LenweTasasartir
47 -
Everything posted by LenweTasasartir
If You must press slider realy hard to get any sound it You'll have to replace this fader. I think, you can try to resolder joints of this one first. Replaceing slider can't be to difficult, becouse it's exploitation part.
But what about this ones? LP3875 - 1.5A Fast Ultra Low Dropout Linear Regulator LP3856 - 3A Fast Ultra Low Dropout Linear Regulator It has 0.38 Volt dropout, so it's possible to run +5V stabilised voltage starting from 5.4V!
Yes, there is only LCD connected. 3rd board from video (double sid) is disconnected. I'll check traces tomorrow, because It's midnight in Poland and I don't think to clear. What is being initialised after control surface?
What the "CS" is? I've no LEDs connected, and have disconnected SID board. I'm using Commodore one, which provides 1.7A at 5V and 1A at 9V. It's possible, that I've somewhere short circuit, so It would be nice to know what happens in this moment, which pins and connectors are being probed/changed.
In Poland it costs not more then 2E and can be bought at several brand. I still have scars on my hands after screw which handle blade suddenly got broken. Most wonderfull tool I've ever seen.
Smaller or bigger one? In bigger ones there is just trafo and four diodes - it could be used to power midibox using low-drop pull-down voltage regulators (not 7805). In smaller ("fast" chargers) ones you can find voltage converter which is probably to noisy to audio equipment and couldn't be filtered enought.
I had this one too. It's the worst thing I've ever seen.
Hi I've problem with my core module. It runs midibox sid v2 software on PIC18F4685. It restarts after "Launching CS" (Counter Strike? ^^) screen. http://pl.youtube.com/watch?v=PI5-cURWIbM Have anyone got any idea?
very important info (could save you from a night asleep)
LenweTasasartir replied to cimo's topic in Miscellaneous
Count me in for one ;) -
Hi! I haven't seen sale request from user like "STATTATIVE", but I've just found Midibox SID on Allegro.pl (something like Polish Ebay). I've mailed admins about it. http://allegro.pl/item342956593_midibox_sid.html
Thanks, I've mailed them about that. EDIT: IT'S RUNNING! FUSE SOCKET WAS DAMAGED! IT GIVES SOUND! EDIT2: Ok, replaced fuse socket. But found something bad. Potentiometer or tuning cap has broken core. I'll wait for scheme. EDIT3: It's tuning cap in LC circut...
Hi all! I've just bought Vermona ET6-1 organs (less than 15€!). Unfortunately it didn't work. I'm searching for scheme or service manual. Have anyone got it? Regards, Lenwe
QBAS, Moje plany si? jednak zmieni?y. Dzisiaj jad? odebra? Vermon? ET6-1. Pó?niej b?dzie zabawa z midifikacj? ;)
AndAway, bez ?artów ;) http://www.ckmedia.pl/~jankomuzykant/n/muzykant3/muzykant3.htm Komplet cz??ci jest ta?szy od DIN'a (z Core 4-5 razy), a dzia?a równie bezproblemowo. W?a?nie szukam jakiego? "syntezatora". Interface? Szukam czego? co b?dzie mia?o 2x gameport b?d? 2x com port -> 2 midi in, 2 midi out
Ok, LCD problem solved. E pin was partly disconnected in some way. On LCD interconnection test, after going out from E line test, LCD goes blank. After fixing second SID audio channel, I was going to check how this one sounds. Checked testtone - clear. If done SID interconnection test, i've lower volatages on A3 and A4 (3,5V, but I've uncalibrated multimeter...) , +5 at rest. Unfortunately when I'm trying to start MIDIboxSID app, it restarts on "Launching CS". Thanks for help ;) EDIT: Same without SIDs board. DSCN4166.JPG
Klawki szukam na Allegro, szukam po znajomych, no ale na razie bezskutecznie. Na zmidifikowanym malu?kim syfie, na który mam za du?e palce ?rednio chce si? robi? jakie? post?py ;) Z p?ytkami nie mam problemu, termotransfer i wiercenie dremelkiem sobie ju? obcyka?em. Po prostu pyta?em o to midi, bo mia?em nadziej? wy?udzi? schemat jakiego interface'u, bo ten jest umiarkowany co mam. Projekt p?ytki - tak te? wtedy zrobi?em, bo g?upio by si? by?o nie podzieli? poprawionym czyim? projektem.
Inni te? mieli problemy, pliki s? uszkodzone. Ale uda?o mi si? z podgl?dów zrobi? p?ytki, do tego zamiast dwuwartstwowej, jedno- z niewielk? ilo?ci? mostów. PCB do midi? A mo?e kto? ma lu?n? klawiatur?? Bo szukam pe?nowymiarowej 5 oktawowej w przyjaznej cenie. Mo?e by? uszkodzona elektronika b?d? jej brak.
Hi guys! I've changed MIDI interface to working one, and I'm possible continue creating my MB-SID. Let's begin from LCD: When I power everything on, black bar appears on LCD and after some time it goes blank or... It displays something what's on the photos. Datasheet: http://sklep.avt.pl/photo/_pdf/BTHQ_22005VSS.pdf And SID: I've napierzaza Double SID module with 2x8580's. Testtone runs well, sounds clear, has 1kHz. But if I change app to sid synt, and play something on keyboard it sounds strange. In sounds.mp3 I've attached recording which contains 6 ocataves played from low to high. Have anybody has any idea? sounds.mp3 DSCN4154.JPG DSCN4155.JPG DSCN4156.JPG sounds.mp3
@Thorsten But parts for PIC burner costs around 3 Euro ;) I've built it on vero, and it works well. Price difference between PIC16F and burned PIC18F is much bigger.
4 backlit lcds + 32 led rings. How to power them?
LenweTasasartir replied to Alkex's topic in Design Concepts
So, You have 2A only from LCD's.I suggest temperature desintegrator ;) But... why LCD must be backlighted from regulated voltage?! Can't it be just around +5V? -
IMHO, You can use 3A version of LM7805 - LM78T05. Ofcourse with radiator ;) If 3A is still to low, You can connect regulators together as at picture, or just use separate one for backlight of every LCD -
Hi, I've just burned up MIDI interface at SB Live! (bridged +5 with ground not RX with TX... so idiotic!) and need to change connection way. Becouse I've two spare COM ports at PC, and found LTC module at side I'm going to build it. Can I use LTC with bootstrap loader to upload code? Will baudrate be ok? Can I use other MIDI equipment with LTC? Regards, Lenwe
But there is no problem with topside. I've posted underside printscreens.
No, i haven't. I just know, that MKTs are in shop near my school. Costs around 1,5PLN (1/3 Euro). About sound differences - is it like audiophile tuning? "Change of power cord to gold one provides deeper low, and cleaner high and better stereo"? ^^ EDIT: Prices at Farnell: Polystyrene - €1.69 Polypropylene - €1.51 Polyester - €0.198 Now i know, that polysters are the cheapest ones :p
But this one is in Your PDF ;)
