Wise
113 -
Everything posted by Wise
Hi WW ! I have not got the time to work on my controller nor this code from last post in this thread (shame on me..). But I have now taken me time to start working on the project again. Right now I'm redesigning the front layout for traktor 3 new functionality. I will see if i got some time this weekend to try this code on Traktor 3 and see if i can get it to work. Anyone else ? I'll keep you informed. /Wise edit: I'll think this thread should be moved to the C section..
Just order some samples från Texas ;D With this line driver you could use a separate PSU at the DOUT/triac boards, just be sure to connect the GND of that psu and gnd of the core together. And be sure you use TP-cable for the data lines. Found some interesting documents, it's for rs485, bat it's similar tp 422: http://www.embeddedsys.com/subpages/resources/images/documents/microsys_art_RS485.pdf http://www.national.com/an/AN/AN-847.pdf Keep us informed about your progress /Wise
Sweet, then it sounds doable. I'll sleep on this one :) /Wise
I'm sure that with a differential line driver like a RS422 driver you could get way longer than 100' without corrupting data. Just my first thougts. Check out this chip: http://focus.ti.com/lit/ds/symlink/sn65lbc179.pdf Up to 10Mbps, how fast is the DOUT,DIN chians scanned ? 3 pairs of these should work. Plus gnd and +5v. Could be an idea to a new "extend module" ;D wouldnt work with AINs, just for DIN and DOUT.... /Wise
Ok, låter oroväckande Har du kollat dessa trådar?: http://www.midibox.org/forum/index.php?topic=3980.0 http://www.midibox.org/forum/index.php?topic=3299.0 Har själv bara lite erfarenhet av ALPS encodrar från elfa på labnivå, men har nog inte upplevt några problem vad jag kan minnas
Hejsan Har nu skrotat mina långsamma planer på en T2-box till fördel för Traktor3. Så nu är jag på jakt efter encoders. Kollade på SmashTV's hemsida och hittade bourns typen med klick för ett vettigt pris. Men innan jag beställer skulle ja vilja "känna & klämma" på en, gärna en som är modifierad till klicklös. Ingen som har en sådan i närheten av Gävle eller Hudiksvall ? Eller om någon längre ifrån skulle kunna skicka en (givetvis mot betalning), vore guld ! Tacksam för svar /Henrik
Härligt ! Väntar på lite material från dig då :) Själv har jag kasserat mitt Traktor2 projekt vid 75%.. För att börja med nya T3. Gigantiskt...ujuj, läre ju ta ett par år...(med min takt)
Har själv ingen SID, så där kan jag inte hjälpa dig. Men du får in MIDI kommandon till datorn ? Om du testar ladda upp ett av testprogramen från ucapps ? /Henrik
Been there, done that... And it realy hurts when the anaesthetic??? goes away from the eye.. :o :o
This is somewhat what I'm aiming for : http://www.gavle.to/~henrik.m/traktor.jpg. The design is not finished...and no time to work on it either.... /Wise
Oh my ! This is a just so cool ! ;D ;D ;D What about some kind of "butkicker" ??? installation in this "midibox", could be controlled and amplified from an aout ;) And yeah, I have the exact same sofa, the best sofa ever to rest or sleep in ;D
Sweeeeet ;D ;D ;D Just have to find some time to code now... /W
Hey ! I don't know where they can ship outside Sweden. But I sent a mail to them now and asked. You'r in Portugal, right ? I'm about to order from them myself in the days now, I could buy some center detend 10k lin pot's (VRB-101M10) and send you one private so you can get a feeling of them. Just have to check the shipping and payment, sounds interesting ?, pm or mail me ! /Wise
Great  :) ! /Wise
I don't have a SID module, but from looking on the schematic i asume there is a break in the pcb track. If the voltage out of the receiver is OK, and on the same track closer to C6 is 0V, that indicates a broken track. If the cap is shorten it shouldnt be any voltage out of the bridge.. /Wise
Yes, it's possible to have buttons and encoders on the same DIN. /Wise
I know a store here in Sweden, http://www.trimlog.se Prices in SEK ... Look under: Elektronikkomponenter/Potentiometrar/Potentiometrar - 6mm 18-srårs axel Then the pots marked with "centrumklick" at the bottom of the page. Realy good feeling in those ! Going to be my pot choise for avTraktor box. Bye, Wise
Any dual rail-to-rail OP should do the job. Since high bandwith, CMRR, max gain, offset etc is not a issue for you i think anyone is good enough. If you want to use the op for a gain of 1, it should be marked something as : "stable downto a gain of 1", but I don't think this is a problem in this case. TS1852IN , dual rail to rail OPA337, single op, rail to rail, stable downto gain 1 just some examples... /Wise
I know the smal traces, it's just a first draft. By the way the upper two (so as the lower two) pinns of the switch is internaly connected. I'll try moving the CONN's around a little to get bigger groundarea to the bottom left switches. Bye for now /Wise
I'm about to design and etch PCB's to mount leds and switches to under the frontpanel. It's kind of a modular pcb with two rows of 4 buttons + LED's. I want to be able to mount the board in any direction, means 0 degrees or 90 deg. So there are 2 LED's for each switch (in parallell). You get the point by this picture: First version: To ease up the design and reducing jumpers on the board I have connected the LED's gnd (DOUT) and switches gnd (DIN) together on the PCB. I know this creates a groundloop if I connect the groundpins to both dout and din boards, but should this be a problem ? Or should i just connect it to one ground ? Maybe I have to split it into two boards, one vertical and one horizontal, to be on the safe side ? ??? What are you'r thoughts about this ? /Wise
I know that MIOS doesen't read the resistance. But Bosone said that the joy-pot was rated 10k, but the maximum reading(at middle pin) was 4-5kohm. This is half the range of 10k, thus just 5/2 = 2.5V maximum. Range 0-2.5V at the slider (the pot will not go mecanicly from 2.5-5V). Or is it something i'm missing here ? Regards Wise
I have looked around for a ready-made-case, but with no luck finding one that will fit my panel. And I don't want to redesign the panel. And well.. Is it DIY it is DIYÂ ;) Still have'nt found a good sollution for the power connector. Thx Tl for the neutrik powercon, good, but not perfect. To big and uggly to stick up from the panel i think.. /wise
One way to make this if it's just a couple of pots is to take a rail-to-rail OP amp and set it up as a non-inverting amp with a gain of 2. And maybe a trimpot to trim the gain. This way you don't have to take care of the scaling in mios. Just a thought. MIOS AIN is 10 bit => 1024 steps full range. And your range is 0 to lets say 2.5 V => 1024/2 = 512 steps. Then to scale, just devide with 4 (not exactly, but maybe enough?) So: 1: Take the 10Bit value from AIN (MIOS has a function called MIOS_AIN_10BitGet or something similar) 2: Just rightshift 2 times, this equals a devision with 4 (correct me if i'm wrong) 3: Then you have your aprox 7bit value ;D /Wise
Skulle gärna bränna dina PIC'ar om jag hade möjlighet. Lyckades bränna min bootloader på högskolan jag för ett bra tag sedan, men den utrustningen har jag inte tillgång till mera. Och på jobbet kör vi med Atmel MCU....Men om du ska beställa kort så kankse det är lika bra att beställa ett programmeringskort oxå. Annars finns det säkerligen någon annan här på forumet som kan hjälpa dig. Stigmata tror jag är från Sverige och har byggt några SID boxar om jag kommer ihåg rätt, kanske han är villig att hjälpa om han har möjlighet. /Wise
Potentiometer: En potentiometer är en variabel analog resistor. Sån som sitter på alla stereoapparater typ. Den kan man bara vrida ett vissst antal grader, normalt ca 300 grader. Så finns det precisionspotentiometrar, flervarviga, uppåt 20 varv. Men dessa är tämligen oanvändbara i midibox byggen. För midiboxändamål bör potentiometrarna vara märkta med 10K (ohm) linjär. Med 10K menas att hela resistansbanan i potten är 10kohm, vilket är lämpligt för dessa byggen. Får man inte tag på 10K pottar så går det med andra värden oxå, men man ska vara medveten om att tar man ett mindre värde så drar det mer ström, och det vill man inte gärna. Tar man ett större värde så är risken för "jitter", störningar högre, vilket medför fladdrande värden hela tiden. Med linjär menas att resistansen ändras linjärt över hela vridområdet, vilket är önskvärt i midibox sammanhang. Det finns logaritmiska potentiometrar oxå (isf linjära), men de ska du akta dig för. I dessa ändras resistansen logaritmiskt under vridandet. Detta är mer till för audiosammanhang då man upplever tex en volym logaritmiskt. Nog om potentiometrar nu. Encoders: En encoder är en digital komponent som mycket liknar en potentiometer i utseendet. Men den skilljer sig vesäntligt. Finns i uvudsak två olika typer: non-detent och detent. Detent encoders är det "klick" i när man vrider, distinkta lägen, ungefär som på de flesta scrollhjul på möss. Non-detent har således inga "klick". Mycket förenklat kan man säga att innuti encodern sitter det två knappar. När du vrider på axeln så trycks knapparna ner, först den ena sen lite efter den andra sen den första, andra etc. Vrider du åt andra hållet trycks först den andra ner, sen den första, sen andra etc. Detta genererar två pulståg som är fasförskjutna sinsemellan. Dessa pulståg kopplas in på två ingångar på ett DIN kort. Sen sköter programmvaran i PIC'en resten, känner av vilket håll du vrider. Den räknar oxå ut vilket värde som du vridit encodern till, beroende på håll och antal pulser. Man kan således "emulera" en potentiometer med en encoder. Encoders kan man vrida runt runt runt, precis som ett scrollhjul. Potentiometrar och encoders har sina för och nackdelar. Med en potentiomerer får man en mer visuell bild/känsla av hur mycket man vridit den. Man kan ju ha en ratt med en pil och en skala. Det kan man inte med en encoder då man inte vet riktigt hur programvaran räknat ut värdet/läget på motsvarande skala. Dock har encoders den stora fördelen att om man byter funktion på den i programmvaran under körning, så behöver man ju inte vrida tillbaka den till "nolläget" som man behöver med en potentiometer, det sköter programmet automatiskt. Till en SID eller FM ska du nog helst använda encoders (har dock ingen erfarenhet av SID/FM själv, bara det jag läst på forumet). Själv ska jag använda potentiometrar till min Traktor Mixer box, vill ha en mer visuell bild av värden med skalor och så. dessa från trimlog är riktigt sköna potentiometrar: http://www.trimlog.se/butik/viewproduct.asp?artnr=VRB-100M10 Ska använda ett par encoders för att bläddra i menyer, playlists etc, från elfa: http://www.elfa.se/elfa-bin/dyndok.pl?dok=2030.htm , Har dock lite problem med dem, men de känns bra när man vrider på dem. Men jag tror Smash har encoders på sin site, eller om det var Mike. De ska nog fungera utmärkt, men kolla med någon annan än mig innan du beställer....... Hoppas inte jag babblat strunt nu bara och du blev lite klokare på det här. Vart håller ni hus i sverige eg ? själv bor jag i Gävle. /Henrik
