Lamouette
    369
    4
Everything posted by Lamouette
  1. Thanks for the info ! Have fun ! :afro:
  2. Yes, also, for the front panel, check with the beastUk, he already do some front panel for midibox, maybe ha can give us a better price
  3. Ok, cool ! :smile: What about the faders ? They can control some parameters on the seqv4 ? or can control external cc via the seqV4 out ? Can we use them to record cc automation in the SEQV4, so maybe it will need a proper firmware ? What about adding a joystick on the bottom ot the 4 faders ? i have no idea about how the software side works... but i could be in ! :rolleyes:
  4. That really awesome, what a work ! What is the mcd for the leds ? did you tested this outside on a sunny light ? are the colors visible ? also, how it works with rear connector, all the data can passe by the midi port ?
  5. interrested in one pair too
  6. Awesome work, love the BLM/TPD integration ! How can you use the BLM side to side with all this Midi outs and a TPD ? can you provide a scheme for the connectiosn between the differents boards/modules ?
  7. the hole size looks large enough to put 2 smd led on it, but the problem is to get powered enough led, looks like you need something like 10000mcd to get something visible by day, but impossible to find smd alternative.
  8. TK said to me that the BLM use the 2nd I/O port, so you cannot use it. (in my case i added a Aout_NG)
  9. I thougt i could connect up to 4 Midi I/O, so i can use one for the BLM. But in case of the use of a quac IIc with BLM port, and only one Midi I/O, i have just to connect the BLM port on J2 of the midi I/O ?
  10. I have also 2x RLE8x2 to sell
  11. Up ? Maybe i could live with only one MIDI I/O
  12. Updated : Filter factory & Shruthi XT pcb sold
  13. Rowan : PM ganchan : no trigger board, but i can build one for you if needed !
  14. Hi there here are the winter's slaes, need to make some space ! All items can be shipped worldwide, but located in Canada. You are welcome at home for picking items, but you will have to drink a beer with me ! Price in USD. ----------------------------------------------------- LL113 Sequencer + PSU : 500$ Naked actually, all cards built, not tested the CV/Gates one, but midi working perfectly, others should work ! A case is designed actually, and will be avialable soon. Proposed design : All details + vids : The page : http://bricosique.blogspot.ca/p/blog-page.html Multi sequencer MIDI/CV 3 midi IN/OUT 8 CV 8 Gates Din sync 24 in/out Clock in Euclidian sequencer 8 cell, 16 patterns mode song Step by step Sequencer 32 or 64 steps, 16 pattern, mode song TR Style sequencer, 16 instruments + accent, 16 pattern, mode song Complexe ARP, 16 motifs, and mode song 2 internal LFO, and 2 ADSR (can be send to Cvs or Seq parameters Synth editor : Today : DSI Tetra, Marion MSR2, Roland JX8P, Mutable Shruthi 1, Solton Project 100, Siel DK700, Généric Midi CC Midi router, Midi -> CV, Midi -> Trig Groove swing ------------------------------------------------------------------------------------ transparent glass for screen lot : 10$ One special for Midibox MB-6582 Let get them guyz !
  15. the ucapps page say : ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- J5A/B Analog sources (like pots) can be connected to this port (8 pots maximum). If more analog pins should be scanned, please use the MBHP_AINSER64 module! There are also some application which use this pin as digital in- or output (mostly described in README.txt file). Alternatively J5 pins can also be used as digital input and/or output pins (MIOS32_BOARD_J5_*, see tutorial applications). And J5B.A6 (MIDI IN3) and J5B.A7 (MIDI OUT3) provide an alternative MIDI IO port as well if "#define MIOS32_UART_NUM 3" has been added to the mios32_config.h file (defines the number of UART ports). J11E This port provides four MIDI IOs at 3V level, interface to the MBHP_MIDI_IO breakout board. ------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- I thought that like on the LCP17? I could use the midi out 3 alternative on J5A/B ( BLM) No way to get a BLM working in this config ?
  16. Is that right ?
  17. Because of changing my LPC17 for a STM32F4, is my wiring correct ?
  18. Up 420$
  19. I have a little question about the TPD, i have mine waiting to be used, I want to build a 16x16 BLM, is it compatible with the TPD, (i mean could i connect a TPD, and a 16X16 BLM to a wilba SEQV4 Panel ? Because my SEQV4, TPB and BLM will be in separate boxes, i will have to connect them together. how it works ? I have a MIDI IICX4 which provide the BLM port. SEQ4 J2 to TPD J1 TPD J2 to ??? (i think on your config you use this one the connect to the BLM 16x4) In my case, i let it free, and use my ''normal BLM port ? No problem of too much scanned-at-a-time values ?
  20. A long time later... i am not able to find SMD led that can provide 2000mcd (that what the monome use, enough for exterior use) diffused led. It is not dead from my side, it is in a little part in my head...
  21. 2 other beer on the road :santa:
  22. Ok thanks TK, thought it was eating much current !
