Nomical
    207
Everything posted by Nomical
  1. I only have it in PDF format. Is that any good? Since i'm new to this, in what way could the digital sysex implementation help me? Simply cut & paste the stuff in MPLAB?
  2. I didn't notice any change in speed of loading parts of the forum.
  3. Well, your frontpanel certainly looks nice! One question though. Do you really need the LEDrings? It's going to be a lot of work soldering these. And i think you don't actually need them, since you are going to use encoders and a display. So any entered value will be displayed on the LCD and the encoders initiate an increment or decrement on any value. Just build/change the MIOS application code in such a way that if you press a button or move an encoder, the value change will immediately be displayed on the LCD. Or are you going to use it in a different manner?
  4. I use Opera instead of IE. Although some pages are not displayed correctly, i can really recommend Opera to anyone. It's really a user friendly browser that's far more customisable than IE. Integrated email if you want to. Skin support. The reason that some pages aren't displayed correctly is that most pages are optimized for IE. But sometimes even other pages aren't correctly displayed when using IE. So I just use Opera and once in a while i use IE for the sites that demand it.
  5. Hi Cem3340, I'm developing my DB50Xg interface in such a way that i can switch between XG Mode en TB300B mode (which is the QS300 Mode). Maybe even an GS Mode. But it will be the last addition to the design and code, since i'm already getting the idea that the massive menu structure for the XG Mode LCD menu that i want to build is going to need a second core, just for the menu! I don't know if you've taken a look at the DB50XG manual, but it's going to take me quite some time to implement all sysex for controlling all functions from the LCD menu. Because i'm a newbie to (mios) programming... ;D Also, to decide what has to be on the frontplate for controls is kinda hard without the hardware finished yet and me deciding what's too much and what's to less for the interface.
  6. And it seems that TK has left for another vacation. Good for him!! I hope for him he's somewhere on a beach in the sun..
  7. Nomical
    mike's sjop
    Ik heb nodig: 1 x CORE 2 x DIN 1 x DOUT 1 x LTC 1 x JDM Nieuwste versies en pertinax, maar volgens mij kan je al best een tijd geen epoxy meer kiezen. Zal ik het geld langs komen brengen? Zo ja, mail ff je adres.
  8. Nomical
    mike's sjop
  9. Nomical
    mike's sjop
    Hoe lang duurt het voordat die internationale overschrijvingskaarten binnen zijn? Sorry hoor, maar is het misschien alsnog niet handiger als iemand de bestelling op zich neemt die al van die overschrijvingskaarten heeft...... ;D Anders moeten we nog langer wachten totdat ik die kaarten binnen heb. Eigenlijk wil ik gewoon gaan solderen en niet al te lang wachten.... ;D En er zijn er meer die zo snel mogelijk willen bestellen. CHE = Carel??? (ik zag je volgens mij laatst nog op het station lopen met je vriendin)
  10. Nomical
    mike's sjop
  11. Nomical
    mike's sjop
    Ok OK, Het forum was down.... Ik ga binnen een week alle pcb's bestellen. Iedereen die mee wil bestellen moet maar emailen naar me met zn bestelling, als ie wilt dat ik het samen met mijn bestelling doe. Gaan we geld overmaken of opsturen? Overmaken maar toch? Is nu toch gratis als het goed is? Weet iemand of je kan betalen via de postbank of is het het beste om het via ABN ed te doen? Ik was laatst namelijk bij de Postbank en ik kreeg de melding dat er vanuit een postbank kantoor geen overschrijving naar het buitenland gemaakt kan worden. Dit kan alleen maar met internationale overschrijvingskaarten die ik (nog) niet heb. Ff een duidelijk plan maken, ook hoe de pcb's naar iedereen verstuurd worden of dat ze opgehaald worden bij mij.......
  12. Nomical
    mike's sjop
  13. I was getting scared....
  14. Woh, that looks really nice!! Good job Thorsten!!! You were doing a little dance around your working spot when you finished this, weren't you? ;D
  15. Well ok, you really have some good points there. But the only thing i meant was the fact that there are going to be people how are gonna take these ideas and are going to make a lot of money out of it. You and me don't want it, Thorsten sure as hell doesn't. That's just the way this twisted world sometimes works. But i understood what you meant. Also, it seems that Thorstens ideas have their own reputation which seems to attract people! ;D
  16. I'm currently working out how to let the encoders interact with the display. Not the code, but the manner in which it works that is. I've got a question about those functions that i want to control with sysex. If i assign a certain encoder to a function that has to be controlled by sysex, wil i hear the change in value when i turn the encoder? Or do i have to push on a enter/execute button after entering the value ,with an encoder, that has to be send via sysex? In other words, does my application (or MIOS) send out continious sysex messages while u turn a encoder in a way that i can hear the change? Second question. The SID has only one part, right? It wil only get multitimbral when you add more SID's into the design, right? My DB50XG has sixteen parts that are normally controlled by each corresponding midi channel. There's also the ability to assign a certain midi channel to a certain part. I was thinking about building the MIOS aplication in such a way that i can control all 16 channels from the box. I would build the interface for one part in the beginning and when optimised and finished i would use this as a template for the other 15 channels. This would be an ok way of working, right? Or should i build it with all 16 parts in mind and just add a function which acts just before the sysex command which will add an indication for what midi channel that particular sysex command is meant? I'm actually getting the idea that i'm going to have to use more than one core for the way i want to interact between encoders/buttons and the display. This stuff is hard!! And i haven't even begon to try and write the code for it.
  17. I totally agree with Xcen!!
  18. Just remember that making it more known to people also means that there's going to be more people that take advantage of these projects for their own commercial projects!! Would be a shame!
  19. Are you really a machine instead of human? Tk works so fast (and types fast too)!! ;D
  20. Nomical
    Encoder
    Is er ondertussen al bij iemand een adres bekend waar je goedkoop encoders kan bestellen? En welke merken + types zijn nu het best of meest geschikt?
  21. Nomical
    mike's sjop
    Nee, laat maar zitten. Ik doe Reichelt zelf wel merk ik ;D
  22. Nomical
    mike's sjop
  23. Breda, the Netherlands
  24. Nomical
    mike's sjop
    Email adres is ok, maar ik heb er ook een die ik vaker gebruik. Op forums doe ik namelijk geen hoofdemail adres invullen, omdat er van die f*ckers zijn die forums afscannen op emailadressen en je dan vervolgens gaan spammen. Als je iets naam mijn mail stuurt, dan reply ik wel met mn hoofd emailadres. Ik heb ff gekeken op circuitsonline, maar die thread is veel te lang zeg! Kan je niet in één zin samenvatten wat de conclusie is? Op zich een goed idee van dat overnemen, aangezien ik waarschijnlijk vanaf morgen weer werkeloos ben. >:( Ik kan sowieso mn eigen bestelling wel betalen en misschien nog wel een tweede ook. Ik mail je wel ff met wat meer info zodra ik meer tijd heb. Druk, druk , druk....
  25. Nomical
    mike's sjop
