105 -
Everything posted by k-rAd MB6401
i have soldered a wire from ground to the side of R59 closest to the usb jack and it works. I finally got around to trying this. Now i can use my mpd18 with a homeade usb -b to usb -b cable. Having 16 pads hooked up to the 16 trigger outs is going to be sweet! Cheers
Confirmed R59.
Wow yogi. Thanks for looking into the disco board for me. I will try this and report back. Yeah i I wanted all the jacks to be accessible. I hate reaching behind stuff to find a jack. Also the seq was intended to sit in front of a modular setup. So it's not static at all. The cv/gate, clock, and triggers are used for different things in every patch. Bending the front panel was a little scary but fun. ;) My my whole life is playing with cables.
Hey yogi. Thanks a lot. I pretty much came to the same conclusion. Add a switch to ground pin 4 of the micro usb on the disco board. I'll most likely leave a jumper in at j17 and just never use the Ac plug when connected to a computer for Sysex updates Thanks for the kind worlds. I need to post some pics of my box all finished. As soon as I had the thing working I sort of stopped documenting. It's just so fun to play with.
This is true. For safety reasons j17 should be open when powering the core externally to prevent frying your computer when you plug in the usb. However, when you need to power a midi controller through the usb and you are using external power for your core, j17 must be closed to give 5v to the midi controller. So now you have to be carefull and never plug the midibox into the computer with the external power supply connected. I still need a solution for a usb otg cable with a usb b jack on the end. ;) If i make this cable will it also work when the midibox is not a host? Or will i have to switch the cable for a normal usb when doing a sysex dump. This would be not cool as i would have to open up my seq every time i wanted to switch from otg to normal usb . I hope this makes sense. Thanks for any insights. Maybe all i need to do is short pins 4 and 5 on the micro end of the cable inside my box.????
Ok. I'm pretty sure my problem is the cable. I installed a USB b jack on my seqv4 case that connects to the micro usb on the discovery board. So now i need a way of converting an OTG cable to usb b on both ends. doh: i made a usb b to usb b cable but that only worked for powering the device and the midibox wont go into host mode. Is there any way that i can add a couple resistors to my diy cable to make it otg? edit: i think i screwed my self by putting a usb b jack on the midibox as i only have access to 4 pins of the micro usb on the discovery. I wanted a more robust connector. i think micro usb is too precarious. damn.
Thanks Latig. I put a jumper at J17 and the MPD18 powers up just fine. I'm just not getting any data transfer now. If i watch the midi monitor i see no incoming data. Any ideas what might be wrong?
If i am using J2 to power my STM32F4 core with a 5v supply and i want to try USB host mode.....i should put a jumper in at J17? Then I will need to be careful not to use an external power source and plug the USB into my computer at the same time? Is this correct? I'm afraid to fry stuff as i love my seq right now. I'm trying to use an akai mpd18 as a USB input to the seq. the mpd18 has usb only. otherwise i will have to buy a kenton USB host to use these devices?
Sounds like I'm ready to jump to a new version! Thanks TK for all your work. I just played my first solo performance with the seq and a modular and I've never felt more at home. Thank you.
A request for seqv4+ please save robotizer settings when a session is saved. Ive been using the skip, octave and length features quite a bit and its a drag to redo the settings when a session is loaded. Thanks
First steps are also not played when midi delay is used.
i'm not sure if i'm the first to find this problem..... Drum triggers from analog out via ch16 will turn off if a delay of "0ms" is selected on all the midi outs in the bpm page. In other words I can mute and unmute my 16 DOUT drum triggers by toggling between 0ms and -1ms on any midi out in the bpm page. Currently running v 4.089 maybe this is already fixed in v 4.091?
i'm not sure if i'm the first to find this problem..... my drum tracks from an analog out ch16 will turn off if no delay is selected on any midi out in the bpm page. i can mute and unmute my analog out drum tracks by toggling between 0 and -1ms on any midi out in the bpm page
Robotizer settings not saved with session?
k-rAd MB6401 replied to k-rAd MB6401's topic in MIDIbox SEQ
ok well. I like Robotizer a lot! and i wish i was able to save the settings for this effect. thanks TK. Hoping it becomes a more permanent feature. -
Why are the Robotizer FX not saved with the session? How can I fix this?
I added a few features to the Humanize function...
k-rAd MB6401 replied to borfo's topic in MIDIbox SEQ
Can't wait to implement this robotizer function! How do i get my hands on this? Very cool guys. -
installed 4.087 then MIOS looses the connection to the core?
Yes! The sysex gets stucked! -
Holy Crap! All of my issues are fixed! Due to installing the GM5 DRIVER! This explains why my mios sessions were so hit and miss. It would work and not work intermittently. The larger the file the less likely it would make the transfer. I was getting corrupted sysex dumps causing all sorts of issues! It corrupted my SD card it won't work now? Now i can succesfully us the mios file browser! It was acting very strange previous to the GM5 install. I missed that part of the documentation. So very sorry to have wasted your time TK. And yes i'm using the stm32f4! So the 230% cpu on idle is ok then? seems to run just fine. Thank you so much for all of your help! Your the best TK! "Windows7 64bit: the SysEx communication gets stucked if a MIOS32 core opens more than one USB port (like MIDIbox SEQ V4). Workarounds ensure that your are using MIOS32 Bootloader V1.010 or higher, and install the GM5 device driver. Alternatively you could install the Korg USB driver as reported but the GM5 driver seems to be better." This was true for my version of XP SP3 as well. The real story is that i ignored this because it said win7 64bit. GM5 device driver is the answer! -
So after wiping everything and getting a new sd card. i've installed 4.086 and the wilba MBSEQ_HW.V4. And i have %235 cpu when stopped! What is going on? Maybe the disconvery board is messed up? -
with a new session i see 236 cpu! when stopped. and 00 cpu when playinng. something is goofy:) At this point i believe i have fried my sd card and this is why the sudden change in everything! I will need to get a new SD card to confirm. After re installing the bootloader. and reinstalling .086. the midibox refused to recognize the sd card. "searching forsd card forever" going to buy a new sd card tomrw. :) -
sorry i cant be as attentive as id like to be today. i'm having a little party at my house cooking mexican. wish i could give you a taco. :) -
i do get notes on the usb midi in -
[14650.487] router [14650.462] MIDI Router Nodes (change with 'set router <node> <in-port> <channel> <out-port> <channel>) [14650.462] Example: set router 1 IN1 all USB1 all [14650.462] 1 SRC:Def. off DST:Def. off [14650.462] 2 SRC:Def. off DST:OUT1 off [14650.462] 3 SRC:Def. off DST:OUT1 off [14650.462] 4 SRC:Def. off DST:OUT1 off [14650.462] 5 SRC:Def. off DST:OUT1 off [14650.462] 6 SRC:Def. off DST:OUT1 off [14650.462] 7 SRC:Def. off DST:OUT1 off [14650.462] 8 SRC:Def. off DST:OUT1 off [14650.462] 9 SRC:Def. off DST:OUT1 off [14650.462] 10 SRC:Def. off DST:OUT1 off [14650.462] 11 SRC:Def. off DST:OUT1 off [14650.462] 12 SRC:Def. off DST:OUT1 off [14650.462] 13 SRC:Def. off DST:OUT1 off [14650.463] 14 SRC:Def. off DST:OUT1 off [14650.463] 15 SRC:Def. off DST:OUT1 off [14650.463] 16 SRC:Def. off DST:OUT1 off [14650.463] [14650.463] MIDI Clock (change with 'set mclk_in <in-port> <on|off>' resp. 'set mclk_out <out-port> <on|off>') [14650.463] USB1 IN:on OUT:on [14650.463] USB2 IN:off OUT:off [14650.463] USB3 IN:off OUT:off [14650.463] USB4 IN:off OUT:off [14650.463] MID1 IN:off OUT:on [14650.463] MID2 IN:off OUT:off [14650.463] MID3 IN:off OUT:off [14650.463] MID4 IN:off OUT:off [14650.463] IIC1 IN:--- OUT:--- [14650.463] IIC2 IN:--- OUT:--- [14650.464] IIC3 IN:--- OUT:--- [14650.464] IIC4 IN:--- OUT:--- [14650.464] OSC1 IN:off OUT:off [14650.464] OSC2 IN:off OUT:off [14650.464] OS IN:off OUTf
