This morning I soldered this bunch of 8 LCDs to 1 Core....totally awesome :)
The testapp is simple written in C within the "void DISPLAY_Init" section, but what I need is to check if they dont suck too many processor performance etc....
maybe I should write some coundtdown`s or something  for each display, but I dunno how to do this....stryyyyyd, I need you at the chat  ;D  ;D
The next days Ill try if I can connect 16 Displays to the Core, but 1st I wanna check if the 8 works stable...
brb.... :)
that is incredibly cool :) Its not a dig by any means...but are you actually going to use that many? or is this more a test to see how far you can push the core unit? wouldn't that chew up a whole bucketload of power?
Writing to any one of the LCDs doesn't take any longer than any other LCD... but if you have 4x as much screen and you writet to all of it, it'll take 4x as long.... (plus a little bit of overhead)
I think MTE noticed TK's hint in the function reference and is running with it... it's fun :)
Yes, for now I only want to test if its possible and working without big problems, but I see in future mega midirouters / monitors with a big bunch of LCDs to overview all parameters  etc without shortened names/values  :)
Ive connected them to my LC-Core and this is powered with an 23A PC-PSU ;)  ;D
Totally right, that I figured out the last hours, because when u need to communicate to the 3rd and above LCD u need to reinitialize every display  before you can write something to it.
Are you already using the new app_lcd/clcd_multi driver I gave doc? ;)
Yayyy thank you Thorsten :)
Hehe, no, I got a empty C-skeleton and started with coding....
void Init(void)
MIOS_LCD_YAddressSet(0x00, 0x40, 0x80, 0xc0);
  void DISPLAY_Init(void)
// LCDs-Initialisation
  MIOS_LCD_TypeSet(MIOS_LCD_TYPE_CLCD, 0x80 | 0x37, 0x80 | 0x25);
  MIOS_LCD_Init();
  MIOS_LCD_TypeSet(MIOS_LCD_TYPE_CLCD, 0x80 | 0x24, 0x80 | 0x23);
  MIOS_LCD_Init();
  MIOS_LCD_TypeSet(MIOS_LCD_TYPE_CLCD, 0x80 | 0x20, 0x80 | 0x21);
  MIOS_LCD_Init();
  MIOS_LCD_TypeSet(MIOS_LCD_TYPE_CLCD, 0x80 | 0x22, 0x80 | 0x34);
  MIOS_LCD_Init();
//Writing on LCD 1 & 2
  MIOS_LCD_CursorSet(0x00);
  MIOS_LCD_PrintCString("LCD 1 on   >RD7<");
  MIOS_LCD_CursorSet(0x80);
  MIOS_LCD_PrintCString("LCD 2 on   >RC5<");
//Writing on LCD 3 & 4
  MIOS_LCD_PrintCString("LCD 3 on   >RC4<");
  MIOS_LCD_PrintCString("LCD 4 on   >RC3<");
and so on......
::) maybe not the elegantest way to code, Im not a pro but willing to learn  ;D
Yeh, I have been trying to convince MTE to use the new structure... he's having a bit of an attack of "fear of the unknown" but I think we'll give it a shot this weekend and I'm sure he'll be pleasantly surprised by how much easier it is!
While I'm talking with MTE, we'll make an 8*LCD version of the driver, and he can learn how to upload to SVN too :)
hehehehe, Ive done many things the last hour, installed Tortoise and got access to the server, but 1 thing is totally nerving....when I want to connect to a folder I must write everytime my passphrase for 2 times  ??? >:(
...so I only connect in Read-mode for now via webbrowser...
Ok, than I putted all new files into my C-Skel...but when I try to compile I got only this error
error: missing definition for symbol "_USER_LCD_Select", required by "_output\main.o"
Follow my instructions on the wiki - install pageant and that will go away :)
Will be in the chat in about 30 seconds ;)
Uhm Ive totally overread that, sorry, it works now *happy :)
I like the direction in which this is going. Oh btw, whatever happened to mbTV? ;D
Who on earth picked that music, it has nothing to do with the dance... hmm.
Yeh gay music for a gay-dance...  ;D
Sorry for the following writing in german language, but its necessary for correct explanation...
Hallo Thorsten,
Stryd und ich haben jetzt 3 Tage mit dem neuen Treiber rumprobiert, aber stoßen immer wieder auf unerklärliche Bugs...
Pinbelegung der 8 LCDs :
E1=RD7  0x37
E2=RC5  0x25
E3=RC4  0x24
E4=RC3  0x23
E5=RC0  0x20
E6=RC1  0x21
E7=RC2  0x22
E8=RD4  0x34
OK, zuallererst hat Stryd LCD 4 bis 7 (von 0 gezählt natürlich ;) ) in den Treiber adaptiert, dann schrieb er eine kleine Applikation die wie folgt ablaufen soll :
Poweron -> Hello World x - Messages auf allen Displays -> dann ein langsames scrollen einer Zeichenfolge, daß von LCD 0 startend durch alle LCDs wandert......
Soweit sogut, die Initialmessages (Hello Wolrd x) funktionieren und werden auf allen Displays korrekt dargestellt, die Scrollroutine beginnt und läuft durch LCD 0-4, bleibt dann aber an LCD 5 hängen...LCD 6 wird komplett ignoriert (sprich das Initial-Hello World ist wie eingefroren) und an LCD 7 läuft die Routine weiter durch und beginnt wieder ab LCD0.
Das seltsame nun daran ist, daß sich dieser Ablauf  nach mehrmaligen Powerons/offs immer wieder and den letzten 3 LCDs geändert hat, sprich manchmal durchlief es auch gar nicht mehr die letzten 3 LCDs, manchmal lief es auch perfekt durch alle....
Gut, was wir dann zuerst vermuteten ist, das es ein meiner LC-PSU liegt (meine erste Testumgebung war die LC mit dem PC-Netzteil), gut ich switche heute das ganze mal auf den Traktorizer (PSU mit Entrauschung, anderes Core), aber da waren die Bugs genau dieselben...
Natürlich habe ich auch die letzten 3 Displays getauscht (hab ja 16 Stück hier rumliegen :) ) und die Verkabelung mehr wie 10mal gecheckt, ich kann also auf jedenfall mal einen Hardwarefehler ausschliessen und vermute, das der Bug eher am Treiber (definierung der Enable-Pins etc) oder der Applikation liegt, oder auch an beiden...
Auf jedenfall sind wir mal mit unserem Latein am Ende und bitten Dich, doch kurz mal einen Blick die Applikation (Attachment) zu werfen.
Grüße
MTE & Stryd
app_8clcds.zip
app_8clcds.zip
LCDs should never be concurrently handled by the main task (DISPLAY_Init/Tick) and an ISR (Timer())
In fact, I would never control the LCD from an ISR, because if a LCD is busy for more than 640 uS, this could result into MIDI data loss at the input side.
Heh yeh I wouldn't do this in a real app for sure :D
However I thought it'd be safe to increment the counter in a timer so long as it was atomic?
hehe.
Are four displays not enough?
That's what happens if you get a small finger... :D
greets
Doc
small finger? Must be a German joke... actually, I probably don't "get it" because I'm stupid :D
So can someone tell me why this is bad:
void Timer(void) __wparam
count_l++;
void DISPLAY_Tick(void) __wparam
if (count_l>=animspeed) {
count_l = 0;
++count_h;
if (count_h) {
	count_h = 0;
	MIOS_LCD_CursorSet(0x00+animhere); //1st line
	MIOS_LCD_PrintCString("X");
....etc
I must be missing something cause that looks OK to me?
IRQ handling seems to be ok, so I would propose to swap the enable pins in order to check, if it is really a SW issue. If the same LCDs are failing to work, you know where you don't need to search for errors before doing speculations into the wrong direction.
Heh, this is where it starts to get more complex... When we swapped the wires to the enable pins, the problem followed the enable line, which hinted that the problem was there... But it also caused other LCDs to start to fail, which made me think that maybe those LCDs are a bit 'funny':
E2 : LCD2
E6 : LCD6
LCD6 does not animate, and sometimes LCD5, but sometimes they all work OK. The behaviour does not change while the box is on, only after it has been power cycled (turned off and then on again)
E2 : LCD6
E6 : LCD2
LCD2 does not animate, and neither do LCD7 or LCD1. Again, this behaviour is constant, until the box is power cycled, and then sometimes they will work and sometimes they will not...
I should also mention that there were some interesting bugs noticed with these screens with the inbuilt MIOS CLCD driver, like if we send a certain string, it caused LCD 0 2 and 4 to fail thereafter. Sending a different string in it's place, everything was OK.
