florian
100 -
Everything posted by florian
Hello. I have bought some time ago those pcb, but wont build them. They are the pcb you need for a midibox seq 4 -seq4 controller board pcb -i/o midi board pcb -mbhp core stm32f4 pcb The 3 are quoted 52 +6.30 =58.30(postage to eu) dollars on modular addict. Please make me an offer in euro, postage included.basically i want to get ride of them so first reasonnable offer would have it. Ideal if you want to save some bucks. Pcb are untouched, pics by mail. Im am in france, europe, and dont think it worth it going outside eu for postage waitingfor your offer Flo
"I wish I had a tact with a longer actuator" solution
florian replied to Altitude's topic in Tips & Tricks
so if i understand well, you need those 5mm "spacers" to be able to use a panel with the encoder pcb monuted that's it?? By the way these new electronic site has really good price for sure for example the alps encoders are at 1,87e at reichelt and 1,20 at this one!!! -
looks very good!!! i assume this is the last pcb version, with the switch tl 1240??? from the bom i read: "The TL-1240 are short (8.2mm) so they cannot be used with encoders installed but are wired correctly for the LEDs. The Mec parts are tall and have a variety of caps but the LEDs are NOT wired to anything despite having pads and will need to be wired by hand. The 3 pin LEDs cannot be used with these switches. Only the 3F Mec parts are suitable, the 5F and others may fit the footprint, but use a different scheme for the LEDs that wont work at all with this board" What are these wonderful caps??? So you manually wire the led on the back of the pcb?? How did you do for the bi color leds , as it was stated not doable on the bom??? what's the problem with the encoders, i don't really understand???? many thanks for your tips and hints, i'm looking to make one, and this look wonderful!! bye
hello english spoken??? thanks
i'm in for it!! pm'ed
so let's go for the final list of things i need to run : my seq: -Maybe kingsbright leds if i go for them. -1 10 pin flat ribbon cable with -2 female idc connector 10 pin =>for connecting J1 on the frontpanel to j8/j9 on the lpc module (only conncation between the boards??? What is for the "SO" pin hole on j1 on the frontpanel?? you should not connect it...?? -2 16 pins flat ribbon -2 female idc connectors to =>To connect the screens to the lpc and the mounting hardware . Is that all???? thanks flo
was a lonely saturday evening..... But not really boring: But's it's far from end, and a usual i'm pissed off me, because i wsn't able to order all that i need in advance, and now blocked.... Will try to make a list here, hope someone wille help me to validate it, and will make the mios studio thing in the core now.... About the leds: TK: "If a suitable bicolour LED doesn't exist, I could add an option to the firmware which inverts the GP LED instead of activating a second colour." sorry, idon't understand that... What is "invert the GP" ?? semi lighted?? you can have a good result without dual colors leds without loss of funcctionality??? (sorry i don't read the manual for instance, just want to build it as soon as possible to play with it....) many thanks for explanations!!
ok thanks for your answer!! not sure if i will not just stick with the kits one... After all functionality is here... anyway i'm just soldering the lpc board now... the nxp board splittage was rude, hope it will work after that....
i had the chance to have a seq 4 kit from smash ( long wait, but can't be more happy). I usually ever use kingsbright flat top leds when i solder. I don't read for instance the manual ( will certainly not read it before some build), so i don't know what deserve the bicolor leds. My set is around a red light scheme so i hope to replace the kits leds, if not too complicated. I want to use kingbrights reds flat tops led instead of the green one. AND IWANT TO FOUND BICOLOR RED/BLUE . If the blue is not eye burner. Do you know if it exist??? any advice??? thanks!!
Hi all! I am starting a seq v4 build. I have the pcb and most of the part, and it seem a very simple and powerful build except that...... I cannot use my lcpxpresso 1769 : It's not recognised by my computer... And i can't flash anything with the pc... It discoouraged me to start the build.... My problem really seem the same than here: http://www.lpcware.com/content/forum/lpc1769-xpressomore-extra-long-cafe-latte I have very few free time, so i want to know if someone has a solution i would be amazed...... Or maybe if someone near france is open can i hope he flash the card for me,?? many thanks.. flo
hello at all! i am on the point to start a seq v4 build. Although i already ordered a ponoko case, i discover recently these swiths and switch caps: http://www.mutable-instruments.net/forum/discussion/4044/help-me-identify-these-switch-caps-please#Item_6 do you think i can use them as a bare replacement of the satndard switch on the wilba seq 4 pcb...??? thanks for your answer bye flo
i have put a switch on the fan, change nothing about the noise, surely come from psu??
Hi so no one as an advice on psu or fan connection??? etherway, i will put a switch on the fan..thanks!
so finally my two last questions are: -is the fan correcly connected or not (does it produce noise???) (see photo) -is the psu good to use with the altitude mode (does it produce noise???) (see photos) many thanks at all!!!
From the album: florian gallery
