422 -
24
Everything posted by jjonas
I have 2 x SwinSID nano, which I bought here: http://retro-donald.de/sinchai-shop/index.php?main_page=product_info&cPath=3&products_id=90 If by firmware version you mean that of the swinSIDs, I don't know. (I bought them some time last year, autumn maybe.) My MBSID firmware used to be v2.0RC38, but as of today it's v2.040 (compiled with swinsid options enabled + cloning).
Hi, I have swinSIDs only on slave core 02. I performed the firmware cloning operation, but the situation is still the same as previously. One separate question about cloning: as 8580 and 6581 have their own hex files, how come it doesn't hurt (or does it) to clone the one uploaded to the master core (which has e.g. 6581s) to the slaves as well, when the slaves might have 8580s..?
Hi, thanks for the confirmation that this is what is to be done. Based on this newfound conviction I double-checked what I had done, and indeed I had only edited the setup_8580.asm but not the setup_6851.asm in addition. Now that I edited also the latter, recompiled and uploaded it, the new options appear, and I can also choose the extra waveforms (called Ns1-7). BTW is it necessary to update only the master core, or also the slaves? However now the question is what the new options do, and how the new waveforms operate. It doesn't seem to be covered in the MBSID manual (there's a swinsid review there though). With a 6851 the new waveforms don't make a peep (not a big surprise there), but with a swinSID the new waveform sounds are the same as they are with a 8580 - they sound like the normal noise waveform. Changing the SwM and SwP variables doesn't do anything. Is there something else I still need to do? For example do the jumpers on the swinSID matter? I have them both removed. Thanks!
Hi, there's two entries in setup_[8580/6851].asm (rc38) on swinSID-related options: ;; 0: SwinSID extensions disabled ;; 1: SwinSID extensions enabled #define DEFAULT_ENABLE_SWINSID 1 ;; 0: only waveform 0-8 selectable ;; 1: waveform 0-15 selectable (e.g. for selecting additional SwinSID Waveforms) #define DEFAULT_ENABLE_UPPER_WAVEFORMS 1 I have three cores in my MBSIDv2: core00 with 6581s, core01 with 8580s and core02 with swinSIDs. I've updated cores 00 and 02 (maybe only 00 would have been necessary?) with the recompiled hex with above modifications, but I'm not able to choose swinSID waveforms. Is there other stuff I need to do apart from changing these two lines? In the wiki a search for "swinsid" yields only one entry that mentions it, but even that doesn't really deal with the matter itself: http://www.midibox.org/dokuwiki/doku.php?id=changing_the_order_of_items_in_menu_pages However based on this it looks like two new entries should appear in the OSC menu if swinSID is enabled, but that doesnt' happen. Am I missing something?
Thanks for the replies! By MBSID application do you mean setup_6581.hex and setup8580.hex..? If so, I'm not sure of everything I need to do in order to compile the modified source successfully. I guess I have all the raw material from the midibox_sid_v2_0_rc38.zip, but from there on I'm not completely sure what I have to do. There's some advice in http://www.midibox.org/dokuwiki/application_development, but the most detailed advice seems to be for Windows, and I'm on Ubuntu 11.10. I have installed sdcc and gputils. Do I need to have MIOS sources as well (From http://svnmios.midibox.org/listing.php?repname=svn.mios&path=%2Ftrunk%2Fmios%2F)? Or if not, what is the advice for Ubuntu 8.04 referring to with MIOS_PATH="/YOUR/PATH/HERE/mios/trunk" MIOS_BIN_PATH="/YOUR/PATH/HERE/mios/trunk/bin" MIOS_SHELL="/bin/bash" There's a lot of stuff in the folder of the unzipped midibox_sid_v2_0_rc38.zip, how will make know what to do..? You bet these won't be the last questions, but thanks for your patience :-)
Hi, I tried searching the forum for "button press delay", but didn't find an answer to my question, so here goes: My problem is that sometimes (too often) when I release a pressed button, the MBSID takes the release as a button press as well. I guess this has to do with the mechanical property of the springy buttons, so I was wondering if there is something I could do software-wise - basically change some number in a line of code, as I cannot really code anything myself - to increase the delay between button presses so that when the contact disc in the button is springing up and down during release, the MBSID would not interpret these as a button press. I don't know how much this delay is at the moment, but taking as reference ladyada's arduino button tutorial, a millisecond would seem like an ok delay..? http://www.ladyada.net/learn/arduino/lesson5.html (section 'Brooklyn Debounce')
Hi, for those of you who know more about the SID, is there a good patch in the preset patches to test whether the SID filters are working properly? I found out recently that the filters of one of my 6581s are not working, i.e. it goes silent when you put the filters on, but works fine as long as they're off. Is it enough to test them with any filter setting, or can there be more subtle and devious faults that can be revealed only by certain settings?
From the album: jjonas - midibox SID
I put a headphone jack in the back, and this knob controls the volume it puts out. -
Finally I got myself some knobs, some Dutch guy was selling these for real cheap on eBay, about 20c a piece. I had to shorten the encoder shafts and drill the knobs a bit deeper, but they are firmly in place. Should they fall out I can always re-fasten them with hot glue.. -
Originally I though to keep the PSU and 4th core separate (like when the PSU and the external unit were in separate boxes), so that the PSU would feed the voltage into the synth, and then a separate cable would bring it back to the 4th core; there would need to be a cable coming back from the synth anyway for audio/CAN etc anyway, and there was enough pins. But apparently the voltage loss was a tiny wee bit too much, like I think it was already with the first external unit, which sometimes worked, sometimes didn't; I'm not 100% sure this was the reason, but all problems disappeared when I fed the core 5VDC straight from after the PSU's regulator. With the 6581s run by the core and their 12V it didn't matter because there was enough voltage to lose even when bringing it in with the cable from the synth. --- The earlier PSU had the problem of getting hot, I don't know if it was too much or not, but anyway with this the regulator is attached to the 1541s original cooling element, which in turn is attached (with silicon paste in between) to the metal frame, which should have enough surface to cool the regulator :-) I put a fan there for just in case as well :-) -
I managed to re-use the original labels in the back, and all of the back stuff (switch, fuse, mains in) is functional as well. -
I ditched my self-built PSU along with the exteranal unit for the 4th core in order to fit them both inside an old 1541 disk drive. It's bulky, but it's handier having only one external thingy in addition to the synthesizer itself - plus it fits the theme perfectly! I painted it black like the synth. Naturally I had to remove the actual drive, but I managed to preserve the latch that holds the disk in place while it's in the drive by gluing it into the front panel from inside. So too bad it doesn't move, but it looks more real with it in place :-) -
I have the output of all the SIDs going to R and L mono jacks which I connect to a multitracker for recording purposes, but it was too cumbersome to mess with the multitracker set up just to play with and test different sounds (i.e. most of the time), so I built in a stereo earphone jack parallel to the R and L jacks and a global volume knob (10k log) for it so that I don't need to connect anything external to the MBsid (apart from earphones) in order to use it. For this kind of use there's no need for extra amplification, in fact without the volume knob it was too loud and I needed the knob to be there to lower the volume.
Personally I wasn't aware that Retro-Donald's design should be improved, so I too am interested in orange_hand's suggestions; myself I can't really design anything too complicated, even though I can read schematics ok and implement other people's projects. Retro-Donald's design seems better than the C64 original though. Here's what I built. From the outside: ..and inside. The toroid is under the rubbish PCB.
Here's two pics of and old PSU which I opened to see whether you could build a new one inside it. Verdict: not really. Here's the "transformer side". The regulator is mostly inside the glue or whatever, so in practice it cannot be replaced. The fuse is on the mains side. Here's the PCB. Check out the rectifier :-) I built myself a new one out based on a toroidal transformer I found at work, and retro-donald's design (http://www.retro-donald.de/pages/hardware/basteleien/powernetzteil.php). The toroid puts out almost 11VAC per coil (nominally 9VAC), so there's a lot to regulate after rectification (15VDC->5VDC); the total power consumption of a 4-core MBSID is about 18-19W, and the cooling element of the regulator gets very hot (you can't touch it longer than a few seconds after half an hour). I also had to put a small cooling element on the regulator inside the midibox which regulates 16VDC->9VDC, which doesn't get too hot though. (Will send more pics when I get home!) The regulator I used can take 2A, and according to my measurements a 4-core MBSID with completele control surface doesn't exceed 1,5A (on the 5VDC side); I guess I'm going to consider a bigger cooling element just to make it sure.
This is why I had to start building an external unit.. what a mess! -
This is the external unit from the inside. In addition to the expected core+2SID there is, on the lower left corner, an LED to signal the thing is on :-) plus in the upper left corner a socket for external audio (which isn't working at the moment). -
Having used individual PCBs for all core & SID modules, I could fit only three cores + six SIDs (plus CS stuff) inside the Commodore64 box. However I managed to get around the problem by building the 4th core inside an old digibox shell, which is connected to the main unit through one of the original c64 9-pin connectors; nine pins was just enough to make all the necessary connections: (1). GND, (2). 5 VDC, (3). 14 VDC, (4). Audio GND, (5). Audio L, (6). Audio R, (7). CAN bus, (8). J11:1, (9). J11:2. It's no hot-pluggable, attempting to do so will result in a reboot. -
Hi, just for the sake of information (and hey, isn't sciencific progress about independent verification of testable hypotheses ;-), I had similar kind of problems, and it helped me too just to reflash the firmware; I reflashed both the MIOS and 6851.hex, so I'm not sure which one of them was the critical one, but anyway it helped.
Last weekend I taught myself to use the drum and bassline engines of MBSID, and this was the outcome.
Problem solved! Apparently it was a matter of one solder bridge in one of the 8580 SID modules. Earlier I think though that I couldn't get either of the 8580s working even separately, but never mind :-)
