F0 00 00 7E 40 00 01 F7 string every 20 ms *solved*
cimo
Thank You! I've connected 470 Ohms in serial with pull-up resistor making it's resistance smaller. Everything works fine!
Starting upload of mios_v1_9f_pic18f452.hex
Hex file contains code in MIOS range, forcing reboot!
Received Upload Request
Sending block 00000400-000004FF
Received Checksum: 46 - OK
Sending block 00000500-000005FF
Received Checksum: 0F - OK
Sending block 00000600-000006FF
Received Checksum: 48 - OK
Sending block 00000700-000007FF
Received Checksum: 53 - OK
Sending block 00000800-000008FF
Received Checksum: 08 - OK
Sending block 00000900-000009FF
Received Checksum: 59 - OK
Sending block 00000A00-00000AFF
Received Checksum: 60 - OK
Sending block 00000B00-00000BFF
Received Checksum: 7B - OK
Sending block 00000C00-00000CFF
Sending block 00000D00-00000DFF
Received Checksum: 50 - OK
Sending block 00000E00-00000EFF
Received Checksum: 47 - OK
Sending block 00000F00-00000FFF
Received Checksum: 2C - OK
Sending block 00001000-000010FF
Received Checksum: 4E - OK
Sending block 00001100-000011FF
Received Checksum: 28 - OK
Sending block 00001200-000012FF
Received Checksum: 17 - OK
Sending block 00001300-000013FF
Received Checksum: 1B - OK
Sending block 00001400-000014FF
Received Checksum: 0B - OK
Sending block 00001500-000015FF
Received Checksum: 78 - OK
Sending block 00001600-000016FF
Sending block 00001700-000017FF
Received Checksum: 06 - OK
Sending block 00001800-000018FF
Received Checksum: 77 - OK
Sending block 00001900-000019FF
Received Checksum: 79 - OK
Sending block 00001A00-00001AFF
Received Checksum: 64 - OK
Sending block 00001B00-00001BFF
Received Checksum: 72 - OK
Sending block 00001C00-00001CFF
Sending block 00001D00-00001DFF
Received Checksum: 40 - OK
Sending block 00001E00-00001EFF
Received Checksum: 74 - OK
Sending block 00001F00-00001FFF
Received Checksum: 3C - OK
Sending block 00002000-000020FF
Received Checksum: 4F - OK
Sending block 00002100-000021FF
Received Checksum: 5F - OK
Sending block 00002200-000022FF
Sending block 00002300-000023FF
Received Checksum: 7E - OK
Sending block 00002400-000024FF
Received Checksum: 68 - OK
Sending block 00002500-000025FF
Received Checksum: 4A - OK
Sending block 00002600-000026FF
Received Checksum: 3E - OK
Sending block 00002700-000027FF
Received Checksum: 62 - OK
Sending block 00002800-000028FF
Sending block 00002900-000029FF
Sending block 00002A00-00002AFF
Sending block 00002B00-00002BFF
Sending block 00002C00-00002CFF
Received Checksum: 23 - OK
Sending block 00002D00-00002DFF
Sending block 00002E00-00002EFF
Received Checksum: 33 - OK
Sending block 00002F00-00002FFF
Sending block 00003000-000030FF
Received Checksum: 22 - OK
Sending block 00003100-000031FF
Sending block 00003200-000032FF
Sending block 00003300-000033FF
Sending block 00007C00-00007CFF
Received Checksum: 0E - OK
Sending block 00007D00-00007DFF
Sending block 00007E00-00007EFF
Sending block 00007F00-00007FFF
Upload process complete
I haven't found them! I think, it could be moved to "Misc"...
Click link to ucapps page, scroll down, you'll see MIDI Troubleshooting near the bottom...
or
Click the search link, type midi troubleshooting, hit 11 is LINK TO MIDI ISSUES
or
Start at forum front page, scroll down to Testing/Troubleshooting, and you'll see the above link as a sticky thread.
Seems easy enough to find where it is ;) It takes some time of course .... Only took a minute for me to find it three different ways, but of course I'm familiar with the site... that's why it's important to read lots, it's not just the stuff that 'sinks in', it's also the stuff that gives you a 'feeling' of where things go... It's like getting to know someone's kitchen; I wonder where this guy keeps the beer glasses? Probably the same place he got that wine glass from ...
Serial makes it larger, parallel makes it smaller. Anyway, now we know that it was a dodgy midi interface, What kind of midi interface is it? I don't suppose it's USB, and running off a hub? (I'm trying to think about why it may be underpowered aside from just being faulty... maybe it can be fixed)
But it's most usefull for new users ;)
Misstake in translating, sorry ;)
I'm using DIY interface, connected to gameport, but the problem was at CORE module side.
Nah that's what I said - it's most useful for new users to read,read,read, so they get used to where things go, and can easily find it when they search,search,search. A stickied thread in the troubleshooting forum and a link from the front page at ucapps and a solid search hit is about as good as the coverage could possibly be, and the most appropriate place. I'm the first to admit that sometimes it can be hard to find the little bit of info you need, amongst all the info around here - but this is not one of those times. You just didn't search hard enough.
No, the problem is with your midi interface - you just changed the core so that it works with your broken midi interface. Now they're both gimpy ;)
Lenwe, that's the same schematic I've used for my MIDI adapter too. (it's also the most famous, available on the 'net since one decade I think).
But by my side the problem was lying in the master keyboard, unable to communicate to the Core. Link between Core and the adapter was always been OK. Eventually I had to modify the Core so it could also read from the keyboard.
Now I got rid of my DIY interface because of other issues. I'm very happy (even with Linux!) using a Midisport 2x2.
That's based on MMA's schem:
Yeh... ris8 mangled his midi interface to match his mangled keyboard, and had to mangle his core to match the two of them.... Seeing as you don't have a keyboard that forces you to mangle things, you should try and fix the interface (although the real problem may be the joystick port) so you don't have to mangle every core you make.
