midiboxxer
    133
Everything posted by midiboxxer
  1. So please post a photo of your sid modul, sounds like an soldering problem. But I will check the pinning tomorrow again, that we 100% know that its right. ??? Greetings Markus
  2. Have you connected all pins like that? Core: Sid: Rc Rc Vd Vc Vs Vs Md Sc PWM Clk So So Mu Mu
  3. You should connect MD from core to SC of sid board.
  4. If I see it right, you have to connect the clock to the PWM. PWM stands for puls wide modulation, with the pwm output from the core you clock the sid chip. On the old sid bord was an crystal which did that, but there were some problems. So TK clocked it with the core to fix this hardware bug. Read about the old schematic like NorthernLightX writes, so you´ll understand it better. Greetings Markus
  5. Hi, have a look at Smash´s homepage for the pinning.
  6. The KS0066 controller is compatible. So it should work.
  7. having sex all day
  8. I take a look at the datasheet, you don´t need the R5 here try 2,2K in stead of 1,2K for R6.
  9. Hi, to me it sound like an problem with the output signal of the optocoupler. Try an smaller resistor perhaps 1K or less. A second thing, perhaps your pic is clocked to slow. So it can be the wrong crystal. But with an feasibility of about 95% it should be a problem with the optocoupler. Greetings Markus
  10. Wow, I hope we can shortly read more about it. ;D Looks interesting to me. (Ableton Live User too!) Regards Markus
  11. Nein, ich glaube du solltest dir das Wochenende mal Zeit nehmen und dich hier über die einzelnen Projekte schlau machen. (links MBHP Projekte) Wenn du dann etwas nicht verstehst oder dir nicht sicher bist kannst du gerne Kontakt mit mir aufnehmen. Gruß
  12. Hi, du kannst ja mal mit einer LC anfangen und wenn du damit fertig bist mit dem nächsten Step deines Projektes weiter machen. (So ne Art Modularbauweise.) Das was du da beschreibst wird aber in der Tat nicht einfach, da steckt einiges an Weiterentwicklung mit drin, zumal du mit dem Midibox Mixer nur Lautstärke und Pan kontrollieren kannst. Weiß nicht ob dir das reicht? Lass dich aber nicht entmutigen. Gruß Markus
  13. Das mit dem sampeln ist als Privatperson nicht mehr so einfach.
  14. The only introduction for the P18 software in english I know is on this side. http://www.ucapps.de/mbhp_burner.html
  15. Danke, gut zu wissen. Gruß
  16. The Joshua Tree - U2
  17. Hi, die bekommst du bei Mike´s Midishop: http://www.mikes-elektronikseite.de/shop_deutsch/xaranshop_20.htm Warum funktionieren die von Atmel nicht? Hab mir das Datenblatt zwar noch nicht angeschaut, sollte aber rein vom Namen und damit auch von der Funktion das gleiche sein. Gruß Markus
  18. Da hab ich bereits geschaut. Finde die Seite aber nicht gerade benutzerfreundlich. Andauernd liest man was von Tabak und Alkohol. Habe auf jeden Fall festgestellt, dass diese Sendung dem Zoll unterliegt. Hab ja auch ne email mit meinen Fragen vor ner Woche an die Zollbehörde geschickt. Bis jetzt aber noch keine Antwort erhalten. Gruß
  19. Also, this panel mount part should work, do you agree? panel mount dc plug. [EDIT] Strike that. This has a split tip. If you find a panel mount 2.1 or 2.5 DC jack, let me know. -d
  20. Deswegen will ich sie auch bestellen. Will mir noch ne Midibox lc bauen und brauch dazu eben core,din,dout und mf Platinen. Als ich die Bilder auf Smash´s Seite gesehen habe dachte ich mir nur, die muß ich haben. Mikes Platinen sind auch nicht schlecht, die habe ich bei meiner letzten MB verbaut. Gruß
  21. You have to change the main.asm for a 2x16 display. But thats no problem. ;; number of visible menu items on LCD ;; use: 4 for 2x16 displays ;; 5 for 2x20 displays ;; 10 for 2x40 displays #define CS_MENU_DISPLAYED_ITEMS 5 see also: http://www.ucapps.de/howto_tools_mpasm.html Best regards Markus
  22. Dachte ich mir schon, dass es so in etwa laufen wird. Danke für den Tip mit mit UPS, hab ich nicht gewusst. Gruß
  23. I have no experience with this project, but when I looked at the schematics I saw the 8 pots. When I´m right, you can adjust the outputrange with this 8 pots. There is a mathematical formula on the schematic. You should check the value of your resistors and then calculate the value of the pots. Best regards Markus
  24. Hi an welcome, to question 1) I can say 12V are O.K. But it doesn´t only depents on the voltage (12V), the PSU should have enought power so it can afford enough current. When you´ll take this PSU you have to stuff a 9V voltage regulator on the sid board (for a 8580 chip) and a 5V voltage regulator on the coreboard. You should have a look at the datasheet of the 5V regulator for the max input voltage, but I think 12V should be O.K. 1B) There are powerjacks which have a thread so you could fix it in your case. 2) You shoud have a datasheet and compare it with the cores specs. 2a) Yes and no, I´ve testet those cables, some of them causes problems in my midibox, the connectors didn´t fit everytime. Greetz Markus
  25. Why don´t you draw it directly in eagle? Eagle 4.16r2 is running on OSX. Best regards Markus
