23 -
Everything posted by Rene
OK, I have no skills as a programmer. No ledbars.... :'(
Referring to this: So, it is possible to change the motorfaders with encoders? If you use the encoders with a sort of belt and the 'ledring' leds in a straight line next to to the belt for position indicator, then you have no need for MF-ers? Correct me if I'm wrong.
OK, I understand.
It's only an idea, because I don't know anything about programming the PIC. Thorsten has give up the idea of USB to MIDI, but is it maybe possible to use the USB port in that PIC for a memorystick? Then you have more space then the bankstick? René
Maybe an idea to make a subforum for user to selling their boxes to other users, with no profit of course.
Ah, I shell read it, but my German is terrible. ;D
Correct me if I'm wrong, but is the 18F4550 the same as 18F452? I'm meaning, with the 452 you need a midi port, and for the 4550 an usb port? So if you use the 4550, you don't need midiports anymore? René
On the moment that I've downloaded it, I have Java 1.4.2 or something, now I have Java 1.5 and when I download it again,again it's a zip. I don't think it's a problem, rename the file and all's well.
Hello, you forget to say that if it's downloaded you must rename it to *.jar. Because when I've downloaded it, it's a zip file. René
OK, I live in Holland and had the same problem, so I found out that Conrad Germany sells them under number:442081-07. I ask Conrad Netherlands, and thet can sell them to, so... ask Conrad UK and maby they can to. Go to www.conrad.com and choose the uk. I hope it helps. René
Op mijn vraag aan Conrad Nederland of ze de motorfaders in Nederland verkopen kreeg ik het volgende antwoord, het gaat dus om artikelnr.: 442081-07 de ALPS motorfader met TS =========================== In antwoord op uw mail kan ik u mededelen dat wij dit artikel ook verkopen en deze 22.95 euro kost incl. BTW en excl.verzendkosten. Vertrouwende u hiermee voldoende geïnformeerd te hebben Met vriendelijke groet, Anita Hassink Conrad Electronic Nederland BV ================================== Dus, we gaan echt de goede kant op? Doe er uw voordeel mee.............
Het probleem met niet TS faders is dat de spanning niet van de motor afgaat als je hem aanraakt wat met TS wel gebeurd, nu kan je dit oplossen met een button, maar dat vind ik persoonlijk geen mooie oplossing. Maar ik zag net op ucapps dat ze de alps faders verkopen bij conrad duitsland onder nummer 442081-07, als jer meer dan 10 besteld zijn ze € 20,95 , we komen dus al in de buurt.
Ik wil wel, maar ik zit er dus tegenaan te hikken dat er nergens, zeker niet in Nederland, betaalbare touchsensetive motorfaders zijn, zonder touch trouwens ook niet.
The Hague, Netherlands, connection 1500 Cable. Download 196Kb/s Forum as lightning. 8) It works fine.
Well, because sawing gives a lot of dust I use a knife. (Stanley or somelike) It takes several strikes to cut, say it, halfway, and then you can break it, a little sandpaper to make the edges smooth. René
Heeft er ooit iemand in Nederland betaalbare motorfaders gevonden, en zo ja, WAAR? Het liefst ook in Nederland te koop.
The idea is good to change the panasonic, BUT what does the touch switch? Is it detect the position, the movement, or whatever. What I mean is, is the switch closed when you touch the fader whatever the position is? René ( Never mind, I found the answer here http://www.midibox.org/cgi-bin/yabb/YaBB.cgi?board=parts_q;action=display;num=1079521748 )
Mayby a synth module or keyboard with flop or memorycard will do? René
Sorry. :-[ René
Redesigned MIDIbox of the Year (3xMIDIbox LC of Axel)
Rene replied to TK.'s topic in MIDIbox of the Week
Thanks for the quick reply, so IF I build something AND I will use it with Cubase (or Sonar?) as a Mackie or LogicControl THEN I must use for evey core a midi port. For the moment something to think about, if I have more questions or I'm stuck, I ask again. Thanks again. René -
If you use more than 1 core, say 3, is it than possible to use for every core a midi i/o? Less latency maybe? René
Hello Axel, You put in a midisport, so is this that you use for every core mudule a midi port, or is the chain of cores connected to 1 midi i/o? Is it even possible to use 1 midi i/o for each core? Less latency? René -
I've seen this unit and I must say, "VERY GOOD JOB". I think it's now possible to use somthing else then the Digidesign consoles, this one is more beautiful then the Digi. SO, if it's possible can you mail or post the schematic (block) of the unit?
