vix Posted June 12, 2008 Posted June 12, 2008 HiI build a MD FM since last year... I just reopened my boxes, uploaded FM 1.1 and started it (still in construction)i got a 2x40 LCD with Backlight from Hantronix named "HDM 402 16L"and here is what he shows me after booting :? do i need a special driver for this one ? I can't remember where i bought it.I use Mios 1.9CThanks
/tilted/ Posted June 13, 2008 Posted June 13, 2008 ? do i need a special driver for this one ? I can't remember where i bought it.No, you don't need a special driver.according to the datasheet it uses the Hitachi controller.I would be quick to jump to a wiring error as a conclusion. In each of the characters shown on screen in the photo, the d2 line is set high, and the d7 is set low. See table below.[tt]Character In binary$ 00100100W 01010111G 01000111| 01111100? 01111111. 00101110w 01110111n 01101110E 010001014 00110100N 01001110l 01101100g 011001117 001101116 001101105 00110101This bit is always '1' ^This bit is always '0' ^[/tt]
stryd_one Posted June 13, 2008 Posted June 13, 2008 Heh, I saw that too, but then I realised - the cursor has been set correctly, so I wasn't so sure...Edit: Maybe the RS line is shorted to those two pins?
/tilted/ Posted June 13, 2008 Posted June 13, 2008 Yes, I can also see through time.Also, I'm trying to learn Deutch.And recently enrolled in an OU course on Calculus / Linear Algebra.Ok. I'm a nerd.
doc Posted June 13, 2008 Posted June 13, 2008 Also, I'm trying to learn Deutch.I hope you mean "Deutsch". If so, you'll have to try harder! ;DgreetsDoc
stryd_one Posted June 14, 2008 Posted June 14, 2008 Buß.(In case you missed it, that's the new spelling - we have found the answer to the neverending argument about "buss" vs "bus"!)
/tilted/ Posted June 16, 2008 Posted June 16, 2008 so vix, any word on this?did you load mios v1.9f?did you triple check for wiring errors?also, tell your lcd I said: "ack d'ack b'dack dack m'ack ack d'dack dack"that'll fix it.
vix Posted June 18, 2008 Author Posted June 18, 2008 so... i updated to 1.9f and after rebooting the lcd shows me several martians screens then stop on this one :nice isn't it ?i checked my solderings one morrrre time.. nothing (it's simple because at this step i have only the core, the obpl3 and one DIN4 with nothing connected to it, and the LCD)by the way these are readymade midibox.org boardsso this is for sure lcd wiring, thanks tilted !but as this lcd have not "in line" pins, i'm a little confused with the numbers :there are 2 vertical columns of 8 pins :the up-right one is #16and the down-left one is #1but what is the down-right pin ? #2 or #8 ???i think i wired it thinking it was #2
vix Posted June 18, 2008 Author Posted June 18, 2008 i've seen on the data sheet that i was right, the down-right pin is #2 (seen from the back, oposite to the datasheet drawing)so now... i'm resoldering all the lcd wiring....i'll tell you what happened soon :P
vix Posted June 18, 2008 Author Posted June 18, 2008 so i made a new wiring for the lcd, paying attention very carefully to pin numbersand the result is exactly the same !!i checked with a small 2x16 testing lcd i made, the MBFM works, the display is oki noticed i got a short on the J15 of core module between pin V0 (named VL on the lcd datasheet) and pin Vssis it normal ?thanks guys
vix Posted June 18, 2008 Author Posted June 18, 2008 ok it works now !!! ;Di guess it was my connector, one D# pin was not connected...thanks for your support guys !
vix Posted June 19, 2008 Author Posted June 19, 2008 i didn't use your table to find the pin (more simple to do a continuity test)but of course it helped ! thanks for your accuracy, i hope u'll see my future troubleshooting posts ;D
/tilted/ Posted June 21, 2008 Posted June 21, 2008 Did you pass my message on?Did it help?i didn't use your table to find the pin (more simple to do a continuity test)Actually vix, I meant my other message...http://www.youtube.com/watch?v=6cid85WBkvcGlad to hear it's working... ;D
vix Posted June 21, 2008 Author Posted June 21, 2008 Mwhahahaaa ! i love this movie ! but i didn't catch the first joke :Pi just hope my MBFM won't do the same sounds....
/tilted/ Posted June 21, 2008 Posted June 21, 2008 Mwhahahaaa ! i love this movie ! but i didn't catch the first joke :Pi just hope my MBFM won't do the same sounds....Man! If it does, let me know! I think a MBFM that speaks Martian is totally wikiWorthy!
nILS Posted June 21, 2008 Posted June 21, 2008 If Martians speak in white noise, then my mbFM kinda speaks martian at times.
