moebius
1,199 -
Everything posted by moebius
Nice to see there´s some "proof of the concept" code! Keep up the nice hype, Stryd!! Moebius
Uh, I just searched the subject in this very forum. Found some info. No schematics, thought. Moebius
Newbie here... going for a simple, monophonic MBSID (photoblog)
moebius replied to swoki's topic in MIDIbox SID
Hi ya! Sorry for me bad enklish. Solder taps are the spots to solder on.. Usually round and with hole in the center :D I´m sorry, I´ve made a board with previous layout and the legs for the rectifier needed bigger drill. There wasn´t much space to solder there. Cap Ys are for life.. Plain and Simple; "How Do You Do" :D I hope You´ll get the Braid.. :D Moebius p.s. You are doing fine! -
vX. It´s been referred to. Many times. No code seen. It might even be ready. Sometime. Hi. He. I´m so sick. I have some much work. I have a flue. He he hee! Well, vaporware it is.
Monome clones. If Monome was lame, Midiboxers clonin´it was probably even more lame? "Hey, Midibox Lemur - Just if I pay ya?" Moebius
This is where You tell who did and what didn´t happen. TK just DID IT - Get it?
Why should You get any cover for SL1200´s? No laptop hurts those. Moebius
Well, I´d rather try Dynebolic. As always, they offered a Live-CD, but I didn´t find Live anywhere. It´s like Midibox. You can´t find vx even if You wanted to. Only references. Moebius
Welcome! If You don´t have a desoldering pump - I´d rather say, get a solder wick (braid) instead. The work You have done is excellent, don´t let people destroy what You´re doing. Didn´t Your board have a proper solder tap? Moewbius -
You can be the beta tester! 2-3, Just check the datasheet out. I don´t know. 4 x SOIC OpAmps don´t cost that much space. Moebius
Possible SHX8 CV Multiplexer solution - Transconductance Amplifiers..
moebius replied to Artesia's topic in Design Concepts
Hi, "With digital control, to address the drift" - It´s a nice definition! Moebius p.s. TK, please save me - what is the update frequency of the current S&H code? -
Hi, There are no "static signals" - S&H is constantly updated with current voltage in the DAC output. NJU7304 was pretty good at droop rate of 1mV/5ms. Of course "low leakege" is needed, but I can´t see reason to use OTA (with hold cap and buffer OpAmp) as analog switches already have MegaOhm off state, so it´s more up to the cap and switching rate to hold the voltage. Moebius -
Hi, Using OTAs isn´t an elegant or Cost Effective solution. It´s too bad those NJDs are obsolete. (other available S&H chips I´ve found really aren´t up to the job) I still think using 4051 multiplexers with a hold cap and buffering OpAmps would be easiest way to go. It´s a cheap solution, but uses pretty much board space. Moebius -
I just tried: perl vx and it doesn´t exist! I feel stupid, I´ve used perl before.. even perl vx.pl didn´t work! Is it the path problem? Moebius
All the encoders I´ve seen are PCB mount. Moebius p.s. You can use wires and attach the encoder to the frontpanel
Hi all, cheater I think the INL error we are concerned about is a static (known) scale error between MIN-MAX values of the dac. (In other words, cheater you are fighting against wrong problem here.) Moebius
Yes we do, but at least I´m too tired to "search the forum" for the answer ;D Moebius
It has Roland custom mask programmed 8048. I´m not sure if it´s possible to dump internal code even with hacking. But the protocol is most likely pretty simple so as DrBunsen suggests.. data logging and reverse engineering could be "easy".. Actually You want a PG800 workalike ;D PG300 is for alphaJunos and MKS-50. Moebius
Hi, Check this out: http://www.midibox.org/forum/index.php?topic=3610.msg23537#msg23537 Moebius
Hi. Core is from Mikes Midibox shop... One suggestion: Try disconnecting middle (ground) pin from the core MIDI Out port (J12). Moebius
Hi, You can look the datasheet. Each of the buttons needs a clock and a serial data line. The minimum clock frequency is 50kHz.. To support many buttons it´s pretty resource hungry bit banging effort. Moebius
Hi, Rumours tell that those PA397 chips were originally from Tom Oberheims Marion Systems MRS-2 synth. Seen original Evolver circuit board photo with OnChip PA397. Also the OnChip systems owns CEM chip designs. (quoting) Dave: "yes; the chip is very close to the Marion. Has 2 oscillators, LP filter, a few VCAs all on one chip. " This smells pretty much like 3396. So, oscillators are actually waveshapers. Pro-one is nothing like Prophet5 for that matter, direct Voltage control versus uC based system with memory. Moebius
Cool! Moewbius ;)
