Antix
    824
    3
Everything posted by Antix
  1. Antix
    Nice PCB deserves nice soldering
  2. is enjoyng his new GM5 midi interfaces that WORKS GREAT!!!
  3. Hi, Does anyone experienced HCT14 Instead of HC14 on GM5x5x5? Saluti Antix
  4. Never want to copy someone else’s status, word for word, and see if they notice
  5. Antix
    From the album: Antix MidiBox SID
    SMT needs only a good solder tip
  6. Antix
    Who's afraid from SMT
  7. is waiting for fresh night for build Midibox stuff
  8. Bello, veramente bello. Beautiful, really beautiful. :D
  9. Hi guys, Just tested on job in these days: Ethilic alchool whith a nails brush to remove flux after distilled water ( or demineralized water ) to remove any stains and streaks leaved by alchool. all these operation i made in little tanks but not submerging boards,I soak the brush and brush the board perpendicular to the liquid surface. I am very positively impressed from the result that is very very professional :thumbsup: Normally I use commercial flux cleaners ( very expensive ) so I think that it will be my stable method of cleaning, cheap and aesily available materials best regards Antix
  10. Heya, PCB just arrived. Nice packaging and very nice PCB color. :drool: Thank You Seppoman Antix
  11. is tanned and feels worry because he thinks Midibox also on the beach
  12. Hi, Anyone used TL084 instead of 074? I am asking because i have a lot of 084 in my drawer and it will be fine use them. Thanks and regards. Antix
  13. Hi I don't understand exactly your problem but I have burned just now four 16F88 with the last HEX file for IIC MIDI and returned any error you enountered.I suppose it is the ultimate firmware. I use EPIC programmer and PICPgm software. Hope you have already solved the problem. Regards Antix
  14. Sorry for delay. On the bender board I have resoldered cursors ( pot ) and other SMD and PTH. The whole cause of malfunction was ( like old philips television ) a degradation of the PTH solderings. You can see , with magnifyng lens , like a little darker circle in the soldering around the pin. After resoldering pins of the cursors aftertouch starts ( restarts ) to work but I gave a little shot to all the soldering on this board. Regards Antix
  15. Hi, Anyone knows why the styroflex ( polistirene ) cap haz a stripe on side? Normally ( what is normality in this world? ) a sidestripe on a el-part may indicates polarity. Regards Antix
  16. Hi Seppoman, Mine is a "big order" too ? Regards Antix
  17. Ok, Thanks I am already sure for the pinning of the connector but not for the compatibility of the application with this board. You have cleared me. So the creative is the worst of the DBoard :hmm: anyway it is a pity put her in waste as I own and works well. :thumbsup: Is there a minimum of schematic for connecting to a core? I am searching on the forum in this discussion but i found only code file of app. Effectively it is a MB64 whith midi out connected to midi in of daughter but if exist a little schematic will be better. Thanks for any information best regards Antix
  18. Antix
  19. Hi, I have a WAVE BLASTER CT1900 with E_mu engine doughterboard. Can be the same or the application is only for DB50? regards Antix
