Marxon
Programmer
    474
    4
Everything posted by Marxon
  1. I meant to measure directly on the Mac USB port. If there is really a 6V output then might something wrong with your Mac.
  2. Hi! Such high values are desturbing. I would first measure the USB port voltage when nothing is connected. Marxon
  3. Hi! Solder BS1 and BS2 to GND. The missing BS0 is mostly internal connected to GND. Best regards Marxon
  4. Hi everybody! I want to start a bulk order of SSD1306 OLED displays LINK Here are the technical details: Controller:SSD1306 Pixels: 128x64 Panel Size: 26.70mm x 19.26mm x 1.85mm Active Area: 21.74mm x 11.2mm Module size:28.mm x 27.1mm Dot Size: 0.15mm x 0.15mm Drive Duty: 1/64 Duty Support interface: 6800/8080, parallel interface, IIC, 4 SPI, 3 SPI Voltage:3.3V They are available in 3 different colors. White Blue Yellow-Blue The pinout is somewhat different than in Thorsten's schematic but i have already tested the displays and they are working without problems on my LPC1769 and STM32F4 cores. ------------------------------------------------------------------------------ The Dealer offers following prices: if ordered 1pcs = 5,80€ / 7,78$ per pcs. if ordered >= 50pcs = 5,35€ / 7,18$ per pcs. if ordered >= 100pcs = 4,66€ / 6,25$ per pcs. if ordered >= 200pcs = 4,25€ / 5,70$ per pcs. Everyone pays the same price per pcs. regardless how many Displays he ordered --------------------------------------------------------------------- Shipping: Germany (unversichert) = 1,45€ Germany (versichert) = 5,40€ International (uninsured) = 3,45€ / 4,90$ international (insured) = 7,10€ / 10,06$ (Shipping costs can be reduced if the pin header is cut off so the Display takes less space) ----------------------------------------------------------------------------------- Orders can be submitted until 07 September 2014. Shipping to me in germany will take 4-6 weeks. Afterwards it will take another 3-30 days (depending on distance) until all displays reaches their owners. ------------------------------------------------------------------------------------- Payments can be done via Paypal. (payments from germany can be done by bank transfer) Paypal fees = 1,9% + 0,35€ / 0,47$ ----------------------------------------------------------------------------------------- ORDER LIST Simply reply to this topic and write down your name, quantities, display color and shipping destinaion. Use your full and correct forum name, so I can reach you via PM. Everybody gets an order confirmation and an invoice after the order deadline By putting your name on the list you agree to the terms and conditions described here: www.midibox.org/dokuwiki/nils_bulk_terms Best regards Marxon
  5. My settings: At the moment i am using just the bootloader app. EDIT: I've just noticed the following: After changing the number of displays with the bootloader app, then MIOS studio does initialize them and reports which displays failed to initialize. If i use character displays and connect less character displays than i have set, MIOS studio reports the missing ones correctly. But when i use SSD1306 displays, then MIOS studio does not recognize missing ones regardless how much displays have been connected. Is this a normal behavior?
  6. Hi again and sorry for my late reply! I tried to connect the display to Port J10B of my STM32F4 core but it still does not work. :( The led goes on but the display shows nothing. Is there any minimum configuration (like connecting Vdd, Vss and Vo of a standard display) to test if the display is generally working? Best regards Marxon
  7. STM32F4 I only measure 2,9V on my 3,3V line... could this be a reason?
  8. Hi novski! Sorry my schematic was not the best choice. It´s more to show the different pinout of the JY-MCU display compared to the one from TK HERE. Of course i dont use the same CS line for both displays and no second resistor/ capacitor :smile: Nevertheless i have connected D7 instead of D0 to the display CS pin, like you said but it still does not work.
  9. Hi all! I have exactly the same display but unfortunately i cant get it work on my STM32f4 core. The screen stays black only the led gets on. My core module should be OK because character displays are working properly. Settings: - all BS bridges are set to 0 - voltage jumper is set to 3V - lcd_type is set to 0x84 - led_num_x and lcd_num_y are set to 1 - lcd_heigh and lcd_width are set to 128 respectively 64 Thats my display wiring: I soldered 1k resistor and the 10uF capaciator directly on the core board and added a connection from the core to the display RES pin. What could be problem? Best regards Marxon
  10. Marxon
    Many Pics of my upcomming Mixvibes Cross DJ Controller
  11. Marxon
    SSD1306
    From the album: Marxon's M³ - MarxonMixvibesMidibox
    Wiring of a "JY-MCU OLED Module v1.5" SSD1306 display
  12. Hi TK! Oh OK, i did not know that. But that´s no big problem. To use a second display was anyway an optional idea. If really needed then i still can use a second core, But maybe it would be helpfull to mention this "circumstance" in the LCD chapter from the NG manual. Have a nice weekend! Best regards Marxon
  13. Sorry i made a mistake: Correct are four SSD1306 and two 16x2 Displays
  14. Hi novski! Thanks for your info and your board looks nice too! Do I see correctly that you moved the 595 from the core to the lcd board? Are short lines from the chip to the displays better? Or is it because an easier chaining of your display boards? Another NG question: Is it possible to use different LCD types at the same time? Because i like to use four SSD1306 and two 16x4 displays connected to J15A respectively J15B but i guess it´s not possible because there are only two "enable" (E) outputs...? Best regards Marxon
  15. Hi Midiboxer! I have a question about connecting multiple SSD1306 displays: Do i need a 10k resistor and a 10uF cap on every display or would it be enough if i use just one resistor and one cap on the core board only? Thanks for your advice! Best regards Marxon
  16. Hi Chris! You have to replace the byte which you want to control via a pot with "^val" For example stream="0xf0 0x11 0x22 0x33 ^val 0xf7" will send this string: 0xf0 0x11 0x22 0x33 the value (from the pot) 0xf7 Best regards marxon
  17. Hi again! So, for my use both options would be OK. (What´s about you jrp?) TK decide for yourself which one makes less effort for you. Best regrads Marxon
  18. Cool, so i´m not the only one. hihi :tongue: :thumbsup: Best regards Marxon
  19. No, of course not! That was just an observation. Which might could have been wrong. So i stated "i can´t find any Sysex or NRPN..." and not "there is no Sysex or NRPN..." :angel: :angel: :angel: Sorry that I'm the only one . :sweat: No documentation needed. I promise! Good to know but so far I haven't even thought of. Thanks for your response and have a nice weekend! Best rgards Marxon
  20. Ok, thank you Thorsten! And what´s about the SID control surface encoders itself? I can´t find any Sysex or NRPN which "simulate" them. Englisch kann ich das evtl nicht genau erklären... Was ich meine ist, dass ich anstatt die NG mit eigenen Encodern auszustatten, gerne die Sid eigenen 10 Control Surface Encoder (die 4 LFO/Filter Encoder jetzt mal nicht mitgezählt :smile:) nutzen möchte und die NG quasi einfach davor zuschalten. Die verschiedenen Funktionen/Parameter der Encoder lassen sich zwar per Sysex/NRPN steuern, die Encoder selbst (sodass sich ihrer Funktion je nach Menü ändert) aber scheinbar nicht. Gibt es da eine Lösung? Vielen Dank für deine Hilfe! Best regards Mfg Marxon
  21. I just remember that I have (due your tip with the MidiRex) a unused LPC core. Maybe i build a small MidiboxNG with: -1 encoder to select the current instrument -8 Encoders for the drum parameters -some buttons to select the drum model Or even better would be to use the Sid encoders itself. I imagine something like this What do you think about it? Best regards Marxon EDIT: Maybe it´s better to move this post to the MidiboxNG section.
  22. Hallo Rolf, es ist wirklich interessant, deinem Synth beim Erwachsenwerden zuzusehen! Mich würde noch interessieren, auf was sich die Bautteilkosten beim aktuellen Stand des Gerätes belaufen? Gruß Marxon
  23. ...YAR for TK (yet another reminder) :) Best regards Marxon
  24. +1 for this idea! Best regards Marxon
  25. Hi Alchemist, AFAIK you can leave out these parts except R9 and R10. You can connect up to 8 Banksticks to one core. They are shared between all cores. Best regards Marxon
