Jack
Programmer-
323 -
4
Everything posted by Jack
Hi all, I'm finally finished my MB SEQ V4L V1 from 2011. Sorry for the poor quality. Next step for me: Learn to play Next step for my children: Raspberry PI Touchcreen extension Best regards Jack
Thanks for your help. With the installed sequencer this option is still not available. Only if the bootloader alone is installed. Following steps are working for me: 1. Upload only bootloader 2. Connect the LCDs 3. Start MIOS Studio 4. Enter following into MIOS Terminal set lcd_type 0x02 store 5. Upload midibox_seq_v4_092 => Working Only issue on 5V the LCD starts stinking (not like on LPC17 Core), so I changed to 3V and everything is fine now. Except the 3V3 Regulator getting really hot. Best Regards Jack
Hi all, I have the same Raystar like Jbdriver. On a LPC17 Core with 5V and 3.3V it is working like a charm. But on the STM32F4 (MB997D) it is not working, same issues like jarvis: What I have tested yet: * External power supply with 5V (Pin J2) and 3.3V (J15_S middle Pin) is not working. * Also with the 3.3V regulator from LPC17 Core it not working. - STM32F4:J2 -> LPC17:J2 - LPC17:J15_S Pin 3v3 -> STM32F4:J15_S middle Pin - STM32F4 USB and LPC17 power supply The left display is also not working 100% correctly. Some characters are wrong In my opinion it is a timing problem with the enable pins. Where can I set the "LCD type to 0x02"? In MIOS terminal this option is missing for STM32F4. Best Regards Jack
Full 16x16+X BLM with silicone buttons, matching case. Interested?
Jack replied to latigid on's topic in MIDIbox BLM
@ latigid on can you upload a High Res PDF Version of the BLM, please? I need it for troubleshooting. Thanks and Best Regards Jack -
Name PCB BLM PCB miniCore Case Shift button M2 hardware 4xLED latigid on 1 1 1 1 1 1 Rowan 1 1 1 1 1 1 Phatline 2 2 1 2? 1 1 TK 1 1 1 1 1 1 Altitude 1 1 1 1 1 1 rwo 1 1 1 1 1 1 jojjelito 1 1 1 1 1 1 tashikoma 1 1 - 1 - 1 workspace 1 1 1 1 1 1 flyweight 1 1 1 1 1 1 Grizz 1 1 1 1 1 1 blingy 1 1 - 1 - 1 ganchan 1 1 1 1 ? 1 Macotronic 1 1 - - - - Jack 1 1 1 1 1 1 Total 16 16 11 15 11 14
Found an interesting concept from teenageengineering.com just follow the link. Best Regards Jack
Hallo Thorsten, macht bitte Videos davon. Wäre gerne dabei gewesen, kann leider nicht daran teilnehmen, Best Regards Jack
MBHP_ETH, MBHP_SDCARD, SSM2044, SSM2164 PCB Bulk Order
Jack replied to seppoman's topic in Bulk Orders
Thank you, I received my package today. Thank you also for your time and effort. Best Regards Jack -
No Stress, I have time. Just want to know when I should plan my midibox holidays. Best Regards Jack -
Hi seppoman, Do you have a update of the delivery progress? Best Regards Jack -
Sorry I make a mistake. I mean the angle of view is not so optimal with the LCD on a flat case.
Hi Altitude, It looks nice but with a LCD this flat case is not optimal. I would prefer a sloped enclosure (Pultgehäuse) or a keyboard enclosure, see Link. Best Regards Jack
Hi, I am also not a DSP specialist. My suggestions: - set the oszi to AC and measure again - check and measure the power source during triangle and pulse - check and measure the clock Do you use a amplifier? Best Regards Jack
Hi, das gibt es auch eine nummer größer (mit mehr drehencoder Har Har Har) und teuerer: http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582 Die Bausätze gibt es hier: http://avishowtech.com/mbhp/ Best Regards Jack
Hallo Hvl-Players, Vielleicht wäre das, was für Dich: http://translate.google.de/translate?js=y&prev=_t&hl=de&ie=UTF-8&u=http%3A%2F%2Fwww.midibox.org%2Fforum%2Findex.php%2Ftopic%2C14079.0.html&sl=en&tl=de&history_state0= kostet aber ca 150€ Best Regards Jack
So viele wie Möglich, ist vielleicht schon zu viel. Die frage ist immer, wieviele Kanäle brauche ich wirklich zum arbeiten. Bei mir sind 16 optimal und wenn ich mehr brauche, dann habe ich per tastendruck 16 weitere zur Verfügung. PS: Den Mackie C4pro gibt es zurzeit für 444€ 385€ im Angebot. Best Regards Jack
Hi Peroja, hast Du die Scalen auch neu machen lassen? Wenn ja, wie wurde es gemacht? Best Regards Jack
Hi, Ja. Schau Dir mal den Midibox LC an, bzw. den Mackie Control http://www.mackie.com/home/showimage.html?u=/products/mcupro/images/MCU-Pro-Top.jpg Source: http://www.mackie.com/products/mcupro/index.html Für mich, ist das rumschalten, persönlich ziemlich nervig. Deshalb habe ich noch weitere 8 Kanäle gekauft. Damit geht es deutlich besser als nur mit 8. Ich habe hier noch was interessantes für Dich: http://www.beis.de/index.html schau mal nach DPLCM-VFD. Leider hat es nichts mit Midi zu tun :( . Best Regards Jack
Hi Wilba, Any update? Do you have a timeline? I must plan my vacation for building. :) Best Regards Jack
Put Waveblaster daughter board (Yamaha DB50XG) in a box?
Jack replied to SeverityOne's topic in Design Concepts
I found another one from Trond Olsen played on a MU10. <object width="560" height="340"><param name="movie" value="http://www.youtube.com/watch?v=2GTal2jczpg&hl=de&fs=1&"></param><param'>http://www.youtube.com/watch?v=2GTal2jczpg&hl=de&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/watch?v=2GTal2jczpg&hl=de&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object> Best Regards Jack -
I like both ideas. A mixed panel Frontpanel would also be nice: - Aluminium as base - Acryl for the lcd and the LEDs (iluminated midibox logo) Best Regards Jack
I recorded some short LQ sound samples from a SW50XG. I have also a sound sample from the Yamaha Demo xg midi file (Jimi Hendrix - Voodoo Chile), but I don't know if it cause a copyright problem. ??? Best Regards Jack LQ_Trond Olsen - Olsen Driver.mp3 LQ_Trond Olsen - Skeletor.mp3 LQ_Trond Olsen - Olsen Driver.mp3 LQ_Trond Olsen - Skeletor.mp3 -
Hi Steve, It looks nice. :) I have a wish list: optional Audio Input for the DB60XG encoder for the menu bigger display, e.g. 4x40 or 2x40 to display all channels, instruments, ... support to save and load QS300-Voices over the memory @joeribl The PSU is not the problem, because it is external. Can you try this midi files from Trond Olsen (except Indiana)? http://www.megatrade.ru/Russian/Midi.html On my SW60XG they sound fine but on my DB50XG and DB60XG on a SB16Pro they sounds weird. Maybe there is a problem to load the QS300 Voices. I would like to know if you have the same problem. Best Regards Jack -
Hi Steve, I am ready to build. If have bought 5 DB60XG clone from NEC XR385 and 1 DB50XG. :D http://cgi.ebay.com.sg/Yamaha-DB50XG-DB60XG-Sound-Daughter-Board-SW1000XG_W0QQitemZ190296107746QQihZ009QQcategoryZ108984QQcmdZViewItem And I already own a SW60XG as reference. @stryd_one check your pm. Best Regards Jack -
Hi, I have found a helpful sites long time ago, for XG programming. Maybe this is helpful for you. XG programming: http://www.studio4all.de/htmle/frameset090.html http://www.studio4all.de/htmle/welcomexg.html alternative board design, but in german: http://www.heise.de/ct/Wavetable-Board-als-MIDI-Expander--/artikel/123220 @Steve, nice project. :) Do you have created a board for preview? Best Regards Jack
