Marxon
Programmer
    474
    4
Marxon last won the day on March 20 2015
Marxon had the most liked content!
About Marxon
  • Birthday 09/27/1985
  • Gender
    Male
  • Location
    Plauen, Germany
Recent Profile Visitors
5,213 profile views
Marxon's Achievements
MIDIbox Tweaker
MIDIbox Tweaker (3/4)
5
  1. Problem solved! I found a tool called PICPgm which supports my old Willem parallel port programmer (the manufacturer software doesn´t support 18F4685) and burned my PIC without any problems. Have a nice day! Best regards Marxon
  2. Hi, this topic is a bit older but i'm facing the same ID problem with my G540 programmer. There is also no option in software to reconfigure the programmer so that only the first 4k block will be overwritten. Since the baud rate is set COM, would it not be possible to upload the workaround somehow via a LTC module? Thanks for your help. Best regards Marxon
  3. Yeah the signatures are back again.
  4. Aber kein Alkohol ist auch keine Lösung. In plain english: But no alcohol is no solution, too.
  5. I also tried Isopropyl but I could not achieve the same results.
  6. Yes they look very nice! The same button are also used in my Quasimidi 309. But they are so expensive :( This is my low-cost variant: http://midibox.org/forums/topic/17186-yaib-yet-another-illuminated-button/ Best regards Marxon
  7. Hi TK I just wanted to buy you one or two beers and realized that there is no "Buy TK a beer" button anymore. Have you renounced the alcohol? ;) Best regards Marxon
  8. Hi all! I am very sad becaused i missed this bulk order. If someone changed his mind and does not want his 16x16 board anymore please let me know :) Nevertheless have much fun with your boards! Best regards Marxon
  9. Damn! I visit the forum regulary but missed this bulk order. If there are any PCBs left i wouldt buy them instantly. Best regards Marxon
  10. Hi FantomXR try if this works like you expect. The channel select buttons will run a script (to activaon press .NGC #CH2 EVENT_BUTTON id=1 hw_id=1 type=Meta meta=runsection:1 range=127:0 button_mode=OnOff EVENT_BUTTON id=2 hw_id=1 type=Meta meta=runsection:2 range=0:127 button_mode=OnOnly #CH3 EVENT_BUTTON id=3 hw_id=2 type=Meta meta=runsection:3 range=127:0 button_mode=OnOff EVENT_BUTTON id=4 hw_id=2 type=Meta meta=runsection:4 range=0:127 button_mode=OnOnly EVENT_KB id=1 hw_id=1 type=NoteOn chn=1 EVENT_KB id=2 hw_id=1 type=NoteOn chn=2 EVENT_KB id=3 hw_id=1 type=NoteOn chn=3 .NGR #CH2 if ^section == 1 LOG "CH2 deactivated" set_active (id)KB:2 0 endif if ^section == 2 LOG "CH2 activated" set_active (id)KB:2 1 endif #CH3 if ^section == 3 LOG "CH3 deactivated" set_active (id)KB:3 0 endif if ^section == 4 LOG "CH3 activated" set_active (id)KB:3 1 endif
  11. Hi sprintf, unfortunately it is not possible to mix display types. AFAIK Hawkeye and nILS made a working SSD1322 and SSD1325 driver for theire projects. If you really want to use different displays, you can connect them to multiple cores.
  12. Hi Midiboxers, while i was tinkering with my midiboxes i wondered if it would be possible to use a Midibox NG to simulate a encoder. Something like an "encoder generator" simply by using a Dout board and a .NGR script. Some quadrature encoder signal may could be generated like this: if ^section == 1 set LED:0 0 delay_ms 2 set LED:1 0 delay_ms 2 set LED:1 1 delay_ms 2 set LED:2 1 delay_ms 2 set LED:0 0 delay_ms 2 set LED:1 1 delay_ms 2 endif I guess connecting DOUT pins directly to the encoder inputs on the destination device requires some kind of adjustment but should work too? What do you think? Is something like that in genaral possible? Best regards Marxon
  13. Hi Novski, thanks for your suggestion! Your inverted range get me on the right path. Last night I did not come up with the idea. This is working: ### BUTTON PRESS EVENT_BUTTON id=1 hw_id=3 type=Meta range=127:0 button_mode=OnOff meta=runsection:1 ### BUTTON RELEASE EVENT_BUTTON id=2 hw_id=3 type=Meta range=0:127 button_mode=OnOnly meta=runsection:2It allows to run two different scripts on button press and button release. Until now i used a if/then statement in my .NGR script wich was probably not very CPU friendly. ### .NGC EVENT_BUTTON id=1 hw_id=1 type=Meta range=0:127 button_mode=OnOff meta=runsection:1 ### .NGR if ^section == 1 if (id)button:1 == 0 LOG "BUTTON RELEASE" else LOG "BUTTON PRESS" endif endif Best regards Marxon
  14. Hi TK, would you please add also a "OffOnly" mode for buttons? A way to start a ngr on button press and a other script on release would be just as helpfull. Thank you very much! Best regards Marxon
  15. Hi Thorsten You are genius! After more than three years reminding you, you come up with it without warning on a sunday afternoon. :) I would love to test it right now unfortunately i am already on the way to work. But it looks exactly like what i've wanted. Really great! Thank you! Best regards Marxon
