DragonMaster
159 -
Everything posted by DragonMaster
Unless this bridge has an hidden constant current source in it :D (Joking) With a constant current source, the voltage is adjusted by the circuit so that a constant current is output -> BAD for digital circuits.)
Nope, it would just be able to output a maximum of 2 amps. The rectifier just converts AC to DC, nothing else. The circuit will use the current it needs, and the rectifier output voltage is 1.414 x input voltage. The maximum output current at 50°C. Average is probably the average rating that tested units produced. (Those tests are done on multiple units, some can handle more current than others) An higher voltage rating like in Wilba's circuit is much safer as the diode has much less chances to fail. (Because if it fails, it shorts, that means both AC lines will get connected together in the bridge and the DC outputs as well. Not only will it destroy the whole circuit, but also get the transformer outputs shorted, and if there are no fuses (Likely), the transformer will overheat and there are following consequences. A shorted transformer used for small projects like this one don't pull enough current to get the 15A breakers to shut off if they're shorted at their outputs, so fuses and >200V bridges are always recommended.
http://www.ucapps.de/mbhp/mbhp_dinx4_32buttons.pdf
DragonMaster replied to cimo's topic in MIDIbox Documentation Project
Vs = ground All the Vs pins are ground pins. Just connect the buttons there. -
Well, you can probably use them, it depends of the wiring and probably a bit of logic and/or transistors will have to be used. If it's wired this way: http://ucapps.de/mbhp/mbhp_doutx4_32leds.pdf It's only either one color per LED or one for off and the other for on. If you use a matrix you could probably get both colors using various ways. If the matrix gets the LEDs to flash very quickly anyways, both colors could be switched really fast between each others by using twice as much rows or columns than there are LEDs.
http://www.google.com/support/youtube/bin/answer.py?answer=55744&topic=10526
There's a driver on the MIDI-OX website to use custom sounds with an OPL2 / OPL3. They even have a compatible DOS sound editor.
No sound samples... :'(
Doesn't look like it... You can find a few never finished projects on diyAudio using either VisualDSP (AD's own $3500 software), C or uCLinux.
Would be a nice way to restore the silkscreen on the acrylic panel of my EICO tube FM tuner, the effect looks quite similar to your panels.
spectrasymbol softpots group buy - membrane strip potentiometers
DragonMaster replied to phineus's topic in Bulk Orders
Maybe a list in the wiki could be placed next time, more convenient... -
Seems to calm down... 100 chipsets on the list last week, now there are "just" 9 more after a week...
Effectivement, je ne connais pas beaucoup d'interrupteurs qui n'ont pas de jeu, surtout pas un On-(On) à poussoir. Bonne idée! Par contre, je metterais peut-être un interrupteur à la place des contacts sous le bouton. Si vous trouvez pas grand chose, l'interrupteur ALPS de 4.5mm de course avec un grand titre de "Smooth and linear operation feeling." devrait fonctionner alors http://www3.alps.co.jp/WebObjects/catalog.woa/PDF/E/Switch/Push/SPED2/SPED2.PDF Ils coûtent pas très cher non plus : http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=140154951809 (Je ne vois pas comment les pins sont montées sur ce modèle là , il y a un autre modèle pour circuits imprimés.) Deux choses m'inquiètent : -La force nécessaire pour l'appuyer. -Il est testé seulement pour une durée de vie de 30 000 cycles. Sur un SPDT On-(On), quand la touche n'est pas appuyée, il y a un contact. Le logiciel serait confus quand il verra que sur la même note il y a un On et un (On), ça serait possible de faire fonctionner cela, mais sans vélocité. Sur le forum en anglais, on m'a pointé sur un lien avec une MIDIbox qui utilise une matrice avec un clavier standard, http://www.midibox.org/forum/index.php?topic=6386.0 mais le code est fait pour un clavier à membrane et donc deux "interrupteurs" Off-(On) avec des délais différents. Apparament que le logiciel ne voit pas toujours les note-off et les interrupteurs ne sont pas des SPDT, donc, sans gros travail sur le logiciel (Je connais zéro assembleur ou C), impossible de faire quelque chose. Ici, selon moi, la solution la plus simple (et coûteuse...) resterait deux cores et huit DINX4, comme il y a déjà un logiciel existant et seulement un peu de code à modifier.
8 SIDs = 24 channels ... Two MIDI inputs?
DragonMaster replied to DragonMaster's topic in MIDIbox SID
Hi TK, thanks, simple fix then. Cheers, Antoine -
I see... The person might build a Off-(On1)-(On2) switch system though, that would be closer to a usual keyboard. Still... not sure of which switch type will be used, so there are a few steps to do before thinking about software and MIDIbox hardware...
My SID is not built yet ;-) I was wondering since my two keyboards (Kawai K4, K5) don't support splitting easily (At least the K5 can, but the K4 is another story, I didn't use it much since I bought it.) and I have 12 spare MIDI inputs and outputs for the moment(However, a few MBFMs are to come). Oh, I just found a solution! -> Building an MBCore to make a keyboard splitter! -
I just came across this: http://www.midibox.org/forum/index.php?topic=9376.msg67106#msg67106 Is it possible to use two MIDI inputs with 4 SIDs per cable to fix this?
Nope, only TRS-80 Color Basic, DOS batch and once modded a program made in Tcl/Tk. I've never got to build my Microchip ICD2 clone to start learning ASM... I have all the parts, but my LaserJet IIP printer died last year (I bought a new scanner motor last week, should be getting it soon! -with COD brokerage fees... >:() I don't think I'll learn ASM for someone else if I have other priorities during the next month(Off school from Dec 21st to Jan 21st) : 1. Buy and program Flash ROMs for my Kawai K4r V1.4 / K4m V1.4 / K5 V1.3 / K5m V1.2 firmware upgrade group order. 2. Buy 8x 6582 reserved SIDs from Wilba. 3. Fix the #!$@;* sump pump check valve. 4. Fix the noisy ADC stage in my Fostex DAT deck I bought 1-2 months ago. 5. Fix my laser printer and start to build some PCBs for projects on standby. ... (+ two mono tube amps to restore, my Gainclone to get working properly, finish the speakers I started to build in 2004, repairing two amps with little-annoying problems, get an analog oscilloscope-> align three cassette decks and a few tuners, etc.) ... then if everything goes well, in a few years I'll build the ICD2 and start working on MIDIboxes... -> That's going to be in years! (In the mean time, I get some parts while they're still available)
Hi all, someone on the French forums needs to build a MIDI keyboard using 108 keys with velocity. So far, it looks like SPDT switches will be used. What would be the best way to connect this to a MIDIbox? There's this way : http://www.midibox.org/forum/index.php?topic=5835.0 but it only supports 63 notes. (Two cores, eight DINX4s and a LOT of wire...) I thought about using a matrix, but there's nothing so far with velocity support and I wonder if the keys would be scanned fast enough. So far it looks like the keyboard will just have a power input, keys and a MIDI output. Any ideas?
Leur adresse courriel ne fonctionnait pas, j'ai envoyé un message au webmestre, et rien depuis... Peut-être qu'une matrice devra être utilisée (comme plusieurs claviers électroniques) étant donné qu'il faut deux contacts par notes -> 216 contacts (les MIDIbox supportent jusqu'à 128 entrées) Ça ferait des interrupteurs arrangés en 12 x 9 (2 contacts = 12 x 18) donc avec un DINX4 ou X2 et un DOUTX2 ou X4 ça fonctionnerait. La matrice peut être arrangée de plusieurs façons, il s'agit de la faire fonctionner avec le placement des boutons. Il n'y a pas de logiciel MIDIbox pour une matrice avec vélocité par contre... Deux modules core et huit DINX4 devraient être à envisager alors. De toute façon, ce qui importe le plus pour le moment, c'est de trouver des interrupteurs : La MIDIbox peut être arrangée de plusieurs façons pour réussir à avoir les 108 touches. Je dirais pas mal de câble... (Si les interrupteurs sont sur une rangée, il y a presque 2 mètres de boutons à relier à deux modules.) Il faudrait aussi des boutons sur les interrupteurs pour obtenir la surface de 15mm Seulement si le PIC est préprogrammé avec le bootloader, donc il faut l'acheter chez quelqu'un qui vend des PCB pour modules MIDIbox. http://ucapps.de/mios_bootstrap_newbies_fr.html J'ai trouvé quelques interrupteurs, il faudrait pourvoir obtenir des échantillons par contre, il y en a qui sont pas si mal sur papier mais on ne sait pas comment ils sont physiquement. Un lien ici: http://www3.alps.co.jp/WebObjects/catalog.woa/PDF/E/Switch/Push/SPED2/SPED2.PDF À 100 interrupteurs et plus, vous pouvez acheter les interrupteurs directement des manufacturiers, et certaines compagnies acceptent même d'en fabriquer sur mesure à cette quantité, le seul hic étant d'avoir des pièces de remplacement. Il faudrait avoir quelques spécifications par contre : - Est-ce qu'il faut ressentir et/ou entendre un clic en appuyant sur les boutons? - Comment est-ce que les boutons sont disposés? (Pour pouvoir dire quels modules utiliser et sur quoi monter les interrupteurs.) Est-ce qu'il y aura un panneau? Je doute qu'il puisse passer entre les boutons... (Il faut dire qu'il n'y a rien entre les touches d'un clavier normalement)
http://ledmuseum.home.att.net/1980.htm They produce mostly IR and almost look like a laser apparently. The Fairchild FLV-104 is the only standard LED I found that produces 670nm, and it was discontinued almost 30 years ago.
It wasn't really related finally... However, I found 665nm LEDs, about $0.40 at Digikey. Search for "665nm" on their website. If you look for 670nm, you'll find laser diodes and fiber LED emitters. The website stated that, I don't know if they mean to look throuhg datasheets, or send them an e-mail to know if they have such products.
I just found a website telling they're quite common, but you need to look with manufacturers.
Yep, 360 degree continuous potentiometers. I just searched for the model number of the units you just sent a picture of, they're still in production apparently! -
The CD mailer sounds like a good idea, it even has thin foam layers. The only problem is that they softpots are 5cm longer... By the way, I forgot to specify about the Crimpflex connector in my order, will they all have it? -
Regular letters have no problem, but a bubble envelope will likely need one.
