boops
202 -
Everything posted by boops
ok...it seems that the basics parameters will be useful ,by example the volume cc:7 mod cc :1...i will make a list soon ..;-)
hi,i was busy last days..;i am very interested to control my sid by cc(only this on the P3)...by example resonance,cutoff,lfo rate..etc would you need a list?thanks guys for your works
thanks very much 8) i will try to progress with this informations
thanks but :o ....i have to look for sysex informations.. ???
HI ,i ve planed to build a controller for a old jd 990 ..i find this: For example the following SysEx message turns off Tone 1 on the temporary patch on a JV-1080/JV-2080/XP-50 or XP-80. The checksum 6D is calculated as follows (all numbers are in Hex NOT decimal): F0 41 10 6A 12 03 00 10 00 00 6D F7 ^^ ^^^^^^^^^^^^^^ ^^ ^^ | | | | | | | +-- End of SysEx message marker | | +-- Checksum | +-- Data portion of message +-- Command ID (12 = DT1 - Data Set) (1) Add the data part of the message 03 + 00 + 10 + 00 + 00 = 13 (X) (2) Divide (X) by 0x80 (128 in decimal) and save the reminder which is (Y) 13 / 80 = 0 with remainder of 13 =(Y) (3) Subtract (Y) from 0x80 (128) to give us the checksum 80 - 13 = 6D (checksum) i don't understand the (2)..;some informations please...best regards and happy new years..
Hi Goblinz, knobs are arrived at home....thanks for your work ..Best regards Boops ;)
hi hope you 've received my new adress ,too(by pm)!boop's ;)
cool man!!! :D
how to build a -2,6 v (lcd negative contrast )with the 5v core psu
boops replied to boops's topic in Testing/Troubleshooting
more explanations: -printed the shema with the IC 7660 ,and caps -buy the parts,don't forget the ic socket for the 7660 (or equivalent) -pull off the ics of the core -cut a little piece of veroboard and make a hole (3mm)to install on one hole of the core pcb -desolder with (pompe a dessouder) the P2 (trim on the right on the core,which control the contrast) -build the shematic http://www.modthebox.com/lcdhowto.shtml be careful with caps polarity ,take the +5v and ground on the core where the P2 was soldered,test short cuts,and polarity ,you should have -5v beetween ground and pin 5 of the ic 7660 -ok ,courage ,now solder the P2 on the little veroboard and see the shematic below: -control the negative voltage with the P2 trim.. BRAVO Boop's P051008_13.22.JPG P051008_13.22.JPG -
stryd i 've done exactly that is wrote on the post and use a little my brain ,a paper and a pen too;) f -
hi,i do the job... :o it works ;magic electronic!!! An advice: put the trim p2 on a separate veroboard with the IC 7660 and Caps; be careful with the caps polarity and put off the 18F452...now i attack the opl3 -core connections :P Good night and best regards . -
::) sorry it's doug W. -
thanks folks -
Ping has given me this link http://www.modthebox.com/lcdhowto.shtml thanks but how can i have 2,6v ? -
Hi,cool DG !!!just to say ...there are nice bezels to square caps...do you think it will be possible to order them too? best regards Boops DSC00366.JPG DSC00366.JPG
thanks;i 've learned this too,but 1 or 2 years waiting... ::)
hi,i 've tried my core chip 18F452 with an id 7 and no data on the lcd ..is it possible ..(.like the sid ,i ve build and i've changed the id)that i must have only an id 0? thanks
I play didjeridoo,am i australian? ::) ;)
Hi,friend programmer,,i thought with Reboot (this is his picture) to swap the fm matrix with 24 icecubes and 24 tact switches under, do you think the modification of .ASM (hex)will be difficult -or perhaps impossible)...imagine 24 beautiful icecube switches(blue,red ,or yellow) and with only one finger toggle the parameter ...dream...or reality?i will redesign the front panel for....thanks for your response.. B :) :( P's
group buy for ultracore (core + 4x IIC + 8 banksticks)
boops replied to ultra's topic in Bulk Orders
hi ,ultra,i took my pcbs today ,at reboot's home..very nice work ..best regards -
thanks, (i 've wrote no problem) send me 60 please,i 've refused the refund.....best regards...boop's
hi ,payement done for 60 ,i 've ordered 45...but no problem..thanks for your work Boops
hi,i just discover your work....looking good...i have to use P3....but i am in for one mbSEQ in addition...for a different feeling.very good work..man! ;)
hi i 've cleared two posts... ;)
