Jack
Programmer-
323 -
4
Everything posted by Jack
Hi, I found very interesting 8Bit event. Some impressions on youtube from my favorit artist trash80: http://blipfestival.org/2008/ Interested? Search for "Blib Festival" on youtube. PS: I missed the SID Best Regards Jack
Hi Thorsten, OK, your arguments are convinced me. Really Bad idea. PS: I am blind without my glasses. :) Best Regards Jack
Hi Phil, my idea was to use six DOGL128-6 (128x64 or 67,8mm x 48,26mm). :) But I don't know if it is a good idea. Best Regards Jack
Hi Thorsten, I know. Which distance have the encoder to each other? Is there enough room to fit 6 displays (3 Encoders per display)? Can you send me your Eagle schematic (mbhp_lcd7_dog.pdf)? I want to use it for my Eagle library. Best Regards Jack
Hi all! Have someone checked if one of this displays fits into Wilba's Sequencer? Best Regards Jack
No, you are not an Idiot! :) I found a new fitable place: http://www.midibox.org/dokuwiki/doku.php?id=parts Best Regards Jack
Hi all, I created some Eagle libraries: http://www.midibox.org/dokuwiki/doku.php?id=eagle_midibox_library I will create the related schematic and Eagle3D the next days. Best Regards Jack
I update the wiki: http://www.midibox.org/dokuwiki/doku.php?id=jack Best Regards Jack
Hi, I thinking about DIY led rings, see my attachments. But I don't know how build the upper part. Best Regards Jack
Hi, I have started to publish my Eagle and Eagle3D libraries: http://www.midibox.org/dokuwiki/doku.php?id=eagle_midibox_library http://www.midibox.org/dokuwiki/doku.php?id=eagle3d_midibox_user_pack If you have created any Eagle or Eagle3D MIDIBox libraries, please post there. @Admin: I don't know how to upload my Eagle libraries into DokuWIKI page. Best Regards Jack
Hi! Before you pay over 100€, please check this for less money: main: http://www.fpga4fun.com/Hands-on_Flashy.html usb: http://www.fpga4fun.com/Hands-on_Flashy_USB.html shop: http://www.knjn.com/?pg=info&src=Flashy Best Regards Jack
Hi, you can use like this for your frontpanel: Link: http://www.thomann.de/de/thon_1he_rackblende_xlr.htm I don't know if this is fitable for the GM5x5x5 but it is very cheap only 9€. Best Regards Jack
Multi-Tap Transformers Versus Voltage Regulators?
Jack replied to m00dawg's topic in Design Concepts
Hi, I am not shure because I slept in school. My Theory: Those caps have a tolerance up to 20%. So more caps should make it more smooth as few caps. But we should wait the answer from stryd_one. The Red ractangle are 0Ohm Resistors for 230V respectively 115V primary power supply. What are MOVs? The overvoltage is not so problemtic because I use 78S05 and a big heat sink. http://www.reichelt.de/?;ACTION=3;LA=2;GROUP=C85;GROUPID=3382;ARTICLE=22252;START=0;SORT=artnr;OFFSET=1000;SID=31LpgomqwQAR8AAB7VZUQ6b83af634c0161cfab3b9a7d11c2e743 Best Regards Jack -
Hi, I am planning to build a MB6582 power supply, too. I used this "NT-25-09" and "SPR-2" from "www.thel-audioworld.de" professional as References design: http://www.thel-audioworld.de/module/NT1525/NT1525.htm Transformator Modul http://www.thel-audioworld.de/module/spr/SPR-2.htm Audiophiler Voltage Regulator See attachement for my design suggestions. - RingCore Trafo Talema 2x115V primary and 2x9V secondary - 78S05 and 78S09 Regulators - Cap for smotthing 4x Panasonic FC 1000µF/63V Best Regards Jack -
Hast Du ID 0 ausprobiert? Den CS erkennt er, bei mir nur, wenn die ID 0 ist. Best Regards Jack
Hi Vinyljunkie, hört sich danach an, als ob die IDs nicht stimmen. Das Control Surface muß die ID 0 haben. Die Slaves 1,2,3. Ich hoffe das war das problem. Best Regards Jack
Hi, We could use the ring as bar. Or a Bar as ring. ;D @Phattline How about the Stribe instead of a Motorfader? Best regards Jack
Hi, My wish is a multipurpose Hardware and Software plattform, switchable per SW. Hardware extention wish (optional): - 2x additional 40x2 LCD support - 16x additional encoder - 32x Led Rings - 64x Button/LED Matrix - 8x or more Stribes Software applications wish: - SwinSiD - C4pro clone - ... Best regards Jack
I got it to yesterday. Thanks seppo, too! Best regards Jack
Hi, I want to order 120 x 3FTL6 "Quiet" 120 x 1D.16 "Translucent white" Is there a possibility to order some 1T.16 and 1U.16 (feels better than the 1D)? Best regards Jack
Hi Wilba, Problem solved with a new C64 power supply. Thanks for helping. Best Regards Jack
Hi Wilba, I am at this point: "Completing the Base PCB in Stages" No IC is mounted and only parts for PSU Option A is soldered. C64 Power Supply: - 10,8V AC - 6,3V DC (2,4V AC) Base PCB measured points: J09, J3, UX_COREX Pin 11-12 and 32-31. I think its the AC ratio of the +5V line of the power supply causes this problem. The volatge is stable at the moment at 8,4V but only the first measurement I have 12,3V. Best regards Jack
Hi, I have measured on the 5V line, 8-12V DV, on the naked Base PCB. I am using the PSU Option A and the 9V line is OK. I think this the overvoltage is caused from loaded caps, because no load is connected. Can someone confirm this? Best Regards Jack
Hi! Does anybody knows a good source for the 100mil spacing cable in Europe(Germnay)? I found it on Conrad (606162-F0). Best Regards Jack
Hi Wilba, I'm interested, too. ;D I would suggest to use this kind of case: http://www.thomann.de/gb/skb_84_dj_shuttle.htm Best regards Jack
