serge
73 -
Everything posted by serge
Hi Ilmenator, it works OK for me too now. ??? :) it WAS my PC probably Regards, Serge
Hi, I'm curious to see the MIOS Pogress bar but I cannot : when surfing to www.ucapps.de I get a javascript error if I try to click MIOS progress bar. :( when I surf to ucapps.de I cannot see the item in the menu. :-/ when i enter the url http://www.ucapps.de/mios_status.html by hand, I seem to return to the main page. ??? Does someone else have this problem or is it my PC ? Regards, Serge
Hi Rogic, indeed a new version 1.01 for mb64 (mbhp) is released. It is downloadable at http://ucapps.de/midibox/midibox64_v101.zip. The list of changes will follow soon... Thorsten is still considering namechanges for the new features to make the changelog rhyme... ;) ;D Regards, Serge
Hi Etko, i do not have Reason 2.0 but I think it will work perfectly with a midibox if you configure both correctly. If you are planning to build a midibox but are not sure yet what you need, you could try to use vmidibox64 (see serge.ucapps.de) at first to configure and test the connection between your pots and buttons, and the Reason functionality. Vmidibox64 is a program that partially emulates the functionality of a hardware midibox by software. If you have defined the knob settings in this program you could later dump them into you hardware midibox. You probably need the MidiYoke driver to be able to link vmidibox to Reason without a midi loop cable. Good luck, Serge
Hi, I released a new version of vmidibox64 : 1.01a This one matches mb64 firmware version 1.01. It features the DOUT Shiftregister, TouchSensor, LC Emulation ID Settings ,... You can download it from http://serge.ucapps.de/ as usual. Thanks Thorsten for your help !! Â :) Â Â Â Â Â Â Have Fun, Serge
Hi, with coding help from Thorsten :) :) :), I released a new version of vmidibox16E : 1.004 This supports the Houston Emulation mode and matches firmware version 1.004. You can download it from http://serge.ucapps.de/ as usual... Regards, Serge
Hi y'all, with coding help from Thorsten :D, I can now release a new version of vmidibox16E. It now features LED Pattern and DOUT Shiftregister Editing... You can download it from http://serge.ucapps.de/ as usual... Regards, Serge
Mega ! ;D ;D ;D ;D ;D
Hi Insilentio, zie http://www.howstuffworks.com/mouse2.htm voor een voorbeeld + foto van de rotary encoders in een muis. zie ook voor meer uitleg over uitlezen van encoders :http://mechatronics.mech.northwestern.edu/mechatronics/design_ref/sensors/encoders.html mvg, Serge
I agree, the new nav bar is a nice improvement for master T's already great website. Now we see at a glance the variety of midiboxes :o :o :o Ans who knows how much this will grow in 2003 ??! ;D Happy NY Dan ! :)
Happy new yaer ;D Ian !
Tofu, the virtual desk of vmb64 does not yet simulate the differences between normal/snap/relative pot modes. It is currently only supported for editing the sysex but has no effect on the virtual desk. ... in the current version... I will add it on my to-do list ;) !!! Regards and a happy 2003 !! Serge
Yes, the best wishes to you Thorsten and all Midi-Box-Lovers. :D Serge
looks great !!!! ;D
Hi again, I quickly added a new feature : By adding code like below to the VMB file you can load a certain sysex file at startup [CUSTOMSYSEX] FILENAME=fabtest1.syx Useful for your custom autoload skins... ::) Regards, Serge
You can download the new version from the website http://serge.ucapps.de It has a great sample virtual box skin donated by Fabrizio (fbatino@inwind.it) !!! Look at the code in FabSkin64.vmb64 to see how this is done. There are a few new settings in vmb64 1.00e : They can be used the following way : - add them in vmb64presets.ini : this way they are used when you start the program as usual - add them to the .vmb file you are creating : change the windows file association to the extension used (.vmb64) or drop the file on vmidibox64.exe sample settings : [APPLICATIONPRESETS] MIDIINPORT=8 MIDIOUTPORT=9 SYSEXSENDSPEED=200 [CUSTOMDESK] FILENAME=self AUTOSHOW=1 EDITORHIDE=1 Thanks Fabrizio, Have fun !! Serge
very impressive ! waaw! :o :o :o :o :o :o
Wow !!!!!!!!! :)
Looks cool !!! ;D
Hi Dave, It is a good idea. I will add it to my vmb64 to-do list. ;) Regards, Serge
Hi, finally a release version of vmidibox64 is out : version 1.00a It has the following changes : - sysex ID support, - disable navigation keys feature, - 64 buttons - bank name support - sequencer settings are now removed This version is supposed to be compatible with Thorsten's new mb64 v. 1.0 firmware. For the users of previous mb64 firmware versions, I will keep the old vmidibox as vmidibox64_0xx.zip on the server (http://serge.ucapps.de) for a while. Have fun ! Serge
Hi o3d, this is great stuff !!!! I like all 3 songs. (but mostly 'When the rythm gets phat') It could use a touch of SID to make it perfect ? ::) Keep up the good work ! Serge
