Stigmata
    178
Everything posted by Stigmata
  1. Nu har visst ELFA PIC18F452 för 97.70 + moms, inte så djävligt dyrt.... :). Klart det blir ju billigast att beställa samples men ändå. Christoffer
  2. This is 1 year old but now when x-mas is near...... ;D http://www.subspace.se/tfl/video/index.html Christoffer
  3. Ronaldo
  4. Hi there! Don´t really know where you can get the parts in UK but if you look at:http://www.ucapps.de/midibox_sid.html There is an part list of every link for ex:http://www.ucapps.de/mbhp/mbhp_core_orderlist.txt and so on...(It took me some time to collect all the parts from Sweden, but it´s worth it!!) ;D Hope I help a little.. ;) Christoffer
  5. Just looking at the PDF mbhp_4xsid_c64_psu_optimized.pdf Little confused :-[ Isn´t the J2 at the core an 5V output?? ??? If it is what´s the use for the J1???(I dont want to burn another PIC again ;) ) Christoffer
  6. Shoplifting
  7. Just done with my 4th sid.. ;D Just planning to go to next... Step C full control ;D Should I go for the pic 16f on the slaves or should I go for the 18f... Thinking most for the near future.. (Maybe an self playing sid, not having time to play around with it becuse all the soldering) ;) Christoffer
  8. photo
  9. sorry :-[ ;) Christoffer
  10. Ok i just read something into the cs_menu_cc_tables.inc: ;; due to memory limitations we have to get rid of this nice feature ;; print 12 spaces instead and exit Is that the problem?? ;) ;D Christoffer
  11. Hi there! Just read that the cc´s should be on the display!! All I got is the cc number: ex: " 2| " shouldn´t i get:" 2|Mod. Wheel "??.. I´m been looking into the Main.asm and the menu_cc_table.inc but I´m don´t really understand this. ??? ??? ;). I hope that I understand this wonderful MIOS in the future! ;D. I got an 2*16 lcd but I don´t think that´s matters, or? Christoffer
  12. Yeah!! Working ;D ,The problem was I got the MIOS ver.1.3.. Another question:The rate (in the WT menu) how do you know that the value should be 123 for 16th note? If I want it to be 4th note?? Do I have to be an matematic professor or something?? ;) Thanks!!!! Christoffer
  13. Hi! Allready tried that... Doesn´t work!!! :-/ Maybe I´m forgot something...??Or maybe I´m just stupid.. ;) Christoffer
  14. Hi there! Just an question..I´m using the sid firm 1.5c. And I can´t get sync of the arpeggiator. I have the rate of the WT to 123 (as Thorsten write before) And the Clk in CFG menu to W_ _. And I´m sendig the MIDI Time code from Cubase SX. Should I go back to the SID 1.5b or... Thank´s Christoffer
  15. Hmm.... Nothing here is stupid to ask.. ;D Christoffer
  16. Did you burn the PIC16f877 with the firmware for the 8580?? Christoffer
  17. Works for me! Christoffer
  18. Yes! It´s works for me! Strange..... Christoffer
  19. Yes! It´s works for me! Strange..... Christoffer
  20. Hi there!! Just found out an bug in the J-synth I think... The Jsynth and the sid not respond the same playmode Jsynth=MONO SID=WTS Jsynth=Legato SID=WTS Jsynth=WT seq only SID=Mon Jsynth=Poly SID=Poly Christoffer
  21. Hi there!! Just found out an bug in the J-synth I think... The Jsynth and the sid not respond the same playmode Jsynth=MONO SID=WTS Jsynth=Legato SID=WTS Jsynth=WT seq only SID=Mon Jsynth=Poly SID=Poly Christoffer
  22. Solved!! It was the filter for the 8580 in the hex file.. Stupid me!! ;) Christoffer
  23. Solved!! It was the filter for the 8580 in the hex file.. Stupid me!! ;) Christoffer
  24. Thanks! Working just fine!! ;D Christoffer
