Dave_Wheeler
    51
Everything posted by Dave_Wheeler
  1. frailn, you are a super-star and deserve a nice badge :-) That was exactly the page I was trying to find Thanks Again Dave MB-6582_PK.zip
  2. Thanks guys, It was Fuzzy's pictures that I had seen but I'm sure they were all together on not in a number of posts. Cheers Dave
  3. Guys, Some time ago I saw a walk-trough for the control surface which included loads of pictures and useful comments, I do remember that the 'wife' done the JB Weld using a piping method. Well I blame it on old age (it's my excuse and I'm sticking to it :-)) but I can't find it again, I have searched and searched to no avail :-( Anyone have any ideas ??? Thanks Dave
  4. Thanks Julianf Be very keen to see the panel once it comes off the machine, all those holes are going to take some time !! Price seems good, much better than Schaefer but like you say only one colour fill (or natural I guess) Cheers Dave
  5. Hi Julianf, Great work :-) Have you calculated appox costs based on Wilba's original layouts ?? Thanks Dave
  6. Hi ssp, Yes RS can get them but it was the "Orders for Extended Range items with a total value of less than £100 are subject to a shipping & handling charge of £10" clause that bumps the price up !! If I buy 2 they come in at about £20 so if no one has any 'spare' that will be the way forward :-) Thanks Dave
  7. Guys, I guess there must be someone in the UK that has a spare PT-10 :) RS want £12.xx plus a tenner plus VAT so ends up about £25 delivered If anyone has one (or two) either in the UK or that can be shipped to UK for less than £25 I would be very interested. TIA Dave
  8. LOL :) :) :) :) :) :) :) :P
  9. Cheers SLP, That address is used for all sorts and has a 'very' aggressive spam filter which runs server side Thanks Anyway Dave
  10. Hi Unit-Sound, I could certainly use it. Sequencer is the next project here :-) I'm in the UK so I guess the postage would be more but that is not a problem. By all means PM me or email me directly at: g0gmk@btinternet.com TIA Dave
  11. To be fair to RM, it does cost them quite a lot to process duty and VAT, it just sucks when you have to pay it :-) The only time I had problems with duty was something from Norway that was sent to me to repair, as it was not staying in the UK it was not eligable for duty but DHL took some persuading !!! This is going way off topic so probably best I stop my ranting Cheers Dave
  12. Thanks guys, As mine is NOT going in a PT10 and I'm only using 4 SID's and I 'might' do some stuff at audio level I think I will just layout a board. My existing single SID is on Veroboard :-) Size is not too much of and issue and although I admire the work done by Wilba and Smash I can probably do my board(s) for a similar cost but more importantly to suit my exact requirements. Good luck with your build and post some nice piccies when done :-) Cheers Dave
  13. Hi Toneburst, Nice to see you back :) I am undecided whether to lay out a new board or go for the boards from Smash, you mentioned customs / Duties. Did the Post Office go the full hog ?? (Duty, VAT, collection fee) If so (and you don't mind telling me) how much 'extra' did they cost ?? Cheers Dave
  14. Hi TK, Thanks mine arrived last week but I was away. Looks like my list of Xmas projects is getting bigger every day :) Cheers Dave
  15. Dont forget that the UK price is + VAT @ 17.5% and is from the extended range which means: Quote: * This item is from our Extended Range * Orders for Extended Range items with a total value of less than £100 are subject to a shipping & handling charge of £10 * Please allow extra time for delivery * These items will be invoiced separately under a different order reference * Extended Range items are only available online cheers Dave
  16. Hi Frank, Does the 11Euros include postage ? If not, any idea on the postage cost to UK Thanks, Danke Dave
  17. Thanks Frank, Mine arrived this morning Very well packaged, even the English post office could not manage to crush the box :) :) Dave
  18. Hi Frank, PM sent Thanks, Dave
  19. Hi Frank, Do you know if the cost will be similar ~60EUR inc shipping etc ?? If so, count me in for 100 please Thanks, Dave
  20. Hi Julian, Well done for getting so far. The first test I would do is the documented test with just an LED and a series resistor. This will certainly show if there is a polarity issue (DIN socket connections) or if there is actually a MIDI signal getting to the board. What is the exact Opto Coupler you have used ? Good Luck Dave
  21. Some I like, some not sure :) The link to Hip to be Square is wrong but got there manually Cheers Dave
  22. Hi, For which particular project ?? The 877 has not been used in anything for about the last 4 years. The original Midibox was 877 based and I think the MidiMon can still use it Cheers Dave
  23. Have you confirmed the LED's are connected correctly as they are polarized. The Anode MUST be positive and the Cathode at about 0V. A quick test can be made with a spare LED 5V-----------560R--------(A)LED©-----------0V The resistor can probably be as low as 180R (based on 20mA and FV of 2.0) but to test a 560 is good On most (all ?) LED's the 'flat' on the LED body is the cathode and the long lead is the Anode. Dave
  24. OK, If the Opto has a dot, then that is pin 1 (some has a chamfered side). Inside the opto is basically an LED and a light controlled transistor junction so if the external LED flashes, so should the internal one. The test setup uses a current limited supply (through the 220r resistor) to test the opto so at this stage Midi is not part of the setup. There are sometimes some minor differences between manufacturers but the 6n138 is a standard opto so you should not see any difference in this application. The logic low voltage is listed as 0.1V but there is a maximum of 0.4V. As your tests show 1.5-1.7 I would guess that the pullup is too low a value, try a 10K instead Dave
