474 -
4
Everything posted by Marxon
Hi again Duggle, now i have another question :smile: Can i wire the matrix also this way?
Hi Duggle, unfortunately i get a "non valid image" error when i click on your matrix schematic from the first post. Would you please post it again? Thanks a lot! Best regards Marxon
hi ronde, das ist ja mal eine coole, interessante idee! sowas solltest du auch als einsteiger ohne größere problemle realisieren können! was noch zu klären wäre: hast du dir schon überlegt in welcher art und weise du die sounds triggern willst? also wieviele brauchst du während deiner performance und müssen sie zu jeder zeit verfügbar sein oder willst zwischen den sounds hin und her wechseln? sollen die schuhe erkennen wie stark du auftrittst oder reicht "an/aus"? mfg marxon
Hi mburch, you are right, it is possible via button matrix, but I forgot to mention, that i like to control them via midi. Best regards Marxon
One last try from my side: If it still does not work, do not despair, master TK can help for sure.
I guess you double checked your header solderings, allready? Just found this: http://knowledgebase.nxp.trimm.net/showthread.php?t=2496&langid=1
Yes you are right. The "empty" project does not need to be flashed too. Sorry for my wrong help attempt! Thought this time i can also help somebody :(
TK replied during writing....
Hi Elektruck, have you created and flashed a new "FreeRTOS project" in LPCxpresso IDE first? This enables the flash programmer. After this you can upload the MIOS32 bootloader. The LED should fade three times if it was uploaded correctly. Best regards Marxon
From the album: Marxon's FM Synth
My finished FM Synth. Only a frontpanel need to be done. -
Hi, it would be nice to have "current operator" controllers to control Volume, Flag, Frequency Multiplicator, Attack Rate, Decay Rate, Sustain Level, Release Rate and Waveform of the currently selected operator. Like the "current instrument" controller on the Sid Synth. Best regards Marxon
Hallo wiedermals, gleiches Anliegen anderer Lösungsansatz: könnte man nicht einfach im Sequenzer (Midirouter) eine spezielle SidDrum Destination erstellen, die alle empfangenen current Instrument Parameter der Drum Engine (Attack, Decay...) zum aktiven, im Sequenzner ausgewählten Drum Instrument "umroutet"? Aber ich vermute, dass ich mir das zu einfach vorstelle... mfg Marxon
Hi Midiboxers, i could not figure out whats is the difference between destination "track" and "sel. track". Maybe someone can explain it to me? Thanks a lot Best regards Marxon EDIT: RTFM! ;) Now i know the difference...
Great work TK! I love your Update-Sundays :smile: That´s indeed very usefull. It improves workflow a lot beause i don´t need to change the mapping of my master keyboard if i want to play another instrument. Perfect! Have a nice evening! Marxon
Hi, i know this is not the best way, but you could control the filter type with some conditional events which are depending on different encoder value ranges. For example: if_less_stop_on_match=Encoder:x:10 -> filter type 1 if_less_stop_on_match=Encoder:x:20 -> filter type 2 ... Best regards Marxon
Hi yes you can do this but via nrpn http://svnmios.midibox.org/filedetails.php?repname=svn.mios&path=%2Ftrunk%2Fapps%2Fsynthesizers%2Fmidibox_sid_v2%2Fdoc%2Fmbsidv2_parameter_chart.txt Best regards Marxon
From the album: Marxon's M³ - MarxonMixvibesMidibox
