280 -
7
Everything posted by John E. Finster
Hi, I feel kinda silly to ask. I´m pretty sure I missinterpreted some of the infos in the manual or I overlooked a setting somewhere. My problem is that the action "end" is not stopping the sequencer. It displays the correct song position on the right side of the song page (the position i assigned the action "end" to) but it keeps playing the last song position over and over again. - I am using "song mode", not "phrase mode" - The sequencers clock is set to Master - the current firmware 4.079 is loaded on an LPC17 core - I am using a Guide Track since the length of the patterns are 96 beats What did I miss? Thanks and greets
Trying to order a SEQ V4 parts... confused..
John E. Finster replied to mutascan's topic in MIDIbox SEQ
Hi and welcome, it partly depends on where you´re located and what electronics dealers you have access to. PCBs you can get from SmashTV. Here you can either get a "standard" (Wilba) SEQV4 PCB, although I think it is not available at the moment. Or you can get seperate DIN, DOUT, DIO-MATRIX PCBs, if you plan to build a custom SEQV4. Either way, you definitely need a LPC17 CORE PCB from Smash and a LPCXpresso board from Mouser/Watterott/Lextronic/Ebay... depending on where you´re located. There will be another, faster CORE MODUL available in the future, but I´m not sure, when this will be. For now, the LPC17 CORE will be the one you need. If you choose to build a "standard" SEQV4, then you have to get some specific parts which fit this specific hardware design (like buttons, caps, encoders). More info about those specific parts and where to buy them can be found on Wilbas wiki page here. There you can also find more infos about the hardware design and how to build it. If you choose to build a custom SEQV4 (after your own design ideas), then you´re more or less free to buy any kind of buttons, encoders, ... that suits your functional and aesthetic needs (within the regular Midibox hardware requirements of course). For the rest of the electronic components (resistors, diodes,....), you can refer to any kind of electronics dealer of your choosing, depending on where you´re located. If you want to build a custom SEQV4 you can normally buy the other parts (buttons, encoders,...) there too. You also need two 2x40 character lcds (HD44780 compatible) which can be best found on ebay for a reasonable price. Hope it helps. If you have more questions, just ask. my regards -
Hi, maybe you are looking for something like this Above the tracknames I created a small bar indicating the vpot position. I did this by creating some custom fonts for Midibox NG, which is running a mackie clone script. But I experienced some problems with mackie control protocol and ssd1306 displays. You can read about them in this topic I was able to resolve some of the problems myself, but not all. Unfortunately I ran out of free time after that and wasn´t able to get back to them yet. Maybe the newest NG firmware fixes the remaining problems, but I can´t rule out technical issues either for sure. greets
transponierbare pianotastatur mit Buttons realisieren
John E. Finster replied to Paru01's topic in Deutsch
Wäre es nicht möglich, das mit einem Conditional Event zu realisieren, so als workaround? Also etwas in der Richtung: # normale Oktave EVENT_BUTTON id=1 type=NoteOn chn=1 key= 20 EVENT_BUTTON id=2 type=NoteOn chn=1 key= 21 EVENT_BUTTON id=3 type=NoteOn chn=1 key= 22 EVENT_BUTTON id=4 type=NoteOn chn=1 key= 23 # Oktave - 1 EVENT_BUTTON id=1 type=NoteOn chn=1 key= 10 if_equal=Button:5:1 EVENT_BUTTON id=2 type=NoteOn chn=1 key= 11 if_equal=Button:5:1 EVENT_BUTTON id=3 type=NoteOn chn=1 key= 12 if_equal=Button:5:1 EVENT_BUTTON id=4 type=NoteOn chn=1 key= 13 if_equal=Button:5:1 # Oktave + 1 EVENT_BUTTON id=1 type=NoteOn chn=1 key= 30 if_equal=Button:6:1 EVENT_BUTTON id=2 type=NoteOn chn=1 key= 31 if_equal=Button:6:1 EVENT_BUTTON id=3 type=NoteOn chn=1 key= 32 if_equal=Button:6:1 EVENT_BUTTON id=4 type=NoteOn chn=1 key= 33 if_equal=Button:6:1 # zwei Oktavenumschalter EVENT_BUTTON id=5 type=CC CC=1 chn=1 range=0:1 button_mode=toggle EVENT_BUTTON id=5 type=meta meta=RunSection:1 button_mode=OnOnly EVENT_BUTTON id=6 type=CC CC=2 chn=1 range=0:1 button_mode=toggle EVENT_BUTTON id=6 type=meta meta=RunSection:2 button_mode=OnOnly und dann noch zusätzlich im NGR Skript if ^section == 1 set BUTTON:6 0 endif if ^section == 2 set BUTTON:5 0 endif um die Oktavenumschalter wieder auf 0 zu setzen, wenn der jeweils andere Oktavenumschalter gedrückt wurde. Beiden Oktavumschaltern könnte man natürlich noch ein LED oder LCD Event zuweisen. Zum Aktivieren der "normalen" Oktave müsste dann halt wieder der zuletzt betägte Oktavenumschalter betätigt werden. Oder alternativ einen anderen Button auf dem Controller (vlt "Oktave zurücksetzen"). Ich gebe zu, ein dediziertes Metaevent wäre sicherlich eleganter :smile:. Aber als vorrübergehende Lösung könnte ich mir sowas vorstellen. Gruß -
Hallo und willkommen, Potis und Endlosregler findet man gut (und relativ günstig) bei Reichelt.de. Bauelemente -> Passive Bauelemente -> Potis und Trimmer -> Potis oder Drehimpulsgeber Da gibt es auch alle Varianten (mit/ohne Taster, Endlosregler gerastert/nicht gerastert, ...). Ob es allerdings Potis mit Mittelstellung und Taster gibt, weiß ich nicht. Im Zweifelsfall auch einfach Google oder Ebay fragen. Was Du sonst noch so brauchst, sind natürlich noch die "Innereien": Prozessor LPC1769 Core Modul, DIN Module für Endlosregler, AIN Module für Potis, evtl. DOUT Module für Leds,... Schau Dir mal die verschiedenen Module auf ucapps.de an, die sind dort sehr gut beschrieben inklusive vollständiger Bauteileliste. Platinen für die Module kannst Du bei SmashTV (midibox-shop.com) oder bei Mike (mikes-elektronikseite.de) kaufen. Bei Fragen bist Du hier im Forum immer gut aufgehoben. Viel Spaß
Ich hätte es fast vergessen. Diese Knöpfe passen nicht richtig, wenn man die Potis/Drehregler nur durch ein m7 Loch durch die Frontplatte führt und der Schaft zu kurz ist. Ich musste die Knöpfe unten ein wenig abschleifen, damit sie richtig auf den Schaft passen. Ih habe Bourns PEC12 Encoder verwendet.
Die Cliff K88 habe ich bei meiner Midibox verbaut Die sehen zwar gut aus, sind in der Bedienung aber nicht die Besten. Die Oberfläche ist sehr hart, glatt und "slippery" (mir fällt grad nix anderes ein) und nicht besonders griffig. Man muss schon relativ kräftig zupacken, um die angemessen zu bewegen, was ich einfach als unangenehm empfinde. Liebe Grüße
Wie die Stecker auf den Flachbandkabeln angeordnet, gedreht, geklappt und sonst wie sein müssen, bringt mich auch immer wieder durcheinander. Schau Dir mal die beiden Bilder hier an Bild 1 Bild 2 und schau mal, ob dein Kabel genauso verbaut ist wie auf den Bildern. Das Display ist von den Pinnen her 1:1 kompatibel, wie Thorsten sagt, daher müsste Dein Anschluss genauso aussehen. Wenn Du das Display so angeschlossen hast und es immer noch dunkel bleibt, dann spiel mal ein wenig mit den Potis, die rechts und links neben J15 verbaut sind. Die regeln Kontrast und Helligkeit. Liebe Grüße
Well, I guess I have to keep lookin´ then... Thank you very much for your input. my regards
The ebay offer doesn´t state what display it is, just that it´s ks0108 compatible here. But I looked up the number visible on the back of the screen and found a matching datasheet here. On that a T6360C is listed as the controller.
Too bad... Just another box of scrap for the junkyard :happy: . Thanks for the info. Are there other alternative graphical displays this size with at least 240px width? The old KS0108 with 240x64 pxs can not be found anymore so it seems. There are some KS0108 compatible with 240x128 pxs on ebay at the moment, would they be compatible? I almost bought some of them but after the other conversation about the KS0108 displays not being selected with the normal lcd_parameters I´m not so sure after all. my regards Edit: Sorry, just found out, that these 240x128s are also based on a t6369c controller, but are sold as ks0108 compatible. Oh well...
Hi, I´m sorry to barge in on the current discussion, I have a display related question but don´t want to open another topic for that. Are T6369c displays supported by MB_NG? I´ve noticed there are some drivers available in the mios modules section. I have some of those laying around and would want to use them for at least 2 future projects I´m planning out right now. Thanks my regards
Oh, ich dachte, das zweite Byte sei die Device ID :sweat: . Wieder was gelernt...Danke.
Mackie Control sendet keine Sysex Daten, sondern einfache Noten (Zumindest für die herkömmlichen Funktionen wie Transport, Mute/Solo/Rec,...). EVENT_BUTTON id=1 button_mode=OnOnly type=NoteOn key=58 ports=0100010000000000 Das hier sendet einfach die Note 58 (A#6). Das Mackie Protocol im FL Studio sollte diese Note erkennen und Play starten.
Ok. Schade, dann hat das so nicht funktioniert. Die Sysex Befehle sind standard MMC Befehle, ich dachte, man könnte die einfach mal in FL Studio "reinschmuggeln". Wie ich Dir auch schon per PM geschrieben habe, könntest Du vielleicht das Mackie Protocol nutzen. Bau mal ein paar Button Events mit den Noten 55 bis 59 55 Rewind 56 Forward 57 Stop 58 Play 59 Record und schicke die über einen anderen USB Port raus. Im Fl Studio bindest Du diesen USB Port dann mal als Mackie Controller ein und schaust mal, ob die Transportfunktionen funktionieren.
Hast Du deine Midibox als generic controller im FL Studio integriert?
Sorry, hab´vergessen: Ein Sysex Stream im MB_NG muss in einem anderen Format gesendet werden mit "0x". Also so: stream="0xf0 0x7f 0x06 0x02 0xf7" für Play. Versuch das nochmal.
Hi, what size are your displays? 128x64? If so, you have to set up the display size in bootloader to lcd_width 128, so you have to set this parameter to the size of one of your displays in a chain. With lcd_num_x (or _y) you define how many of your (128px wide) displays you want to use. my regards
Versuche es mal damit, Ich habe mal ein wenig recherchiert und bin hierüber gestolpert: Sende mal per sysex F0 7F 06 XX F7 Für XX setzt Du dann ein 01 Stop 02 Play 04 Forward 05 Rewind 06 Record Gib uns eine Rückmeldung, ob´s funktioniert hat. EDIT: Ach so, wie Du mit MB_NG Sysex senden kannst, findest Du im Manual.
Mackie Control + Extension with Midibox NG
John E. Finster replied to schoko11's topic in MIDIbox NG
Hi Klaus, I think the problem is not so much the touchsensor circuit. The MF_NG module already has 8 available touchsensors on board. Theoratically you could hook these up to any kind of metal object. The problem is to attach a touchsensor cable of some sort to a moving object like the fader without disturbing the fader functuality. my regards -
Problem beim Compilern Error "BUFLCD_DeviceFontHandlingEnabled"
John E. Finster replied to TOKEN_one's topic in MIDIbox HUIs
Hier funktioniert es jetzt :happy: . Liebe Grüße -
Hi again, Once you built the moduls (DIN, DOUT, AINSER) you can connect almost everything directly to these modules without using anything "extra". Everything important is already on the midibox modules. Take a look at the different module descriptions on ucapps.de, there is always some kind of example schematic of how to connect hardware elements. Just make sure you´re using the right module for the right component (DIN for encoders and buttons, AINSER for faders an pots, DOUT for leds, MF_NG for motorfaders, ........). So, yes, a breadboard can be easily used for Midibox development. my regards
Hi, unfortunatly I have no experience with Logic or Protools, so I can´t really tell, if what you are planning to do, is doable. But this sounds like a good plan. I suggest you start by building a LPC core module and a DINx4 module and connect some encoders and buttons. I highly recommend that you get some kind of LCD display (e.g. character display), you can get those for around 10 bucks on ebay. It´s freely programmable with the MB_NG firmware (labels, static text, values in various formats) and it provides valuable information for debugging and experimenting. Don´t focus on one plugin in particular too much for now. A Midibox_NG is able to controll your whole DAW with just a few encoders and buttons, if you want it to. Try to experiment with other plugins and the mixer too. If you have questions, just turn to the forum, there are a lot of nice folks here who can help. my regards
Hi and welcome, I would rather go for the newer Midibox_NG project. The Midibox64E relies on the "old" 8bit PIC core module, while the Midibox_NG uses the current 32bit LPC core module. Although it is still possible to use the old stuff, you would be much more flexible and much less limited using the new NG project. If you want to use RGB Leds, you have to aim for a new 32bit LPC core anyway because afaik those are not supported by the 8bit system. Unfortunatly metering capability have not been officially implemented in the MB_NG firmware, but this will come sooner or later. There are already several attempts made for that to work, but there is still some work to do. And for meters to work you would have to use an appropriate midi protocol inside your daw (like mackie control or logic control). Maybe you could describe your setup a little more. Which DAW? Which plugins? That could help specifiing your controller requirements. my regards
Ich bekomme die gleichen Fehlermeldungen beim Kompilieren, kann aber auch nicht sagen, woran es liegen könnte. Vielleicht liegt es daran, dass es schon ein ziemlich altes Release ist. Wenn Du ein Logic Control emulieren möchtest, kannst Du aber genauso gut die MB_NG Firmware benutzen und ein passendes Script schreiben. Bis auf das Metering kann so ziemlich alles bereits realisiert werden.
