audiocommander
Frequent Writer-
1,358 -
I call "application" what is based on the MIOS skeleton (Init(), Timer(), blabla). Therefore you can achive nearly all you want with a plain C custom application: You can disable the SRIO driver, setup a timer and scan and set pins of the pic. Besides the specialized de-/multiplexing that's apparently what the SM_example does (please correct me anyone if I am wrong). But am I right, that you want to use it for reading the state of your C64 Keyboard? If this is the case, you could just use a DIN module, check the pin states and demultiplex it by code. That sounds a lot easier. Anyway, good luck, Michael
well, I can't ASM and I don't know the example besides having taken a quick look. It seems that the SM_Stuff is that what you want to have, it shouldn't be very complicated but maybe a bit time-consuming to wrap it into a C-file with __asm and __endasm. on the other hand there are two more options: 1. convert the whole asm project to C (I think most of the smaller projects will be converted to C sooner or later, so if you make a start, it surely will be apreciated) ;D 2. forget the example and code your own application in plain C (I'd do that) ;) Michael
Restructuring Wiki Home
audiocommander replied to audiocommander's topic in MIDIbox Documentation Project
OK ;D I did it. don't say I didn't warn you! :o mwuahahahaha (damn, there's no insane-laughter-smiley) -
Yeah, I found the pics are too small, AFAIK they're not at all mentioned in the gifs, but in the PDFs you should see them quite clearly :o Take a look again into the PDF plans: e.g. Core: look at Pins "OSC1" and "OSC2" DOUT: look for C1..C5 ... ;)
search Conrad for "Gerätefuß" or "Plastikpuffer" or "Elastikpuffer": These are also available in clear, but note that they are pre-cutted to easily remove them piece by piece from the sheet. ...of course you can buy them also from other companies. I do not mention here that Conrad is most times 25% - 50% above the usual prices! ;D
Wouldn't it be easier to take a round plexi rod (Stab, Rohr, Stange); should be available in all DIY-Shopping Malls, cut it into pieces, drill the pieces and glue them on the switch? At least for single round clear buttons, this would be the easiest solution I can think of. Other forms or bigger sizes may be achieved with silicone indeed... I know some of my fellow students working with silicone modelling, I will interview them... Regards, Michael
Yeah, I see ;) Just to avoid misunderstandings: I meant the index page of the wiki and the sorting of the linked entries. I haven't really thought of the design or framing the wiki ;D But this would mean a total resorting of the current entries, so I want to discuss it first. Maybe my POV is not the best way to go. :-\ I believe, the better the structure, the more people use it, the more it is used, the more content it gets. -
Hi, I wonder if we could get a better structure of the WIKI Homepage? I think the main page is very unsorted and the time-based concept (preparation, parts, construction) isn't sufficient for the bunch of entries growing steadily. The frame of ucapps is very well sorted, so why not take this sorting as basis? We are all used to that structure! Eg the first entry of the wiki could link to the correspondig ucApps documents (marked as "official" but then there could be more entries, thematically related. So, MIOS and MBHP and the different MBHP-based projects would be differentiated and not mixed up, which is (so I belive) very confusing for beginners. Also, one can easily navigate due to the similarity of information-structures. What do you think? ::)
MIOS programming with Xcode 2 on a Mac (OSX)
audiocommander replied to Rowan's topic in MIOS programming (C)
8) 8) Thank you, thank you, thank you 8) 8) I'm glad I could help with this issue. I whish I'd have had such an installer, I remember it took a loooooooong time to get SDCC running on my mac. Setting up Xcode should be quite easy now! :D -
OK, Rowan, I got it. 8) I've built an pkg installer and tested it on my mac mini where no SDCC has been. It's running! load it here: http://www.audiocommander.de/downloads/midibox/sdcc254-installer-osx.mpkg.tgz (4.6 MB) If you type sdcc and get a return "command not found", you have to add usr/local/bin to your path environment: $ echo $PATH // now you should see this line /bin:/sbin:/usr/bin:/usr/sbin // copy the whole line. now type $ PATH=:<paste here>:/usr/local/bin done. please, if anyone is trying this, give feedback. Michael -
btw, a little off-topic, but useful tips for working with the terminal: 1. if you drag a folder or a file into the terminal window, it's path is set in. This is a real time-saver 2. you can browse these directories within finder. just press CMD+SHIFT+G (or menu: Go To > Go To Folder..) and type /usr/local/ and you're in that directory. Be careful in there! 3. Try pressing the TAB key inside the terminal. It has an autocomplete feature for paths and available commands ("double TAB" ;D) 4. Try pressing the up and down arrows. You can browse through the bash command history Have a nice type ;) Michael -
Hi Rowan, I'm not sure about this. :-[ If it had wrong permissions set it would return "permission denied." (If you ever have to set execute-permission, it goes like this): $ chmod +x /usr/local/bin/or/whatever/directory/the/files/are/in Anyway, I checked my binaries and compared them to the binaries I uploaded. I noticed that mine were 1 month newer. So could you please download this package: http://www.audiocommander.de/downloads/midibox/sdcc-2.5.4.2005.11.15.audiocommander.tgz (4,6 MB) and try it again? The "share/sdcc" dir-content should be the same; I just exchanged the binaries, however it doesn't hurt to exchange both the share/sdcc and put the bin/ content to /usr/local/bin. I have it in /usr/local/bin although the docs say it could also be in /usr/local/bin/sdcc. However I haven't tried that. So, now I confused everyone, here's what to do: bin/ =copy to=> /usr/local/bin (maybe set execution rights then) share/sdcc/ =copy the "sdcc"-folder into=> /usr/local/share/ I hope it really works now!!! ::) If you are successfull, I may set up an installer for others... Michael Edit: This version might work, but I've built an installer (see below...) -
Sorry for assuming you haven't read the page :-[ I searched for KS0070B and found that it should be compatible to HD44780; so the controller should be ok. Could you please answer these two questions: sorry again, Michael
Well, here seems to be your problem: You should have read http://www.ucapps.de/mbhp_lcd.html before ordering. ;) Your LCD controller is a KS0070b (see datasheet). MIOS is by default only compatible with the mentioned LCD-Controller types. You could however write your own driver (requires some efford, but is possible, see section "custom LCD driver" on the lcd page; shouldn't bee too hard in your case, since there seems to be only an issue of correct addressing), only print out chars with MIOS_LCD_PrintChar('x')* or simply buy a HD44780, HD61202 or KS0107 compatible display. Best, Michael * you might also write a custom function or macro, eg: TH_PRINTCHAR(unsigned int addr, unsigned char c) { MIOS_LCD_CursorSet(addr); MIOS_LCD_PrintChar(char); } Edit: fogot to mention the most common controller type: HD44780
Hi Thomas, do you have any strange uncommon LCD or is it a widely used one? Is it KS0107/KS0108 or HD61202 compatible? I'm asking because I have a 1x16 LCD that has to be addressed like a 2x8 (0x00 + 0x40). The fact that it only shows 2 chars even on MIOS-Startup ("MI" ? Is that right?) would point to this direction, even if I can't believe it by myself... Is there the missing "OS" also somewhere or just "MI"? Do you have a datasheet for the LCD? Could be a wrong connection somewhere on the Core, although I can't see why the setting of the cursor shouldn't work with a CString while a CString works with explicitly setted cursor? AFAIK PrintCString is just supported by the wrapper, so it should be no difference there? Is your alternative display from the same type? And just to check one more possibility: Do you have some code that's writing something to the LCD from somewhere else? => Timer(), Tick(), DISPLAY_Tick() etc... ? Best regards, Michael
Midi monitor dashbord widget for OS X 10.4
audiocommander replied to Rowan's topic in MIDIbox Tools & MIOS Studio
Nice try but keeps on crashing, esp. on un-/plugging MIDI Devices and if there's a little more traffic going on ;D hehe... Better stick to "MIDI Monitor" :) http://www.snoize.com/MIDIMonitor/ BSD-License OS -
Not really. The C-Debug Code is used one step earlier :) To simulate quickly (type analog in -> get behavior of your app); to walk through step-by-step (instruction by instruction) and to check if the program flow is right. And being able to watch when/if variables change their contents. Typically you can avoid these errors: - D'oh, the LCD has to be updated here! - What's that char coming from? - Why is AIN5 refusing to take 0 as input? The MIOS SysEx Debug functions are handy if you want to watch what's going on inside the PIC. There is a textfile called mios_sysex_implementation.txt where it's described how to trigger functions and peek into contents of address-ranges. Most of it can be done within MIOS Studio... The main difference is (AFAIK) that if you call a function by SYSEX, you get a return value, but if it's wrong, you might not know for sure why. Next point is, that you don't need to upload your application to realize that there are errors. And there are always errors. Anytime ;D Regards, Michael
Rowan, I just peeked again in the SDCC binary I uploaded on my server. There is a file called "INSTALL.txt" that describes the installation process for Linux. Please try to proceed this way: SDCC Binary Kit Install Help ---------------------------- $Id: INSTALL.txt,v 1.4 2004/02/23 20:54:07 bernhardheld Exp $ For Linux users: Even if the default search paths look into /usr/local, sdcc is fully relocatable. Try `sdcc --print-search-dirs` if you've problems with header or library files. See sdccman.[txt|pdf|html] for more detailed information. To install: * Extract the binary kit to a temporary directory. This will create a new directory called 'sdcc' in the temporary directory. cd ~ mkdir tmp cd tmp tar xzf path/to/binary/kit/sdcc.tar.gz * Change to the sdcc directory and copy all files to /usr/local cd sdcc cp -r * /usr/local This will install sdcc into /usr/local/bin/sdcc, support files into /usr/local/share/sdcc, and documentation into /usr/local/share/sdcc/doc. You can test the install by entering: /usr/local/bin/sdcc -v This should return sdcc's version number. Keep me updated, so I can add instructions to the wiki page :) Michael -
hi rowan, 1. what does sdcc tell you, when you type "sdcc -v" in terminal? 2. if you type this: "cd /usr/local/bin" and then this: "ls" do you see sdcc listed? -
Hi stryd_one, don't worry, it's not C) :-* ;D But I suppose, Mac-Tools won't help you. But you could use the C-Debug stuff I posted to the wiki in an IDE of your choice. The IDE for Win in the C-Thread mentioned the last days seems to be quite a nice thing. And implementing the C-Debug Files is really easy. I guess it prevented me from about 100 test-uploads to the core and saved me about 255 hairs that I'd have else ripped from my head. The concept is: target => debug: build, run in the STDIO console, inspect vars, watch console output etc... target => my_application.syx: build, upload to the core. I have only one MIOS_debug.c file for two current projects, so it should be easily adapted to your needs. I added Bankstick support yesterday (geez, that would've been impossible to do without C-debugging!), but haven't updated the files in the wiki. Is this kind of an answer you wanted to hear? :-\
MIOS Studio for Mac users
audiocommander replied to adamjking's topic in MIDIbox Tools & MIOS Studio
I finally succeeded too in installing MIOS Studio. :D I got MIOS Studio 5.1 beta working with the Java2 5.0 release 3: http://www.apple.com/support/downloads/java2se50release3.html Hower, the problem was, that I haven't read the release notes. :-X Once you have downloaded and installed Java5, it isn't automatically used by MIOS Studio. There should be a program resided in /Applications/Utilities/Java/J2SE 5.0/ Open it and set it to prefer 5.0 over 4.2 Thanks for MIOS Studio! ;) Michael -
Floorboard with Noteon and Exproesion controller.....?
audiocommander replied to Juancho's topic in Design Concepts
Hi Juancho, the answer to all of your questions (except the last one) is: yes. Go to the Dokuwiki and start reading with the "General" section. http://www.midibox.org/dokuwiki/doku.php It's really easy, once you know how to sort the different MIOS modules together ;) Michael Edit: I don't know if anyone made exactly such a floorboard, in theory it's just a few buttons and a custom application that sends some MIDI signals. That's quite an easy thing to do. Just start with it and once you have concrete questions, search for answers in the WIKI, on uCapps, in this forum and (if not found) post your concrete question ;) -
maybe you have an unclosed tag somewhere? is your syntax right and not overlapping with the wiki-syntax? it happened to me, too, but this has always been a syntax error somewhere! best, michael
I'm sorry; I remember now, that this was the big problem I had. The snapshots are only sources. You might try to compile and install, but I had lots of trouble with it. I searched my HD and found the version I installed. I packed it together and uploaded it on my server: http://www.audiocommander.de/downloads/midibox/gputils-installer-osx.pkg.tgz (1.3 MB) http://www.audiocommander.de/downloads/midibox/sdcc-2.5.4.2005.11.15.tbz (2.4 MB) The SDCC package contains binaries. Copy them to /usr/local/bin (You know you can get there within Finder: APPL+SHIFT+G ?) Open the terminal and test by typing: sdcc -v If you are successful with it, I'll update the HowTo! Keep me updated! ;) Edit: The stroked SDCC version is not working. See below... Take this one instead: http://www.audiocommander.de/downloads/midibox/sdcc254-installer-osx.mpkg.tgz (4.6 MB) -
Speakjet - A PIC ready sound chip?
audiocommander replied to herr_prof's topic in MIDIbox User Projects
hmm, then it seems this may be a deadend, becaue sander marked this as discontinued sale. :-\ ahh, what the heck, I'm ordering one too before it's too late :) (thanks for the info about robotikhardware!)
