midiboxxer
133 -
Everything posted by midiboxxer
There are possibities to meassure it with a multimeter with a range for capacitor. You can also meassure the resistor of it to see if it has a short. But the best thing would be to buy a new one, they are very cheap and the risk of an later appearing proplem would be solved.
Hi, you write that you´ll need 2 sliders. As I know Midibox64E has only digital inputs, you´ll need 2 analog inputs. I think writing a little application would perhaps be the best solution for you. I´m not a programmer, but this should not be so difficult for this setup?! Have you any skills in programming? Greetings Markus
Yes you read it! Look here: http://www.midibox.org/forum/index.php?topic=5116.0;topicseen
help....i've broken my midibox....SORTED!!
midiboxxer replied to stevesavage's topic in Testing/Troubleshooting
Good to hear, yes that was the right way. Just like discribed in the upper link! Greetungs Markus -
Good work, the case looks very professional.
Hi and welcome. Is the bootstrap loader on the pic? Did you get the upload request like discribed here? http://www.ucapps.de/mios_bootstrap_newbies.html Perhaps check the pots on the core board! Greetings Markus -
@ sneakthief The post was an good idea. We should bomb ebay with emails. Perhaps they will do something when there is more then only one complaint.
The mk_midio128_syx is only a configuration dump for thze application. You have to upload this application: http://www.ucapps.de/mios/midio128_v2_1d.zip You should also download MIOS Studio to upload the application. The following link discribes how to do that. (Discription starts at the half of the page) http://www.ucapps.de/mios_bootstrap_newbies.html greetings Markus
Hi also this side on the wiki for a better understandig. http://www.midibox.org/dokuwiki/mios Greetings Markus
Ja, hab ich ganz vergessen, schieb den Regler in Richtung nach unten (Endanschlag). Nun musst du wieder Pin 2 gegen einen der anderen messen. Der Pin gegen welchen du 0 Ohm misst ist ground (-) der gegen welchen du 10 kOhm misst ist +. Beim Einbau musst du nun nur noch darauf achten, dass die Richtung Endanschlag unten auch unten ist. Gruß Markus
Danke, den Rauch mal nicht zu vergessen! Gruß
Hi, ist eigentlich ganz einfach. Du brauchst dazu ein Ohmmeter/ Multimeter. Du stellst den Fader in etwa in Mittelstellung, stellst das Messgerät auf den kOhm Bereich und beginnst wahrlos die Pins gegeneinander zu messen. Wenn es dann 10kOhm (+- Tolleranz) anzeigt hast du die Anschlüsse für + und -. Nun musst du nur noch von einem der beiden Anschlüsse gegen die anderen übrigbleibenden Pins nach und nach messen. Wenn dein Messgerät dabei in etwa die Hälfte anzeigt hast du den Pin der das Analog Signal liefert (Abgriff). Beweg ihn und du wirst sehen, der Wert ändert sich von 0-10kOhm. Kleiner Tip noch, die + - Anschlüsse befinden sich meist gegenüber in längsrichtung. Wenn beim anschließen und späteren ausprobieren der Fader in falscher Richtung den Wert ändert einfach + mit - tauschen. Gruß Markus
Souns like a "software problem". In the midibox menü, there is a menüpoint called PotMode ->Pot Behaviour It sounds like you have changed it from normal mode to snap mode. Snap Mode (Soft-Overtake): When you adjust a knob in Snap Mode, the original setting determines the value until the point where the movement of the knob passes beyond this position. In other words, the parameter does not jump to the value as in Normal Mode. However, keep in mind that your adjustments have no effect on the parameter until the knob "snaps" on at the position equivalent to the original parameter. In SNAP mode, an right arrow symbol appears instead of the parameter bar. It indicates in which direction the knob must be turned to exceed the current parameter value. Arrow Left implies the value is lower. The parameter bar appears when the value is "snapped". With the mk_syx skrypt (http://www.ucapps.de/howto_tools_mbsyx.html) you can change the pot behaviour if you havent got an lcd display and menü buttoms to do it directly. Greetings Markus
http://www.ucapps.de/mios_bootstrap.html
Be glad that there´s no enigma! ;D
Have you tried to disconnect the IIC Modul and only connect the Bankstick? What kind of coreboard do you use?
Have you uploaded Mios? If your answer is yes, check the contrast pot at the coremodul. Greetings
Can you post a picture of your board? Perhaps you have connected it to J8 instead of J9? Which application do you use (Midibox 64, LC...)? Greetings Markus
Hi, I´m not a programmer, but if I understand it right you have to modify the mios_tables.inc . At the moment there are no events in (MT_EOT). So have a look at this applicatin: http://www.ucapps.de/mios/ain64_din128_dout128_v1_3.zip In the mios_tables.inc for example you can read this: ;; 128 buttons and LEDs assigned to MIDI events "B0 00 <value>" to "B0 7F <value>" ;; 64 pots assigned to MIDI events "B1 00 <value>" to "B1 3F <value>" MIOS_MPROC_EVENT_TABLE ;; entry 0x00-0x0f MT_ENTRY 0xb0, 0x00 MT_ENTRY 0xb0, 0x01 MT_ENTRY 0xb0, 0x02 MT_ENTRY 0xb0, 0x03 MT_ENTRY 0xb0, 0x04 MT_ENTRY 0xb0, 0x05 MT_ENTRY 0xb0, 0x06 MT_ENTRY 0xb0, 0x07 MT_ENTRY 0xb0, 0x08 MT_ENTRY 0xb0, 0x09 MT_ENTRY 0xb0, 0x0a MT_ENTRY 0xb0, 0x0b MT_ENTRY 0xb0, 0x0c MT_ENTRY 0xb0, 0x0d MT_ENTRY 0xb0, 0x0e MT_ENTRY 0xb0, 0x0f If I´m right, this is what you need. See also: http://www.ucapps.de/mios/mios_din_dout_pin_numbers.txt Here are the din dout nummbers, you´ll need. Hope that`s all true. Greetings Markus
Hello, with 15V on the J1 port of the core the voltage regulator will get very hot! You forgott to supply the sid modul with 5V from the core. (J2 to J2) Please look here: http://www.ucapps.de/mbhp/mbhp_sid_c64_psu.pdf You use the sid 6581, right? Then 12V are O.K. Best regards Markus
Hallo, du mußt nur das J5 port auf Masse legen. Das ganze machst du am besten so: Lege das Coremodul so vor dich, dass das J5 Port in deine Richtung zeigt. Nun ist der Pin auf der linken Seite Masse (Pin1). Der Pin rechts davon ist +5V. Verbinde nun die restlichen 8 Pins mit Pin 1. Das wars dann eigentlich schon. ;) Gruß Markus
Help needed connecting Smash's SID to Mike's CORE
midiboxxer replied to dubka's topic in MIDIbox SID
Hello, where was the problem with the sid and lcd? The problem with the encoder could be a wrong pinning or the wrong detented mode. I think I saw this in mios_tables.inc ? There you should set the detent or non detent mode. But I have no experience with that. See also http://www.midibox.org/dokuwiki/doku.php?id=encoder_specifications for encoder details. Greetings Markus -
That makes sense, because MD and MU are also connected to the J15 port which goes to the lcd. So you should check the sid board, especially IC2 and IC3. -
Have you added the 2 isolated cables on the bottomside of the pic module? Without the one between J10 PWM and core the sid will not be clocked!
