Hi
I build a MD FM since last year... I just reopened my boxes, uploaded FM 1.1 and started it (still in construction)
i got a 2x40 LCD with Backlight from Hantronix named "HDM 402 16L"
and here is what he shows me after booting :
? do i need a special driver for this one ? I can't remember where i bought it.
I use Mios 1.9C
Thanks
No, you don't need a special driver.
according to the datasheet it uses the Hitachi controller.
I would be quick to jump to a wiring error as a conclusion. In each of the characters shown on screen in the photo, the d2 line is set high, and the d7 is set low. See table below.
[tt]
Character              In binary
$                      00100100
W                      01010111
G                      01000111
|                      01111100
?                    01111111
.                      00101110
w                      01110111
n                      01101110
E                      01000101
4                      00110100
N                      01001110
l                      01101100
g                      01100111
7                      00110111
6                      00110110
5                      00110101
This bit is always '1'      ^
This bit is always '0'  ^
[/tt]
Heh, I saw that too, but then I realised - the cursor has been set correctly, so I wasn't so sure...
Edit: Maybe the RS line is shorted to those two pins?
Yes, I can also see through time.
Also, I'm trying to learn Deutch.
And recently enrolled in an OU course on Calculus / Linear Algebra.
Ok. I'm a nerd.
I hope you mean "Deutsch". If so, you'll have to try harder!  ;D
greets
Doc
Buß.
(In case you missed it, that's the new spelling - we have found the answer to the neverending argument about "buss" vs "bus"!)
so vix, any word on this?
did you load mios v1.9f?
did you triple check for wiring errors?
also, tell your lcd I said: "ack d'ack b'dack dack m'ack ack d'dack dack"
that'll fix it.
so... i updated to 1.9f and after rebooting the lcd shows me several martians screens then stop on this one :
nice isn't it ?
i checked my solderings one morrrre time.. nothing (it's simple because at this step i have only the core, the obpl3 and one DIN4 with nothing connected to it, and the LCD)
by the way these are readymade midibox.org boards
so this is for sure lcd wiring, thanks tilted !
but as this lcd have not "in line" pins, i'm a little confused with the numbers :
there are 2 vertical columns of 8 pins :
the up-right one is #16
and the down-left one is #1
but what is the down-right pin ? #2 or #8 ???
i think i wired it thinking it was #2
i've seen on the data sheet that i was right, the down-right pin is #2 (seen from the back, oposite to the datasheet drawing)
so now... i'm resoldering all the lcd wiring....
i'll tell you what happened soon :P
so i made a new wiring for the lcd, paying attention very carefully to pin numbers
and the result  is exactly the same !!
i checked with a small 2x16 testing lcd i made, the MBFM works, the display is ok
i noticed i got a short on the J15 of core module between pin V0 (named VL on the lcd datasheet) and pin Vss
is it normal ?
thanks guys
ok it works now !!!  ;D
i guess it was my connector, one D# pin was not connected...
thanks for your support guys !
i didn't use your table to find the pin (more simple to do a continuity test)
but of course it helped !
thanks for your accuracy, i hope u'll see my future troubleshooting posts  ;D
Mwhahahaaa ! i love this movie ! but i didn't catch the first joke  :P
i just hope my MBFM won't do the same sounds....
Man! If it does, let me know! I think a MBFM that speaks Martian is totally wikiWorthy!
