Snoozr
146 -
Everything posted by Snoozr
Looks like this guy borrowed some pics from ucapps for his video. (PS - This is not me nor someone I know)
That's what I originally thought too. But the circuit will only draw what it needs, up to the limit of your PSU. Think of it like your bank account. If you only have 500 "milli-euros/yen/dollars/whatever" in there, then you can take out any amount up to that. However, if you try to take out more, you will have a problem. :'( It's better to have a bit extra in your bank account than too little.
I am also a noob but I did some calculations and with my basic setup from Smash, 15v 1A was plenty. If you are worried, it is better to go high on the amps (that's what I did). To get the precise answer, just figure out what you are going to build in terms of options, look at all your components, and then add all your amp draws up. If they are less than 500mA, you'll be fine. If not, you risk damaging something. As far as I can tell, one of the main variables is the LCD you choose. Different ones can have fairly different mA requirements. Good luck ;D
OK - deleting above link to prevent confusion...
I've bought 2 C64's from Ebay and neither of their PSUs supply 9V (they both have four pins but only supply 5V - the 9V is dead apparently. I saw someone said it could be a fuse but I have no idea how to open the brick). So the clean-cut optimized PSU is out for me even though I built it. I have been running one of Smash's Cores plus LCD on a 12V 600mA wall wart. I also can get 5V out of my optimized PSU circuit running off of my Ebay PSUs. So, are there any options that a noob could follow? Here is what I was able to come up with. Buy a second wall wart and run it straight into the SID module from Smash, but TK said 100mA is recommended and I would be way over at 600 mA. Or the current wall wart is actually switchable (12V, 9V, 7.5, 6, 4.5, and 3), so I could buy a second one, switch it to 9V and then add the 5V from the PSU circuit. This would give the optimal 14V as described on ucapps.de (but the mA would be high again). Or I could keep rolling the dice with Ebay. :-\ :-\ Or if it was advisable, I could switch the existing wall wart to 9V (or keep it at 12V), "tap into" the 9V that occurs across J1 of the core, and then I could route that over to the SID. Hopefully the current drain on the core + LCD would take the "tapped" mA down closer to 100. If anyone has any suggestions, I'd be very grateful ;D ;D ;D
Awesome - thanks so much!!! ;D ;D ;D
I learned of Neutrik audio jacks on the SID-NUXX site. The jacks have 6 pins whereas the SID PCB only has + and a - jumpers. It is a stereo jack but not sure why there are 6 pins instead of 4. Anyway, for now I just want to go mono and maybe deal with stereo later. So in absence of information, I thought I would use logic (uh - make that "noob logic"). What I was thinking of doing is running a regular 1/4 inch mono cable out of a Roland into the jack. Play Twinkle, Twinkle Little Star via Ye Olde Sequencer or something. Then I would test the pins with a multimeter to see which is testing positive and negative for the Twinkle signal. After that, when wiring the Neutrik to the board, I would wire the *positive* pin to the negative jumper on the PCB and the negative pin to the positive jumper on the PCB. The reason being is that when testing with the Roland, I would be sending audio *into* the jack, whereas when the jack is connected to the PCB, I would send the SID's audio out of the jack (requiring a reversal of roles). Does this sound right to anyone - or am I cruising for an oozing (of SID components)? I looked at the datasheet (below). However, there is no positive and negative listing of pins on here so it was not informative. I also searched the forum for Neutrik to no avail... http://www.neutrik.com/content/products/detail.aspx?id=210_980737404&catId=CatMSDE_audio/ Thanks!
So what do you like better, your MicroKorg or your SID? ;) ;) ;) Seriously, I bet they go well together.
Good luck with your gig tonight - tell us how it went. Usually I would say 'break a leg' too but not this time with your surgery. How about 'heal a leg' ;)
Thanks, Stryd, you're the best!!!! ;D ;D ;D As for your question, I probably didn't express myself very clearly. I read the page http://www.ucapps.de/mios_download.html and knew that this file would test the Core. From the associated readme, I read: Revision ID V1.0 =============================================================================== Copyright © 2006 Thorsten Klose (tk@midibox.org) Licensed for personal non-commercial use only. All other rights reserved. =============================================================================== This program displays the Revision ID of a PIC18F and sends it also via MIDI as CC# event Known numbers (mostly documented in the errata sheets of the PIC devices) - 0427: PIC18F452 C1 Silicon (latest and greatest) - 0C03: PIC18F4620 A3 Silicon (contains EUSART bug) - 0C04: PIC18F4620 A4 Silicon (contains EUSART bug) - 0C06: PIC18F4620 B4 Silicon (the good one w/o EUSART bug) =============================================================================== I was expecting to perhaps see one of these numbers (actually, since my PIC number was not listed as a known number, I was not quite expecting to see one of those - however, since the last three revisions have sequential numbers I thought perhaps I would see 0C07 or 0C08). I did not quite expect 00000000871353 ms | [b0 27 61] Channel 1: CC LSB 7 (Channel Volume) value: 97 Anyway, I will try that search on 4-bit like you said. I really do appreciate that it does take your (and others) valuable time to answer noob questions and so I have and will continue to read as much as possible and take things as far as possible before even considering to post. Thanks again!
Hi everyone. I put together a core using Smash's kit. There is a sticker on the PIC18F4685 that says BSL V1.2B MIOS V.19F. So I guess I don't have to upload those as mentioned here http://www.ucapps.de/mios_bootstrap_newbies.html. I thought I would give it a revision_id_v1a.zip test as mentioned here http://www.ucapps.de/mios_download.html I was expecting to get the Revision ID back as a CC. I got a CC but I don't know if this is right. I have an LCD but it does not really show anything except it has a blinking cursor. No text yet. Could be a bad wiring job so that's why I thought I would test first. Anyway, here are the upload logs and what I got back. Starting upload of main.hex Sending block 00003000-000030FF Received Checksum: 38 - OK Sending block 00003100-000031FF Received Checksum: 60 - OK Sending block 00003200-000032FF Received Checksum: 40 - OK Sending block 00003300-000033FF Received Checksum: 60 - OK Upload process complete Now here is the Midi Monitor In log. The first line is the "Hello World" from the PIC. After that is what came when I uploaded the test. 00000000029189 ms | Sysex message: F0 00 00 7E 40 00 01 F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 00 00 20 43 7B 63 1F 04 23 5E 19 78 22 3D 71 4F 42 15 6F 0C 7C 11 3E 78 67 61 3E 77 46 3E 0C 3F 3C 33 70 64 3B 63 1F 06 17 5E 19 78 31 5D 71 4F 43 13 6F 0C 7C 18 2E 78 67 61 41 77 46 3E 0B 7F 3C 33 70 60 3B 63 1F 04 03 5E 19 78 20 3D 71 4F 42 05 6F 0C 7C 10 3E 78 67 61 44 77 46 3E 0C 1F 3C 33 70 42 3B 63 1F 04 17 5E 19 78 21 5D 71 4F 40 24 00 00 00 02 20 00 00 00 12 00 00 00 01 10 00 00 00 09 00 00 00 00 48 00 00 00 04 40 00 00 00 24 00 00 00 1F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 38 F7 00000000864544 ms | Sysex message: F0 00 00 7E 40 00 0F 38 F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 20 00 20 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 60 F7 00000000864660 ms | Sysex message: F0 00 00 7E 40 00 0F 60 F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 40 00 20 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 40 F7 00000000864779 ms | Sysex message: F0 00 00 7E 40 00 0F 40 F7 timestamp [unknown] | Sysex message: F0 00 00 7E 40 00 02 0C 60 00 20 09 00 02 20 00 48 00 12 00 04 40 01 10 00 24 00 09 00 02 20 00 48 00 12 00 20 5D 41 37 41 5C 0E 7B 1B 46 30 77 5D 5D 1E 76 05 5E 04 00 3A 11 6C 0B 3C 1E 29 77 78 1D 76 37 3F 61 6F 3B 38 7E 0E 7C 1B 41 10 07 57 1E 06 78 02 20 0F 2E 3C 0F 70 7C 1A 5E 28 70 1D 21 18 76 05 5E 00 32 42 31 6C 0B 3C 16 00 71 13 58 16 78 01 6A 07 78 2C 49 6C 0B 3C 00 65 03 7C 16 24 76 05 5E 01 10 00 00 0C 29 19 2E 66 4B 4D 52 6F 37 08 09 14 21 68 24 00 09 00 02 20 00 48 00 12 00 04 40 01 10 00 24 00 09 00 02 20 00 48 00 12 00 3F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 7F 78 60 F7 00000000864933 ms | Sysex message: F0 00 00 7E 40 00 0F 60 F7 00000000867238 ms | Sysex message: F0 00 00 7E 40 00 01 F7 00000000871353 ms | [b0 27 61] Channel 1: CC LSB 7 (Channel Volume) value: 97 I have no idea if this test succeeded or failed. Once I figure that out, I will start trying to make sure the LCD works. I was thinking I would see some text or something. Thanks for any help! I know this is pretty basic but honestly as a noob I am pretty happy I got this far. ;D
Cool. My favorite part comes in around 4:55 and goes for the next minute or so. That part has the most movement for me. I would never be able to tell that's not a real TB...
LEET! ;D ;D ;D That break almost kicked me across the room ;)
Nice! Very distinctive and well done ;) Good songs, good production - you guys are going to do well. The guitar at the end of 'I Fell Off My Name' has a little bit of that New Order bassline feel (Logos too). I was always a sucker for those cool basslines.
Something new to emulate some day? Note this is the analog one - there is also a digital one coming out. Given the heritage, I am reallllly curious to hear this. http://www.rogerlinndesign.com/products/linndrum2/ (I can barely solder so please don't delegate this project to me ;D.) PS - they are hiring software people ;D
Gorgeous! And very patient for 5 years!
Thanks for the warm welcome. Tell you what - I will make an analogous one (with a link to the original one as a citation credit) and then incorporate it into the wiki like you said. That way, it can be updated/corrected (plus, I get to contribute something instead of just lurking ;D). I will also post my Mouser order #s kind of like Smash has. I liked that guide because I can handle "monkey see, monkey do". I am still working on the "monkey read electrical schematic/CAD diagram/etc., monkey build a prototype in his head". ;D Hopefully I won't burn anything up with my Mouser #: 625-W08G-E4 bridge rectifier. PS - thanks also to Wilba whose design is so cool I just *had* to give it a try.
Hi all, I'd like to nominate this for a MIDIbox SID sticky. I just spent more time than I care to say trying to figure out how to approach the PSU (since I am just a musician [no electronics skills], sometimes this all looks like Japanese to me ;D). In fact, I would also like to nominate this (or something like this) as a link inside the MBSid Walkthrough page. http://www.danielprice.org.uk/synth-diy/sid_2.htm Thanks (and massive thanks to TK for all of this!) PS - this would probably cut down the number of noob questions that the Moderators have to answer....
Hate it when I triplecheck all the connections on something and it's still bad. In this case, it was the LCD and I mistranscribed the pinouts. So for anyone else remember it's 1 16 2 15 3 14 4 13 5 12 6 11 7 10 8 9 not 1 9 2 10 3 11 4 12 5 13 6 14 7 15 8 16 So the numbering proceeds in a U-shape, which wasn't what I am used to. Fortunately, my LCD (shown here) survived the abuse and after rewiring it was fine.
Finished soldering base-now what
Snoozr posted a blog entry in Snoozr's Notes on Building an MB-6582
Here are a few things that caused me to have a little head-scratching on my journey to an MB-6582. The documentation from the parts and the base PCB construction guides is great but after that the hand-holding dies down a bit. So here are a few things I had to look up ... maybe this will save someone the trouble. Finding the wiring schematic for the LCD should be high on your priority list after the base PCB is done. If you zoom in, you can see a copy of it here in the first figure of page 1 on the right. http://www.midibox.org/users/jim_henry/building_a_midibox_lcd_cable.pdf This is J15 on the core and the pinouts are labeled (pretty microscopically but they're there). Note all the data pins (D0-D7) are on the left column of J15. Once you get a working LCD, download the MB-6582 application from here. http://www.ucapps.de/mios_download.html The one I used was midibox_sid_v2_0_rc35.zip but this may be out-of-date after a while. Install it with MIOS Studio. A walkthrough's here: http://www.ucapps.de/mios_bootstrap_newbies.html I actually corrupted a PIC by stopping the application halfway through. The symptom - the PIC kept asking to upload by sending the upload request sysex string over and over every minute or so. Solution: back to the downloads and got the MIOS file mios_v1_9g.zip. Uploaded it with MIOS Studio. It was normal after that (LCD says MIOS V. 1.9f, then READY). Re-uploaded the MB-6582_setup.hex file and that was it. Success means it says Midibox Sid v... after the MIOS part. If you have other troubles at this step, might be worth checking out http://www.ucapps.de/howto_debug_midi.html
