Jack
Programmer-
323 -
4
Everything posted by Jack
Hello TK! Have you tested the workaround from Microchip? The Forum message from microchip, seems to be deleted! Jack
It sounds nice! ;) Jack
Hello! Good old style game music. Source: http://store.introversion.co.uk/product_info.php?products_id=49 Link from Source: http://dma-sc.atari.org/ http://www.trash80.net/ My favorite: http://www.trash80.net/mp3s/trash80_-_pain-fade-down.mp3
www.ucapps.de is not reachable. Maybe it is down. Jack
Some Links to DIY Distortion Filter: (not googled, searched in guitar forums) http://www.tonepad.com/projects.asp?projectType=fx            //lot of links http://www.home-wrecker.com/salvo.html                      //some demosound from DIY filters http://www.geocities.com/j4_student/schematics.htm http://smallbox.zeonhost.com/ Someone tried NI Guitar Rig Demo? It works well with MB SID. Jack
Nice Sounds! I can't get enough. More Sounds, please. :D Jack
Hi Skunk! The O-Led tecnology has an important problem, they are to small. (sized like a stamp, but a very good quality) Maybe in the next 2 years this can be changed. Check this: http://www.mikrocontroller.net/forum/read-1-216884.html#new And check the Pov-Ray code. mfg Jack
Hi Dan! Look at this: http://www.superkranz.de/christian/S65_Display/DisplayIndex.html http://www.mikrocontroller.net/forum/read-4-243641.html#new Forum thread is in German, but international questions possible. LPH88xxxx has the best documentation. LS020xxx is the most saled on Ebay. My idea: Using the PIC18F2550 SPI as companion chip to controll up to 2 Displays. And the I2C Inface from Core to communicate between the PICs. PS: I have ordered 8 pieces for 80€. What Do You think? Jack
No problem, I have time. Jack
@TK You have more skills that I never be able to reach. But I never give up! What's your suggestion? @me It my new hobby and I need a new motivation. PS: I have: - 8 pieces of EP9302 ARM9 from Cirruslogic - 32 pieces CS5381 A/D - And a Mother who can solder 144 LQFP without any probs!!! ;D Sources: http://www.mikrocontroller.net/forum/read-1-259841.html#new http://www.embeddedartists.com/products/boards/lpc2106_rs232.php Good Night Jack
Hi all! I decide to work on my free time, on a refresh of the MBSID design. PRO ARM: -One ARM should control 4 SIDs - ~60MIPS -USB2.0 (next year) -Audio CODEC (at the moment not implemented) -more IO -SD / MMC optional -embedded LINUX CONTRA ARM: -Soldering only for Profesionals -2 Layer design (expensive) -JTAG problem (only with free Software) I will order my developement board in 30 Days, but I cannot decide which ARM is the best solution. Both chips are very equal. Source: www.olimex.com http://www.olimex.com/dev/lpc-h2214.html http://www.olimex.com/dev/sam7-p64.html Jack
@Rio Danke! @TK Danke! Hab ich noch nicht gewusst, werd ich morgen mal ausprobieren. @all Habe meinen PIC heute von reichelt bekommen. Werde es morgen mal ausprobieren. mfg Jack
Hi Dan! I made a hole raster PCB (Lochrasterplatine) but it is to big and not sucessfully tested yet. http://www.midibox.org/users/jack/8xPCD8544.brd @Roger Don't forget me! Jack
Hi Dan! This is the best solution for this display. Have you tried with 8 displays? (if you have 8 one!) I will use it for SEQ and for MBLC. But I haven't so much time to order it. How thick have you designed your display + pcb? Jack
Hallo! Du musst aber noch die kosten für die sichere Verpackung und den Versand mitkalkulieren. mfg Jack
Habe es mal durch den Frontplatten Designer mal ausrechenen lassen: Erstellt mit der Preisebasis von Firma: Schaeffer Apparatebau KG Datum der Preisbasis: 1. März 2004 Typ     | Position   | Bemerkungen             |   Preis ----------------+---------------+--------------------------------------+----------- Sonstiges  | ------------- | Vor-/Nacharbeiten          |  4,88 € Material   | ------------- | 2,0 mm Aluminium Eloxiert/Natur   |  4,63 € Rahmen   | 0,00/0,00   | Höhe: 127,00 mm Breite: 397,51 mm  |  6,85 € Bohrung   | 162,56/111,76 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 181,61/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 167,64/111,76 | OSC                 |  0,37 € Bohrung   | 189,23/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 181,61/107,95 | 1                  |  0,16 € Bohrung   | 196,85/111,76 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 21,59/110,49 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 25,40/110,49 | SID1                 |  0,37 € Bohrung   | 21,59/102,87 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 25,40/102,87 | SID2                 |  0,41 € Bohrung   | 21,59/95,25  | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 25,40/95,25  | SID3                 |  0,41 € Bohrung   | 21,59/87,63  | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 25,40/87,63  | SID4                 |  0,40 € Bohrung   | 289,56/73,66 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 295,91/73,66 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 299,72/73,66 | Sync                 |  0,38 € Bohrung   | 295,91/68,58 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 299,72/68,58 | Ring                 |  0,40 € Text-Gravur | 189,23/107,95 | 2                  |  0,20 € Text-Gravur | 196,85/107,95 | 3                  |  0,20 € Bohrung   | 264,16/111,76 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 283,21/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 269,24/111,76 | Ctrl                 |  0,31 € Bohrung   | 295,91/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 283,21/107,95 | Env                 |  0,32 € Bohrung   | 308,61/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 295,91/107,95 | Misc                 |  0,42 € Text-Gravur | 308,61/107,95 | Assign                |  0,52 € Text-Gravur | 166,37/80,01 | Delay                |  0,45 € Text-Gravur | 191,77/80,01 | Attack                |  0,50 € Text-Gravur | 217,17/80,01 | Decay                |  0,47 € Text-Gravur | 242,57/80,01 | Sustain               |  0,54 € Text-Gravur | 267,97/80,01 | Release               |  0,60 € Text-Gravur | 166,37/76,20 | Transpose              |  0,69 € Text-Gravur | 191,77/76,20 | Finetune               |  0,58 € Text-Gravur | 217,17/76,20 | Portamento              |  0,75 € Text-Gravur | 242,57/76,20 | Arpeggiator             |  0,84 € Text-Gravur | 267,97/76,20 | PulseWidth              |  0,78 € Text-Gravur | 166,37/72,39 | Assign #1              |  0,64 € Text-Gravur | 191,77/72,39 | Assign #2              |  0,68 € Text-Gravur | 217,17/72,39 | Assign #3              |  0,68 € Text-Gravur | 242,57/72,39 | Assign #4              |  0,67 € Text-Gravur | 267,97/72,39 | Assign #5              |  0,68 € Bohrung   | 15,24/110,49 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 66,04/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 66,04/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 66,04/95,25  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 66,04/87,63  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 66,04/80,01  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 66,04/72,39  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 66,04/64,77  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 73,66/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 73,66/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 73,66/95,25  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 73,66/87,63  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 73,66/80,01  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 73,66/72,39  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 73,66/64,77  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 81,28/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 81,28/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 81,28/95,25  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 81,28/87,63  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 81,28/80,01  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 81,28/72,39  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 81,28/64,77  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 88,90/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 88,90/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 88,90/95,25  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 88,90/87,63  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 88,90/80,01  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 88,90/72,39  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 88,90/64,77  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 96,52/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 96,52/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 96,52/95,25  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 96,52/87,63  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 96,52/80,01  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 96,52/72,39  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 96,52/64,77  | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 104,14/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 104,14/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 104,14/95,25 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 104,14/87,63 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 104,14/80,01 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 104,14/72,39 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 104,14/64,77 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 111,76/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 111,76/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 111,76/95,25 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 111,76/87,63 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 111,76/80,01 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 111,76/72,39 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 111,76/64,77 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 119,38/110,49 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 119,38/102,87 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 119,38/95,25 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 119,38/87,63 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 119,38/80,01 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 119,38/72,39 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 119,38/64,77 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 66,04/115,57 | E1                  |  0,26 € Text-Gravur | 73,66/115,57 | E2                  |  0,29 € Text-Gravur | 81,28/115,57 | L1                  |  0,21 € Text-Gravur | 88,90/115,57 | L2                  |  0,24 € Text-Gravur | 96,52/115,57 | L3                  |  0,24 € Text-Gravur | 104,14/115,57 | L4                  |  0,23 € Text-Gravur | 111,76/115,57 | L5                  |  0,25 € Text-Gravur | 119,38/115,57 | L6                  |  0,26 € Text-Gravur | 123,19/110,49 | O1 Pitch               |  0,53 € Text-Gravur | 123,19/102,87 | O2 Pitch               |  0,56 € Text-Gravur | 123,19/95,25 | O3 Pitch               |  0,56 € Text-Gravur | 123,19/87,63 | O1 PW                |  0,45 € Text-Gravur | 123,19/80,01 | O2 PW                |  0,48 € Text-Gravur | 123,19/72,39 | O3 PW                |  0,48 € Text-Gravur | 123,19/64,77 | Filter                |  0,41 € Bohrung   | 57,15/110,49 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 57,15/102,87 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 57,15/95,25  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 57,15/87,63  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 57,15/80,01  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 57,15/72,39  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 57,15/64,77  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 66,04/55,88  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 73,66/55,88  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 81,28/55,88  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 88,90/55,88  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 96,52/55,88  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 104,14/55,88 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 111,76/55,88 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 119,38/55,88 | Durchmesser: 4,00 mm         |  0,12 € Text-Gravur | 167,64/52,07 | LFO                 |  0,32 € Bohrung   | 162,56/52,07 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 181,61/52,07 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 189,23/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 181,61/48,26 | 1                  |  0,16 € Bohrung   | 196,85/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 189,23/48,26 | 2                  |  0,20 € Text-Gravur | 196,85/48,26 | 3                  |  0,20 € Bohrung   | 204,47/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 204,47/48,26 | 4                  |  0,19 € Bohrung   | 212,09/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 212,09/48,26 | 5                  |  0,20 € Bohrung   | 219,71/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 219,71/48,26 | 6                  |  0,21 € Bohrung   | 219,71/39,37 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 223,52/39,37 | Sine                 |  0,37 € Bohrung   | 219,71/34,29 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 223,52/34,29 | Triangle               |  0,58 € Bohrung   | 219,71/29,21 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 223,52/29,21 | Saw                 |  0,37 € Bohrung   | 219,71/24,13 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 223,52/24,13 | Pulse                |  0,42 € Bohrung   | 213,36/39,37 | Durchmesser: 4,00 mm         |  0,12 € Text-Gravur | 166,37/20,32 | Rate                 |  0,41 € Text-Gravur | 191,77/20,32 | Depth                |  0,48 € Text-Gravur | 341,63/111,76 | Filter                |  0,41 € Bohrung   | 336,55/111,76 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 355,60/111,76 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 363,22/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 355,60/107,95 | O1                  |  0,25 € Bohrung   | 370,84/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 363,22/107,95 | O2                  |  0,28 € Text-Gravur | 370,84/107,95 | O3                  |  0,28 € Bohrung   | 378,46/111,76 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 378,46/107,95 | Ext                 |  0,32 € Text-Gravur | 345,44/80,01 | Cutoff                |  0,46 € Text-Gravur | 370,84/80,01 | Resonance              |  0,73 € Text-Gravur | 341,63/73,66 | Mode                 |  0,49 € Bohrung   | 336,55/73,66 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 355,60/73,66 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 363,22/73,66 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 355,60/69,85 | LP                  |  0,24 € Bohrung   | 370,84/73,66 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 363,22/69,85 | BP                  |  0,30 € Text-Gravur | 370,84/69,85 | HP                  |  0,27 € Bohrung   | 378,46/73,66 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 378,46/69,85 | 3O                  |  0,28 € Bohrung   | 33,02/7,62  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 50,80/7,62  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 68,58/7,62  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 86,36/7,62  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 134,62/7,62  | Durchmesser: 4,00 mm         |  0,12 € Grav.-Recht.| 234,95/91,44 | 170,18 mm x 55,88 mm Dicke: 0,40 mm |  1,54 € Grav.-Recht.| 358,14/91,44 | 68,58 mm x 55,88 mm Dicke: 0,40 mm  |  0,90 € Grav.-Recht.| 199,39/34,29 | 99,06 mm x 50,80 mm Dicke: 0,40 mm  |  1,06 € Bohrung   | 219,71/19,05 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 223,52/19,05 | Random                |  0,59 € Bohrung   | 295,91/99,06 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 299,72/99,06 | Triangle               |  0,58 € Bohrung   | 295,91/93,98 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 299,72/93,98 | Saw                 |  0,37 € Bohrung   | 295,91/88,90 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 299,72/88,90 | Pulse                |  0,42 € Bohrung   | 295,91/83,82 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 299,72/83,82 | Noise                |  0,44 € Bohrung   | 289,56/99,06 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 265,43/52,07 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 284,48/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 270,51/52,07 | Env                 |  0,32 € Bohrung   | 292,10/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 284,48/48,26 | 1                  |  0,16 € Text-Gravur | 292,10/48,26 | 2                  |  0,20 € Bohrung   | 342,90/52,07 | Durchmesser: 4,00 mm         |  0,12 € Text-Gravur | 347,98/52,07 | Ctrl                 |  0,31 € Bohrung   | 361,95/52,07 | Durchmesser: 3,00 mm         |  0,10 € Bohrung   | 374,65/52,07 | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 361,95/48,26 | Env                 |  0,32 € Text-Gravur | 374,65/48,26 | Assign                |  0,52 € Text-Gravur | 269,24/20,32 | Depth                |  0,48 € Text-Gravur | 294,64/20,32 | Attack                |  0,50 € Text-Gravur | 320,04/20,32 | Decay                |  0,47 € Text-Gravur | 345,44/20,32 | Sustain               |  0,54 € Text-Gravur | 370,84/20,32 | Release               |  0,60 € Text-Gravur | 269,24/16,51 | Assign #1              |  0,64 € Text-Gravur | 294,64/16,51 | Assign #2              |  0,68 € Text-Gravur | 320,04/16,51 | Assign #3              |  0,68 € Text-Gravur | 345,44/16,51 | Assign #4              |  0,67 € Text-Gravur | 370,84/16,51 | Assign #5              |  0,68 € Grav.-Recht.| 322,58/34,29 | 139,70 mm x 50,80 mm Dicke: 0,40 mm |  1,32 € Bohrung   | 48,26/55,88  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 142,24/115,57 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 142,24/55,88 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 48,26/115,57 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 153,67/12,70 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 153,67/67,31 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 153,67/115,57 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 245,11/55,88 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 245,11/12,70 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 256,54/12,70 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 256,54/55,88 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 388,62/55,88 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 388,62/12,70 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 388,62/67,31 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 388,62/115,57 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 327,66/67,31 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 327,66/115,57 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 316,23/115,57 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 316,23/67,31 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 104,14/7,62  | Durchmesser: 4,00 mm         |  0,12 € Grav.-Recht.| 95,25/85,73  | 101,60 mm x 67,31 mm Dicke: 0,40 mm |  1,18 € Grav.-Recht.| 22,86/85,73  | 35,56 mm x 67,31 mm Dicke: 0,40 mm  |  0,77 € Bohrung   | 8,89/115,57  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 36,83/115,57 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 36,83/55,88  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 8,89/55,88  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 153,67/55,88 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 166,37/90,23 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 191,77/90,23 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 217,17/90,23 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 242,57/90,23 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 267,97/90,23 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 345,44/90,23 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 370,84/90,23 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 269,24/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 294,64/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 320,04/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 345,44/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 370,84/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 191,77/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 166,37/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 134,62/30,54 | Durchmesser: 7,00 mm         |  0,16 € Bohrung   | 13,97/45,72  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 121,92/45,72 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 121,92/16,51 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 13,97/16,51  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Rect. Durch. | 67,95/31,12  | Höhe: 19,05 mm Breite: 82,55 mm   |  0,98 € Bohrung   | 15,24/102,87 | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 15,24/95,25  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 15,24/87,63  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 21,59/77,47  | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 25,40/77,47  | Link                 |  0,33 € Bohrung   | 21,59/69,85  | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 25,40/69,85  | CC                  |  0,27 € Bohrung   | 21,59/62,23  | Durchmesser: 3,00 mm         |  0,10 € Text-Gravur | 25,40/62,23  | Edit                 |  0,37 € Bohrung   | 15,24/77,47  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 15,24/69,85  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 15,24/62,23  | Durchmesser: 4,00 mm         |  0,12 € Bohrung   | 3,81/123,19  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 3,81/3,81   | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 393,70/3,81  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 393,70/123,19 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 198,76/3,81  | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Bohrung   | 198,76/123,19 | Durchmesser: 3,00 mm (mit Senkung)  |  0,56 € Sonstiges  | ------------- | Gravuren mit Farbe auslegen     |  27,74 € Sonstiges  | ------------- | Mehrfarbzuschlag (3 Farben)     |  3,08 € Sonstiges  | ------------- | 2 Werkzeugwechsel          |  1,47 € -------------------------------------------------------------------------------- Summe:                                 131,63 € Menge | 5-9 Stück | 10-19 Stück | 20-29 Stück | ab 30 Stück -------+-----------+-------------+-------------+------------ Rabatt |  10,0%  |  20,0%  |  30,0%  |      Preis | 118,47 € | 105,30 €  |  92,14 €  | auf Anfrage Alle Preise verstehen sich zzgl. der gesetzlichen Mehrwertsteuer und Versandkosten Dieses ist ein freibleibendes Angebot. Änderungen vorbehalten
Abend! Die Verkabelung ist in Ordnung. Habe ich mehrmals geprüft. Meine vermutung ist das der PIC defekt ist. Werde das aber erst in einer Woche prüfen können, da ich das erst bestellen muss. Kann einer bestätigen, das ich den J5 korrekt eingestellt habe. mfg Jack
Midi-Interface bauen, mit mehreren Ein-/Ausgängen
Jack replied to mightymike1978's topic in Deutsch
Wieso JACK? mfg Jack -
Hallo! Ich habe heute mein SID StepB zum Testen aufgebaut und einige probleme festgestellt. Error1: Die LEDs am J5 leuchten nicht, die verkabelung entspricht diesem LINK http://www.ucapps.de/midibox_sid_cs/2x20_enc_multi_w_j5.pdf. Ich habe die "main.asm" und "cs_menu_io_tables.inc" umgestellt, s.unten. Die LED sind richtig rum drinnen. Error2: Bei anschlossenem multiple BankSticks, habe ich das problem das das LCD, manchmal abstürzt. Patch ändern, funktioniert aber. Error3: Wenn man durch die Patches scrolled springt man plötzlich von Bank A auf Bank G. Error4: Manchmal laufen die SIDs nicht mit dem selben Patch. Dann muss man unter CFG beide wieder Syncronisieren. zu Error2-4: SID 12 und LINK aktiviert für Stereo. Kann man den Encoder dazu bringen, noch sauberer zu schalten? PS: Beim SEQ nervt der Bourns Encoder!!! mfg Jack Meine Configuration: MIDIbox 4xSID Control Surface Step B Stromversorgung für SID und Core sind zusammengeschaltet,(Versuchaufbau) 15V 600mA am Labornetzteil. Alle Leitungen sind kurz gehalten. Core (unten) V1.8 J4 gelötet multiple BankSticks 8x 24lc256 (A-H formatiert) J5 gesteckt DOUT (keine Funktion) J9 gelötet DIN J10 gelötet SID J2 J11 gelötet SID Slaves J12 gesteckt MIDI J13 gesteckt MIDI J15 gesteckt 4x20 LCD mit inverter für (Folie) Hintergrundbeleuchtung SID (oben) V1.7A (V1_7_303beta10) 8580 (sehr warm, aber noch berührbar) multiple Bankstick A = midibox_sid_presets_8580 B = midibox_sid_presets_bank2 C-H = leer Benutzter Encoder Bourns PEC11 mit Schaltkontakt und rastent. (von TIM, leider sehr unpräzise) "main.asm" #define CS_MENU_ENC_SPEED_VALUE 15 #define ENABLE_J5 1 "cs_menu_io_tables.inc" CS_MENU_DOUT_TABLE ;; Register and bit SR# Pin#  Description DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 0, 0, 0 ; SID1 LED (Note: Pin #0 is the D7 output of first SR) DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 1, 0, 1 ; SID2 LED DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 2, 0, 2 ; SID3 LED DOUT_ENTRY CS_MENU_SELECTED_SID_FLAGS, 3, 0, 3 ; SID4 LED DOUT_ENTRY CS_MENU_MODE, CS_MENU_MODE_LINK, 0, 4 ; Link LED DOUT_ENTRY CS_MENU_MODE, CS_MENU_MODE_CC, 0, 5 ; CC LED DOUT_ENTRY CS_MENU_MODE, CS_MENU_MODE_EDIT_FLASHED,0, 6 ; Edit LED
Ich habe noch nicht so verstanden, wie das mit CV funktionieren soll. Die Schaltung habe ich umgesetzt. Nur fehlt mir zur Anbindung an meinen SEQ (SHX8), das technische Verständnis. Schliesst man einfach an die AOUT an ? mfg Jack
Ich mal Dir mal ein Vorschlag! ;D Bau Dir einen MB-LC und später ein MB-C4 (gibts noch nicht). Damit deckst Du alles ab was kommen könnte oder noch kommt. Kostet aber einiges. Der Preis hängt davon ab, was Du an extras haben möchtest, z.B. Motorfader, Encoder, LCD, usw.. Du brauchst auch keine 10 Mischpulte, da reicht Dir einer. Vorrausgesetzt, Du hast Reason 3.04. Wenns ein wenig schneller gehen und günstig sein soll, kannste auch die von Behringer nehmen. http://www.behringer.com/BCF2000/index.cfm?lang=GER Ãst ein LC clone, ca. 231€. http://www.behringer.com/BCR2000/index.cfm?lang=GER ist ein C4 clone, ca. 150€. Die haben, aber nur virtuellen LCD. PS: Der Meister, TK, ist im Urlaub! mfg Jack
FPGA based SID 6581. http://www.fpga.nl/jester.html wfg Jack
Hier das Board! Ist aber noch nicht geprüft! Da mir noch die LCD fehlen. http://www.midibox.org/users/jack/8xPCD8544.brd mfg Jack
Habe die Chips bekommen, danke! Zur Platine: Wisst Ihr wie man die, an den Seq über den AIN anschliesst? Bin am grübeln, bis jetzt ohne erfolg. Habe ne platine in Eagle erstellt, nur müssen wir warten bis TK vom Urlaub zurück ist. Die Schaltung habe ich sehr kompakt mit SMD Bauteilen aufgebaut. mfg Jack
It is time to learn VHDL! And develope the first MB_FPGA! For FPGA based Monstersid! wfg Jack
