boops
202 -
Everything posted by boops
a midibox 64 or other? to replace a too much expensive roland mpg 80
boops replied to boops's topic in Design Concepts
thanks a lot ,i understand the general idea...each case..;button,fader,pot,encoder..now i have to detail each info you gave me et ca c'est pas gagné!!!!...merci Monsieur -
After i 've finished a stereo sid ,a fm and the midicv MB;hi i 've planed to build a surface control to replace a roland mpg 80 (rare and very expensive around 1000 euros) to programming my mks 80 roland...two solutions: 1_buy "the interpreter"a little box who convert the midi CC in 62 octets sysex long (cost around 90 euros) +a midibox 64 with a special front panel with each fonction in midi CC . 2_ make a custom app for a midibox64 +special panel ... cheaper and less connections( wallwart ,midi cable),etc. but,for the moment i've just compil some lines for lcd,filter,outng option luckly who work fine...how can i programm this new app..there are these controls: 0-127, on off,and control for 3 choice or four choices(eg lfo tri ,saw,square ,random)i 've got the midi implentation of the mks (62 octets sysex) i don't know where begin in this custom APP ???.thanks for your light ,regards;-)
40x2 Green-on-Black Optrex Displays - ORDERING INSTRUCTIONS
boops replied to fussylizard's topic in Bulk Orders
courage............yep ;-) -
Hey Morten the total was 10 ;) with jook 11
Dear Rasmus where are you???? :( :( :(
thanks ,i am waiting a answer since one week from the moderateur of the mks 80 and jupiter group ;-)is he alive,hope so..i ve got an editor...again thanks very much!!!
Hi all,i am looking for roland mks 80 patches i founded nothing on the web ,(please not the original one),as i haven't got a controller yet,it's not for a commercial use...my adress : boops(dot)secretvibes@laposte.net thanks very much;-)
8) like "amstrong" then we will have the best case ,we can have...we love you so much!!! ;) best regards
Hi all,i am tryng to contact a menber called Rasmus..tk give me a email adress,not working...is there anybody who knows him...i am looking for someone to talk about the mb 64 mks 80 app.best regards
hi all i am looking for this cpu AT89C51ED2,is there somebody wants to sell me one ...best regards
hi all ,some result of my trouble,i 've checked many components after i ' ve desoldered them,following the shematic no problem; ,i 've cuted the +12V rail on a track,also i saw a half of the circuit was fine,cause it is symetric...i desolder all the component in this bad area,first the bipolar area and there was always the shortcut check again and again...but finded nothing ...incredible...i think ,perhaps a mistake in this pcb...(build malfunction?)today i resolder the cv area and i have 8cv and gate but only the the cv 1-4 works in the bipolar option...just an advise for anyone...just cut a track of one of the rails and you will win lot's of time..excuse for my bad english...best regards
we 've founded 3;5 and 14....then i 've tried with my FM psu and as i 've saw the led don't light...i test the out ng alone and find this short cut in j3 and J4 beetwenn c1 ,c2 too...i continue my research..thanks
Thanks for the fast response,the psu is the psu of my Fm and it's works fine..i will check the crucial points and give (i hope) the result...best regards
Hi all,i 've got a short cut between the -12v and the +12 not the ground in my out ng,without IC3,C4i 've rechecked the solders many times(many hours) :) with schematics...no found the question :is it possible that a bad multi tour trimmer(fried) make this short cut? how can i test a soldered trimmer? best regards
hi not boobs please ;)it's boop's....unlucky,nobody for programming a new code... my control surface is not finish yet,i 've just planed to finish it with a ssm 2044 filter...for the moment...best regards thanks ,for the interest....
thanks for your answer,operateur?is it a hardware sampler?THANKS
:o the lead sound !!!!a great example of the two worlds" analog and digital" hope in the future ,compose with a synth like that!!!!!great idea ,beautiful sounds and to finish (i am jealous of your mixer and phone option ;) ) Boop's a siddish fan . Best regards
hi;my +12 V volt mb only works once 2; psu works perfectly ,only happens once a branch opl3 .. the sound is very good though, but I have to switch off and switch once in two :( What can i do ?best regards
Hi all!!my fm works nicely ,missing the cs and a filter Seppoman (thanks seppo)2044 ,that i 've planed to build in...Unluckly it works one time ....when i switch off ,then i switch on, the +12V not working and there is no sound..,i switch off ,then swithch on again and it works fine... etc ...is someone have an idea. of this voltage issue ?(a caps?) excuse my english..best regards
hi the Proof,after a LONG changing home ,my MBFM works,where are you with the new code of the soft? ;)
HI You can find good information here ;) http://www.midibox.org/forum/index.php?topic=7662.msg64774#msg64774 good luck!!! boop's
HI Phil ,sound good ,how do you work?which sampler,fx ,soft etc ;)
Resencement des Midibox, SID et autres projets ...
boops replied to gillesdeshays's topic in Français
@stryd @sasha....Jolis accents!!! 8)
