Benjamin Posted June 11, 2008 Report Share Posted June 11, 2008 As a beginner, should i try to build a LC ?Or should i stick to a 64?I want to control ableton.Motorfaders would be sweet. :D Quote Link to comment Share on other sites More sharing options...
cimo Posted June 11, 2008 Report Share Posted June 11, 2008 Dear BenjaminWe can t decide for you!Usually people build their own MIDI controller cause they want to have their own design.The best advice i can give you is:build a CORE with a DIN and a DOUT, hook up some buttons and leds, then load MB64, MB64E, MBLC, maybe a C skeleton and make your own app, pretty soon you ll figure out what suites best your needsSimone Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 11, 2008 Author Report Share Posted June 11, 2008 build a CORE with a DIN and a DOUT, hook up some buttons and leds, then load MB64, MB64E, MBLC, maybe a C skeleton and make your own app, pretty soon Thanks, I did not know things could be this changeable. Quote Link to comment Share on other sites More sharing options...
nILS Posted June 11, 2008 Report Share Posted June 11, 2008 ...I did not know...That only leaves you with one option: Go read! Now. Go do it ;D Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 11, 2008 Author Report Share Posted June 11, 2008 Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 11, 2008 Author Report Share Posted June 11, 2008 ok i think i just found one Quote Link to comment Share on other sites More sharing options...
nILS Posted June 11, 2008 Report Share Posted June 11, 2008 Yes, as a beginner you can make a midibox that has pots, motorfaders, encoders, LCDs, LEDs, joysticks, logic control, etc. You just need to be willing to read, learn, try, fail, read, learn, try again and spend lots of time and cash - being a little crazy helps. Everything will be just fine. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted June 12, 2008 Report Share Posted June 12, 2008 LOL! Quote Link to comment Share on other sites More sharing options...
doc Posted June 12, 2008 Report Share Posted June 12, 2008 being a little crazy helps.No, it doesn't help ...... it's a MUST !!GreetsDoc Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 12, 2008 Author Report Share Posted June 12, 2008 i just found the thread i had overlooked http://www.midibox.org/forum/index.php/topic,3650.0.htmlfrom seppoman"Build the core module and connect the LCD - after some soldering practice this should be possible in max. one week of your schedule. So after some weeks you can get the first feelings of success and start exploring what is possible and what is needed. This is the real fun SmileyJust try not to think about too many things at once and everything will clear up with time. Perhaps Thorsten should put a "don´t panic" sign on the home page like on the cover of Hitchhiker´s Guide to the Galaxy Wink" Quote Link to comment Share on other sites More sharing options...
Foona Posted June 14, 2008 Report Share Posted June 14, 2008 Hello Bejamin!Did you read everything here: Ucapps?There is soo much information available, and many times stuff just keeps bluring up.Personally i miss vital information all the time.Either way, if you check through this page, you'll see how modular the Mb64 is.example 1 microexample 2 megaKnowledge is power, and as stated above..being crazy is a must! 8) Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 16, 2008 Author Report Share Posted June 16, 2008 example 2 megaSo lets say i want to add a bunch of faders or even more leds or some joysticks or a toaster oven to this config? Is that where i get into adding another core? Quote Link to comment Share on other sites More sharing options...
Sasha Posted June 16, 2008 Report Share Posted June 16, 2008 It`s not just core. And you cannot add a bunch of faders in LC. You can have just 8. You are missing some basic knowledge about MBHP, so it is better start reading or people will simply start ignoring these kind of questions. Quote Link to comment Share on other sites More sharing options...
Benjamin Posted June 16, 2008 Author Report Share Posted June 16, 2008 Ok no more questions Quote Link to comment Share on other sites More sharing options...
nILS Posted June 16, 2008 Report Share Posted June 16, 2008 Ok no more questionsHehe, that's not the point - you are more than welcome to ask questions, just try to find the answer yourself before you post ;) Quote Link to comment Share on other sites More sharing options...
