1,468 -
Everything posted by pay_c
Yes! That are good news!!
Fusion Electro Metal Indus ? ? ? Hmmmmm..... Cool, cant wait for the MP3s ... SID live!!!
It wouldn´t be to hard to increase the voltage to a certain amount (just using an OPAmp). But the question is, if the latency is low enough. The Photodiodes in the Roland Synthies (I owned one once - sold it) are quite slow - just hope thats because of the firmware. Would be a cool advancement for MBHP!! :D
Also everytime good for LCDs (and Pots and Switches): Ebay ;D
There are enough examples and finished programms in the MIOS download area.
That little 2mm nipple under the shaft: Can you remove it? Plastic or metall? Thnx btw! ;)
Yeah, you can change all CCs. Although I really dont know how to programm this. But there should be enough examples. At last: Good luck! :D
;D Yepp, MIOS is cool... You understood everything just fine. With Serges VMidibox the editing, which pot is sending which CC is just very comfortable. But anyhow, if you seldomly will change the CC values, MIOS is very fine. You can even upgrade your stuff later on and use a bankstick for different setups. But in the moment you just have to send the different CC Configs via Sysex, and thats a little uncomfortable. But I´m sure there will be more stuff for that in some time. With MIOS you could also programm a second layer of all your pots and so on and just switch to it with a shift button. Just read about the LC Clone if you want to know more about that. Regards.
Hmm, also sorry, aber: Check einfach nochmal alles durch. Eigentlich sollte der Multiplexer (wenn er richtig an der Core dran ist) den bewegten Poti öfters abfragen, also auch eine Spannung abfragen. Trotzdem: Die volle Spannung wird natürlich nicht anliegen (es wird immer abgetastet). Am LCD ist dann auch nix, oder? Mal ein einfacher Test für die anderen Multiplexer (mit einem LCD): Einfach die Masseleitungen abziehen und mal mit dem Finger draufgehen. Ist zwar fies, aber mach ich öfters so. Auch die Leitungen zum Pic kann man so mal kurz checken. Wenn du da mit dem Finger draufgehst, sollte am LCD so einiges abgehen (bist ja eine wandelnde 50 Hz Antenne...). Wenn die anderen Eingänge funzen, den Poti mal da dran und evtl. den IC austauschen. Ansonsten: Die Schaltung durchchecken, speziell die Verbindungen zur Core und die einzelnen IC-Spannungen (fast immer der untere linke und obere rechte Pin).
If you want to do that, you would have to use MIOS. There you can assign every single DIN Pin to a certain event (e.g. Encoder or Button like you said). The same is for that Encoder&Fader thing: Only with MIOS. The "normal" MB64 Firmware is based on pots. If you would just connect the Encoders to the DINs, the PIC would think youre pushing buttons all along. If you want to have several setups (and so perhaps using Serges VMidibox), you should stick to the normal pots. But if you really want to mix that stuff, go up to MIOS, its fun programming that stuff (and not hard anyhow).
Aaaalso: Was alles jetzt sein kann, weißt du ja. VIEL. Ich würde erstmal ausmessen, ob an dem IC-Pin auch eine entsprechende Spannung anliegt (also 0-5V irgendwo dazwischen, je nach Potistellung). Wenn was anliegt, gut. Hast du einen LCD mit dran? Der müsste den bewegten Poti nämlich gleich anzeigen, ist sicherer als über MIDI erstmal. Wenn er da nämlich angezeigt wird, stimmt die MIDI-Vbdg nicht. Wenn du keinen LCD hast, hol dir lieber einen zum Rumprobieren, die Dinger kann man öfters mal gebrauchen. Erstmal die beiden Sachen und dann weiterschauen.
Hey, TK: Is there something like a Pan Control planned for the single SIDs? Something digital? If not, I will build some additional analog pots in there to control the pan of every SID (since this is not much additional work). Then I just cant save those settings. And something like a Pan controlled by a LFO or so is always great (especially with 4 SIDs ;D).
Hi there? Has anybody some datasheet or at least the measurements of those ALPS Encoders? ALPS STEC16B03 to be exact... Thnx in advance
For that startup phase: Hehe..... Â "SID rulez" scrolling on those 56 LEDs or what? Â ;D
;D ;D ;D *sorry*, aber den konnt ich mir nicht verkneifen... ;D :-X ;D
:o :o Echt? Boah.... nich schlecht... Dann hätt ich nen kleinen Tip: Statt einem normalen Netzgerät, schnapp dir einen alten Comp (egal wie alt) und bau dir das Netzgerät (Schaltnetzteil!!) da aus. Die haben meistens mind. 200W. Nach Umbauten von diesen Netzgeräten kannst du auch googlen, da gibts mehr als genug. Dann kommst du locker über die 5A Schallgrenze.
Yes, but anyhow TK, he could just built the whole thing (the 4xSID) and just ignore the 3rd and 4th SID. -> 2xSID, you just need 2 Cores and two SIDs. For the Bankstick swapping just look at ucapps.de and here in the forum. There are more than enough solutions (multiple switch, two buttons hardware, and MIOS two buttons software).
Oh, I get it. I only used the 18Fs. OK, thnx again TK, hope I´ll get some good sound! :)
:o Nojo: Die beiden LCDs zusammen 200-600 mA (Hintergrundbeleuchtung). Die sieben Cores so um die 200-300 mA (etwas weniger als oben, da sich fünf "nur" um die MFs kümmern müssen). Die Motorfader werden schon EINIGES schlucken, glaub ich... sorry, mehr weiß ich auch nicht... Ich würde mal im offenen (nicht deutschen) Forum fragen, da haben mehrere schon Sachen mit MFs gemacht.
Witzbold... Pass mal auf: HIER BESSERES ANGEBOT: 3 C64, Netzteil, Diskettenlaufwerk, Datasette und Bücher! ;D Nee, echt jetzt: Ich glaub, hier ist der letzte Platz, wo du das loskriegst. Probiers mal auf Ebay, und sag einfach, das der Sound komischerweise nicht mehr funzt. ;)
Hmmm, could be... It´s in a row with a Virus B. The Out of Cubase goes into the Mon and then (thru port) into the virus. I´m sending MTC with Cubase. Perhaps I´m sending some weird stuff... really dont know. I´ll try to plug it somewhere else. But anyhow, thats not so important, I just wanted to have an MTC Display, and I got it. ;D ;)
Would be cool, if you could send me those .syx files. Perhaps you could also post them on ucapps.de. Or perhaps just the .syx files (MIOS) of the first four IDs (cause of the SID - more people will need that...). Am I the only one with this problem? I mean, other people are building the 4xSID, too, aren´t they? So why didn´t I hear anything from them? Weird... Stupid question: Is it really neccesary to count those IDs up? (Do think so though...) Anyway: Thnx !! /edit: Just sent you my email
Wenns nur um das *allgemeine* Löten geht, lad dir mal das Tutorial von Heico runter (auf der HP Hauptseite ganz unten in den News). Da sind nette Videos mit drin. Eine richtige DIY-Anleitung gibts hier kaum. Wäre ziemlich viel Arbeit. Aber die Platinen aufzubauen sollte trotzdem kein Problem darstellen. Wie immer halt: Erst Drähte und Wiederstände und Fassungen, dann die Halbleiter und die empfindlichen Teile und zum Schluß die ICs in die Sockel rein. Die Reihenfolge ist aber im Allgemeinen nicht sooooo kritisch. /edit: Die Bestückung kann man sich ja auf ucapps.de zu jeder Platine downloaden.
Öhm, was meinst du mit Midicores? Meinst du die MBHP Core Platine? Wenn ja mit oder ohne LCD? ohne LCD: ca. 35-50 mA mit LCD: 100-300mA (je nach Hintergrundbeleuchtung) MF kA, sorry Insgesamt reicht ein 1A Netzteil allerdings locker aus, der 7805 hält sowieso nicht mehr aus.
Hey TK, again because of that Analog IN: Tried it on the second SID I built. Still the same: Really not very loud. Hardly hear it. ... ... Whats up? I dont get it...
