43 -
4
gotkovsky last won the day on November 11 2020
gotkovsky had the most liked content!
Gender
Male
Location
Paris
Recent Profile Visitors
2,180 profile views
gotkovsky's Achievements
9
Made with Midibox: La couleur préférée du carrossier
gotkovsky replied to gotkovsky's topic in Songs & Sounds
Thanks for listening and supporting guys, really appreciate that! -
Hello dear midiboxers, I just wanted to share the new EP that I just released, called "La couleur préférée du carrossier": https://kevingotkovsky.bandcamp.com Four library-digital-bossanova-world tracks entirely sequenced with the one and only SEQ V4+ ;) If you like 70's and 80's type sounds, you might enjoy this! Cheers, please don't hesitate to give me any feedback, KG
Yup I'm aware of that function, but that involves having to do it manually and I was more looking for an automatic solution. I don't know if a lot of users actually use the SONG mode to its full potential with lots of different patterns, time signatures, lengths, etc., but for those who do, it could be useful to be able to restart certain tracks without having to do it manually, because a lot of time the timings are messed-up when switching from a pattern to another (especially if for example G1T1 was 128 steps long in the first pattern and 64 steps in the second pattern). In my case I'd like to be able to just press play on the SEQ in song mode to record multiple synths at the same time without having to do anything on the SEQ, and therefore be able to tweak synth's parameters on the fly. It's also nice to be able to actually save a full arrangement as a SONG on the SEQ.
Hello, Here's a proposal that I've had in mind since I've been using SONG mode in the past months: it could be nice to have a "Restart" action for given song positions, which could look just like the "Mutes" action, but instead of muting/unmuting it would restart or not the chosen tracks, if "disabled" is chosen in the "Restart all tracks on pattern change" in the options menu. I think it would be very useful, because for example when working on just the middle or end of a song, most of the times I have to playback the song from the beginning to be sure about what's gonna play and in what length positions my tracks will be on a further song position. Hope it makes sense and that other users will like it too!
I asked for such a function a few months ago, except I called it ‘broken chord’ instead of ‘strumming’. Still think it would be really nice as a parameter layer!
Nice thread idea Blatboy! My workflow with the SEQ is basically the following: —I have only rack samplers, synths and effects boxes all gathered in two cases next to each other, and I’m controlling and composing everything with the SEQ, which is also racked-up in one of the case. —Apart from rare exceptions, I’m only using my machines mono-timbrally on one midi channel per machine, so that I can easily adjust things on the fly without getting lost. —All my gear is hooked-up to the SEQ on specific ports so that I can take advantage of the great DUPLICATE fx of the SEQ. —One small midi keyboard is connected to IN1 of the SEQ, and I just switch tracks on the SEQ if I want to record something live or step-record. —Some synths midi out are connected to IN2 and 3 of the SEQ if I need to record knobs automation (which I rarely do, and few synths send knob movements through midi out anyway). —I’m using sessions as songs (I actually have a template session which I duplicate when creating a new song). —I don’t use external sequencing capabilities on my synths/samplers except built-in arpeggiators sometimes. —When using the synth live, I’d use either SONG mode and manually switch between the 16 buttons-available song positions (which is nice if you want to make your solo last longer than what was planned), or PHRASE mode and manually switching patterns, muting tracks, etc. —To skip from a song to an other, I just stop the sequencer and change sessions, which is I guess ok considering I’m not making techno and tempos can drastically vary from a song to another. And that’s basically it for me. The great thing with the SEQ is the ability to do almost anything on the fly without stopping the sequencer, which is great for improvisation. The fx are great to improvise variations when using the SEQ live, especially the duplicate and echo functions, which seem to work at almost any time, maybe in combination with force to scale. The ALL function also works great for live action on CC stuff like panning, filtering, etc, which are not necessarily available as knobs on external gear (on old akai rack samplers for example). The BPM ramp function is also super nice for intros too, if you want to start with a slow tempo that gradually builds-up to something faster. There’s really tons of ideas on how to use the SEQ live creatively! One last thing that I like to do live is making solos by having a 16 steps track with all the notes pre-programmed but gated-off, and manually gate them on/off, while another track with a lower track division setting is transposing the notes of the solo track, so it’s not always the same. Then for extra spiciness I can also change the solo track division setting, transposing, or make it play in reverse, etc.
You should probably read the manual once again. In your case, look for the first 3 options in the options page, which allow you to specify a number of steps before a pattern will be switched, on a per-session basis.
Hello, About your last question, have you tried using the "ReSt." (restart) function in Track Mode? As I understood it allows to use a different "Restart all tracks on pattern change" option per track. Cheers, Kevin
Hello, Don't think so, you'd have to use an additionnal transposer track for that. Cheers, Kevin
@slo Thanks for trying too, are you also running the latest firmware, seq_v4_097_pre3?
Hi everyone, As documented in this thread, I've encountered a sync bug regarding pattern switching in SONG and PHRASE mode, when tracks don't share the same time division and/or length. I attached a zip file containing a session with a simple reproduction of the issue (please refer to original thread for more details). Here are also two videos with the actual song that I was working on when I discovered the bug. Pay attention to the TDP when the patterns are switched around 0:16 and 0:32: And the second one with just the Organ lead sound, with the tempo slowed down and Follow Mode activated. At 0:42 we can see that the last step of the second pattern plays instead of the last step of the first pattern: Hope this can be fixed! Best, Kevin BUGREPRO.zip
Sure thing, good idea Peter :)
I just uploaded two videos showing the problem on my actual song. On the first video, pay attention to the TDP when the patterns are switched around 0:16 and 0:32: And a second one with just the Organ lead sound, with the tempo slowed down and Follow Mode activated. At 0:42 we can see that the last step of the second pattern plays instead of the last step of the first pattern: I managed to reproduce the problem in a super simple session which is attached in a zip file in this post. The issue seems to happen when two tracks of a same pattern don't share the same length and/or division. The session is composed of two tracks and two patterns. Pattern A1: —Track 1: Kick — 16 steps long, clockdivider 16 (normal) —Track 2: Hat — 24 steps long, clockdivider 16T (triplet) Pattern A2: —Track 1: Kick —16 steps long, clockdivider 16 (normal) —Track 2: Hat — 24 steps long, clockdivider 16T (triplet) It's a simple drum beat, and there's only one open hi-hat note (D#3) at the very end of the pattern A2 (on the 24th last step). If you play the SONG (with a slow tempo and Follow Mode activated, which makes it easier to see), you will notice that this D#3 note plays instead of last step of pattern A1, so before the pattern A2 is supposed to be played. Once again, I ran the test using both SONG and PHRASE mode, and results are the same. Cheers, Kevin BUGREPRO.zip
So I've tried four SD cards with no luck. But now I'm quite sure of what's going on, but don't see a workaround as it looks like a bug. I slowed down the tempo of my song to 20bpm with Follow Mode ON and that allowed me to see more clearly what is happening. I ran several tests with just one track playing at a time, and they all share the same behavior, syncing the tracks to measure or not didn't change the result. Here's a more detailed explanation: —SONG mode —Pos.A1 = x1 1:A1 (Verse) = 64 steps —Pos.A2 = x1 1:A3 (Bridge) = 64 steps —Pos.A3 = x1 1:A2 (Break) = 64 steps —Pos.A4 = Jump to Pos.A1 —Steps per measure = 64 steps —Change considered each = 64 steps —Pattern change synchronization disabled or enabled (same result) What's happening is that when the SEQ reaches step 64 of Pos.A1, which is the last step of pattern A1, it plays instead the last step (step 64) of the next pattern (A3 in my case). And then it plays the first step of pattern A3 as expected. The problem is the same if I'm in PHRASE mode and switch manually from a pattern to another. As said in my first post, I tried using guide tracks but that didn't help. I'll try to reproduce the problem on a simpler session and share it here, I can also make a quick video if needed. All best, Kevin
Hi Peter, thanks for the reply, I'm currently running the SEQ using a SanDisk SDHC 4GB card, but I'll try with other SD cards and report back. Greets, Kevin
