks for the help Thorston. This is one great site. So i guess there is no way to test this with Vmidibox until I pound together my LC ???
