cimo
Programmer
    1,774
Everything posted by cimo
  1. "A guy enters in a cafe, SPLASH" THAT s a sad attempt of a joke
  2. I don t want to sound arrogant or anything but what about answering at least some the questions i am making you? Sometime it is better to switch your head off and let somebody else doing the debugging for you (i ve learned at my own expenses) Simone EDIT: maybe you can pass by the chat sometime, always packed with debuggers
  3. How can you be sure that MIOS is correctly uploaded? Have you checked the "wait for upload request" and used smart mode? (smart mode only for application upload) Can you upload an application while the core seems to be functional? Have you tried to disconnect the LCD? Have you checked 5 times every single component and every single point (with a multimeter for example) Simone i would wait
  4. .. puzzling, can you try to reupload MIOS, smart mode, wait for upload request.
  5. doable in this very moment, i switch among them with my MIDIBoxMindController EDIT: I took a screenshot: the first VST on the left is the newest standalone plugin but it hasn t got midi control over file browsing the other one is the Pluggo (Max/Msp) version with full files browsing
  6. seems like it goes on and off, can you check voltages at j1 and j2? can you tell us what you ve uploaded?
  7. Is that some sad attempt of a joke? Tongue
  8. no it isn t. Have you uploaded any application? Are you using smart mode when uploading mios, and checking the wait for response box?
  9. No he talks about the one in www.virtualorgan.com, JimHenry s been contacted already. cheers Simone
  10. Discussing about whether a chassis should be grounded or not, or about the size of a voltage regulator heatsink, that s the kind of folk i d like to hang out with...
  11. wow it s so well built that it looks like a 3D render...
  12. hola como usuario de midibox forum puedes modificara la wiki asi que .. adelante!
  13. SOIC good TPQFFTQ bad
  14. hi as mentioned the only missing feature is synching to the host, that s it, i wouldn t ask for anything else
  15. Can you be more tech-ish and tell me what you are talking about?
  16. new leds? new buttons? ??? can you explain which ones?
  17. ...LAME ! i use MsPinky s timecoded vinyls as a VST plugin in Ableton since more than 1 year, good marketing though, let s see what they will have to offer, the only feature i am missing is automatic beatmatching/synch between the plugin and the host, which i do tapping on the tap tempo .. Simone
  18. you can also go this way: http://ucapps.de/midio128.html
  19. you can: 1-use a matrix of leds (have a look at step C control surface of MBSID) 2-chain a second core 3-write your own C custom application ah, welcome aboard Simone
  20. Try: http://www.ucapps.de/mios/dout_buttons_v1b.zip
  21. I am happy they look ok but are the connected to ground or deactivated in the application? there is no SO on J9, do you mean SI ?
  22. Are all unusued AINs connected to ground?
  23. Search for Rasteri s scratch wheel ND Sasha s Ableton controller
  24. that was SineSurfer
