15,247 -
Hi Adam, here a more general answer (I answered this some months ago, but I will do it again just for the records) the MB64SEQ provided by me will only support 4 tracks. This is enough for my private needs (my groovebox is running in parallel for the drums and synced via MIDI clock). The firmware has been especially designed for an analog style sequencer (and btw: the MIOS version will also support 8 AOUTs (CV outputs) for analog gear) The firmware has to be adapted by somebody else if another usemodel is desired (e.g. for a TB303 or 808/909 like sequencer or for a 16 channel sequencer with minimal hardware requirements (some buttons + datawheel) or whatever) - this won't be my job. The sequencer core routines donn't take care for the number of tracks, but everything else (user interface, etc.) is dedicated to my hardware and mostly useless for other variations. To your questions: 32 knobs: will work, the minimum requirement will be: 8 pots or 8 rotary encoders or 8 motorfaders. Maximum: 64 pots or 48 rotary encoders or 8 motorfaders LEDs: my firmware will support 4 tracks only, so you only need 4 mute buttons/LEDs and 16 mute buttons/LEDs for every single seq. position (the same buttons/LEDs are assigned to different functions depending on the selected menu). The general purpose LEDs also display the sequencer position of a track. (and to prevent any confusion: yes, you could also add a seq position LED to every pot which is usefull when the tracks are running with different settings) Please check also the given wiring diagrams of my own box: http://www.ucapps.de/mbhp/mbhp_dinx4_mb64seq.pdf http://www.ucapps.de/mbhp/mbhp_doutx4_mb64seq.pdf Best Regards, Thorsten. FAQMARKER
Ooops! Sorry, I was totally wrong. I mixed Michael with Christian (I delete this from my old posting to avoid unnecessary confusion if somebody uses the search function from the forum). So, Michael aka Mike is an absolutely reliable person, he must be in holidays. Normaly he delivers within 2-3 days Best Regards, Thorsten.
40 is a hexadecimal number. So: "176 7 65" for increments. Or better write "0xb0 0x07 0x41", which is the same, but looks better. You never wrote what you plan to do with this knowledge...? ;-) Best Regards, Thorsten.
Ok, here a description how it could work: I used an IR sensor with integrated amplifier of an old TV (such sensors can be found in most consumer products) and the IR LED of an old remote control. The IR LED is switched with a constant frequency. And here the results from the scope: (Channel 1: IR Input, Channel 2: IR Output) Than shorter the distance between my hand and the IR sensor/LED pair, than more pulses are received. So, the only thing which has to be done by the PIC is to count the pulses in order to measure the distance. This could be done by a seperate - small - PIC device (Hi Duggle, are you reading this? This would be a nice IIC gadget) or by MIOS projects which still have a free counter input ( Pin C.1 or C.2) Best Regards, Thorsten.
Pilo is now also a moderator of this group (hope this is ok, Pilo? I haven't asked you ;-)) Best Regards, Thorsten.
Das Posting stammt nicht von mir, sondern von Benni, aber nun gut: ich habe die GLCDs erhalten und muss mir nun noch ein paar PCBs aetzen lassen, um damit irgendetwas anfangen zu koennen - der Folienleiter ist so duenn, dass man ihn einem normalen Flachbandkabel nicht verloeten kann. Also nix fuer Gelegenheitsloeter. Nunja, bis ich mal wieder dazu komme, ein Layout anzufertigen, kann es noch dauern. Ich habe mir uebrigens auch das Schaltnetzteil fuer 2,95 EUR bestellt - es liefert 5V/5A und 12V/3A. Die meisten haben mit Schaltnetzteilen ja bisher schlechte Erfahrungen gemacht, aber dieses scheint fuer MIDI-Anwendungen (ausser MIDIbox SID!!!) ganz gut geeignet zu sein. Ich fuehre gerade einen Langzeittest an meiner MIDIbox NG durch. Gruss, Thorsten.
Hallo Seppoman, am besten schliesst Du es direkt an das 64er Netzteil an. Wie Du schon richtig vermutet hast, wuerde es den T1 ueberlasten. Er steuert den Strom. Eine Helligkeitsreglung via PWM kann ich nicht empfehlen, dadurch entsteht Jitter an den analogen Eingaengen (und speziell beim SID: extremer Audio-Noise) VFD Einstreuungen: keine Ahnung, habe solch ein Display noch nie betrieben. Vielleicht weiss jemand anderes mehr? Bestueckung: 7805 und Gleichrichter weglassen, C6 ist ohne den 7805 nicht notwendig, tut aber auch nicht weh. C5 drauflassen und mit der 5V-Leitung verbinden. Gruss, Thorsten.
Hi, <old text deleted to hide my own confusion ;-)> Best Regards, Thorsten.
Hi Nat, yes, your assumptions are correct. Most software can also handle with the "+/- <speed>" setting which should be more prefered, it "feels" more natural (hard to describe if you never tweaked a MIDIbox64E ;-)) The last mode, which is based on the MIDI spec, doesn't include a speed value, therefore most software manufacturers prefer the other (non-standard) modes. Best Regards, Thorsten.
Roland +5v trigger apps. (syncing arpegiator)
TK. replied to a topic in MIOS programming (Assembler)
Hi, you wrote that your synth has a 5V trigger output, so thats fine, you can connect it to a IO pin of the PIC directly. The purpose of the 10k resistor is to have some kind of default logic-level when nothing is connected to the input. This ensures plug-and-play (or better to say: "unplug and no random MIDI triggers") Your suggested transistor circuit is not required. But btw.: it would also work in this way (but it's better to use a 1k resistor at the base input) Best Regards, Thorsten. -
If you've luck (and a good power supply) 50k could work without jittering values. 10k is the maximum suggested impedance for the analog inputs - this value can be found in the PIC18F452 datasheet (AC/DC characteristics). Alternatively you could maybe add a small (transistor based) amplifier in order to lower the output impedance of the joystick. Best Regards, Thorsten.
Hi, if this is a graphical display with an unknown controller it will be very very hard to get it working. You possibly need to program your own MIOS LCD driver, and this requires a good datasheet which contains at least the pinning and the commands that are necessary for the initialization. Ok, and it requires some programming skills (you will find some driver examples in the MIOS download section). If this is a 16x100 dot display, it would be sufficient for a common MIOS application. The character size is 6x8 pixels by default, this means that 16x2 characters can be displayed w/o problems. Best Regards, Thorsten.
Hi Ryan, this circuit is not perfect for adapting it to a PIC, you need a second power supply, and the output voltage range is from 0 to 12V. In fact a digitally controlled D-Beam could be realized on a very easy way, it could run as background task in a MIOS application. I will evaluate this in the next days (a D-Beam would be a nice feature for my MIDIbox SID :-) ) Best Regards, Thorsten.
Hi Nat, there are different formats for sending relative values, they are documented under http://www.ucapps.de/midibox64e_tutorial_en.html (search for "encoder mode"). You need a coding example? Then tell me for which type of message (or for which host application)... Best Regards, Thorsten.
Das stimmt nicht ganz, der 8580 ist eigentlich viel besser als sein Ruf. Das Filter zeigt eine andere Charakteristik, die sich jedoch softwaremaessig an die des 6581 anpassen laesst (deshalb gibt es in der MIDIbox SID Firmware den 8580 Switch) - in den aelteren C64 Spielen wurde auf diese Charakteristik keine Ruecksicht genommen, und deshalb kommen die Sounds nicht so aus dem 8580 raus, wie es eigentlich beabsichtigt war. Bei der Gelegenheit ein Preview: Jess D. Skov-Nielsen hat mir in den letzten Tagen ein paar Tips gegeben, wie man noch etwas mehr aus dem SID herausholen kann. In der neusten (noch nicht veroeffentlichten) Firmware gibt es einen "Curve" Parameter, mit dem sich die beiden Huellkurven aus der Modulations-Matrix "verbiegen" lassen, so dass sie nicht mehr linear verlaufen, sondern exponentiell - so wie man es von teuren Analog-Synthesizern her kennt. Und hier die Ergebnisse: (*) http://www.kubarth.de/sid/files/8580FLT.mp3 http://www.kubarth.de/sid/files/8580PHS.mp3 http://www.kubarth.de/sid/files/8580LOG.mp3 ...wer braucht da noch einen Virus? ;-) Dieser Sound laesst sich nur mit dem 8580 erzeugen - das 6581-Filter klingt wesentlich "dumpfer". Gruss, Thorsten. (*) Diese Beispiele stammen nicht von der MIDIbox SID, sondern von Jess' selbstgebauten SID-Synthesizer - seine Algorithmen gehen nun in die MBSID Firmware ein. :)
Only problem: how to transfer the old forum articles to the SQL database? Best Regards, Thorsten.
no, it behaves correctly. A much more detailed list + schematics with measuring points can be found here: http://www.ucapps.de/howto_debug_midi.html Best Regards, Thorsten.
J2 can either be used as input or output, here it is used as 5V input. A connection via J1 is not required in this case. This saves some electronic parts Best Regards, Thorsten.
Hi Erik, ok, it seems that you've mixed the MIOS upload procedure with the configuration of a PIC16F based firmware. One reason again to discontinue the old stuff, it produces too much confusion and "communication effort". :-/ On a PIC16F firmware the black bar should disappear immediately after power-on (note for MIOS users: it disappears during the boot phase, ca. 2 seconds after power-on) If the bar is still there, your display is not connected correctly or your PIC is not running. Is there any sign of life from your PIC (MIDI messages on pot moves?) Best Regards, Thorsten.
Hi Christoffer, well done! Looking forward for some audible impressions :) If you want to enjoy the advantages of the upcoming features, use the PIC18F - I will also replace the PICs of my slave modules sooner or later. Best Regards, Thorsten.
Hi Klass, I'm using the MAX6007B as 2.048V voltage reference and the LM324 as amplifier to extend the voltage range. This makes the AOUT module more flexible for different CV requirements - there is no need for a second voltage reference. Best Regards, Thorsten. P.S.: although this schematic is preliminary, it's already working very fine :)
