30 -
Everything posted by RadicalAns
Now that I think of it, the Novation X-Station is powered and does midi via USB. -Dave
USB has 5VDC and data all in the same cable. Seems to work fine for that. -Dave
New boards are ready, but there is an issue....
RadicalAns replied to smashtv's topic in Latest News
Man those boards are sweet! Makes me wish I had waited to order my core and SID boards. Good job smash! -Dave -
I wasn't using your design but a design of my own. Just sharing a lesson I learned the hard way. ;D
Learned a lesson the hard way: Pay attention to the ratings on your components. I was building a PSU for my SID and used a 16V 1000uF cap, unfortunately I didn't read the rating properly and hooked it up to 24V. Around 20 seconds later it went BOOM. Smoke and bits of capacitor everywhere….Lesson learned! ;D -Dave
source of shiny new YMF262-M and YAC512 chips
RadicalAns replied to fergusnoble's topic in MIDIbox FM
Do they require a minimum quantity? -
Is this taking into account the voltage drop across the rectifier?
Well I finnally see the light at the end of hte tunnel. After finishing up college and getting settled in my new job I finally have some time to do some projects. Recently I bought a Korg DW-8000 and I really like it, but it's a pain to edit sounds with just one slider. I was looking at a website (http://www.pallium.com/bryan/dw8000.php#Freak) and saw that it was posible to edit params via a midi controller, but they were special syex messages. My question is, given the right set of messages, would it be posible to make a control surface that would send these syex messages, based on midibox hardware? Thanks, Dave Panseri
Transistor Tester + project site coming soon
RadicalAns replied to Artesia's topic in Design Concepts
I got my scope (Hitachi V-650F 60MHz) on ebay for around $75. It's a little big compared to the newer digital ones they have at my university but that's just cause it's older and fully analog. Overall I am very pleased with it. Both channels work perfectly and. all the dials and switches work perfectly. I also found a modular unit with two 24V adjustable power supplies, funciton generator, and a multi-meter for around $70ish. I'd suggest searching around on ebay. You might find a gem. ~Dave -
Man, that looks like a neat little project to work on after I'm finished w/ the project I'm working on for school. Question: Where did you get the neat little enclosure for the transistor tester? -
The other day I was messing around w/ my MBSID trying to make some new patches when all of the sudden it just kind of died on me. I have since removed the core and checked to see if it was sending any midi messages and it isn't. Any suggestions? ~Dave
oooo i just remembered that I have one that plays the "secret sound" from The Legend of Zelda. You know the sound that you hear when you find a secret item or something in a dungeon. What format do you want it cause right now I have it saved in JSynthLib. ~Dave
How would I go about doing that? Rotary Encoders? I was thinking of adding a phaser from tonepad too so that'd be pretty sweet. ~Dave
I just found that myself the other day. They've got alot of cool projects on that page. I may build one of the phaser pedals on there and maybe make a distrotion box for my guitar. Thanks for the partslist it'll be a big help. ROCK \m/
what I think I'm gonna do is add a switch to turn the noise gate on and off. That way i can go either way. Since I plan on using my SID with my band at live shows, it might be good to be able to get rid of the hum at the flick of a switch, and if I want it just switch it right back.
Thanks for the info. I think I might try running it through a noise gate. Anyone know where I can get one cheap, possibly DIY?
It seems a little loud to me but I may just have my speakers turned up too loud.. i dunno. You can here a sample here
I just got my SID working and I noticed that when I hit a note there is a sort of aftersound. It sounds like the last note I played only softer. Anybody know what this is and/or how to fix it? Thanks Dave
Sweet!! PM me when you get back. Have fun vacationing!
I recently aquired a C64 that was made in Canada, and when I went to desolder the SID I noticed that it was in a IC socket rather thand soldered directly to the board. Needless to say I was a happy camper. Has anyone else seen this? Dave
I'm a bit confused by the switches in the scematics for the c64 power supply (both regular and optimized). Are there two seperate switches used or is that a single DPST switch?
oooo a microKorg interface. :) Sounds awesome! Any chance I could have a look? David
P.S. I just saw the MidiBox Drum trigger topic in the news section, sorry for the redundant thread. For some reason when I did a search for drum on the forum that thread didn't come up.
