  • Replies 59
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
hey phil: i have a couple questions and comments about connecting this and your schematic:
did you limit the current from the 5v b+/b- source?  your schematic shows a resistor to the cathode but it doesn't say a value.
your connections to anode and cathode from b+/b- are backward.  also should be 9x1uF capacitors, and i believe they can be polarized because the pins of the lcd are labeled p and n.  i'm sure non-polarized are ok but harder to find in that capacitance (is this correct?).
does it count backward with the data lines?  you connect your first to d7 and i'm assuming it goes backward from there to other lcds?  in my pcb schematic i've connected like this:
D7 --> lcd1
D6 --> lcd2
D5 --> lcd3
D4 --> lcd4
D5 --> lcd5
i've also adapted this to the pinning of the core32's lcd header instead of the regular core.  i'm not sure if the pinout is the same (doesn't matter i guess), but are any of the actual connections different?
thanks!
ultra
Hi Ultra.
Yes I limited the current to the backlight as per the datasheet, 56R IIRC.
I always screw up anode/cathode connections on circuits (bit of a mental block I think) yes you are quite correct!
The datasheet doesn't mention P/NP caps but the datasheet example uses NP and luckilly I had a never finished talkback project that used lots of 1uF NP so I stole them :) You may be able to use polarized but it could be a bit tricky working out which way round to put them. Maybe worth checking with TK to see what he used?
Yes you are quire correct about the data line assignments. I moved away from the conventional D0=lcd1, D1=lcd2 because I am using an 18F4685 and D0-D3 are not available so I thought that I would start at D7 instead!
AFAIK, the pinout for the CORE32 LCD is different to the CORE8 to make it more 1-1 for standard CLCD's so you may need to change it a bit...
Cheers
Phil
Hi Jack!!!
Yes, I check this: there are no 2x40 DOG LCDs available, but large displays which are properly aligned to the 16 GP encoders and buttons are essential for the ergonomic user interface.
Hi Thorsten,
I know.
Which distance have the encoder to each other?
Is there enough room to fit 6 displays (3 Encoders per display)?
Can you send me your Eagle schematic (mbhp_lcd7_dog.pdf)?
I want to use it for my Eagle library.
Best Regards
Jack
Yes I thought about this as well.
If you put 3 x DOG CLCD's together, the viewable would be approx 165x15mm. For this you will get  a 48x3 display. The viewable area is fairly close to a 40x2 size CLCD viewable area (152.5x16.5) I don't know how big the slots on Wilba's panel are but it could possibly be made to work.
I'm not sure how workable it would be and whether 48x3 is a usable size. The current SPI based DOG CLCD driver (that I have just committed) would support up to 8 of them so 6 could replace the 2 off 40x2 displays....
Cheers
Phil
So, you really want to overwork all seq_ui* files for a derivative which is probably only used by yourself, because it's more expensive (and slower) than really required?
Hi Jack.
That would give you a pretty big display, about 150x6 with the standard font :-)
The 'actual' window size is about 34mm, 48.26 is the external dimension but still pretty big!
Not sure if it would fit though and as TK said you would have to redo all of the UI...
Phil
  • 1 year later...
Posted (edited)
what are the references of the DOG Lcd and the DOG touchscreen @ mouser ? (the pink one of TK)
are there drivers (uc1610 ?) for :
http://fr.mouser.com/ProductDetail/ELECTRONIC-ASSEMBLY/EA-TOUCH160-1/?qs=XoD1gVtqLQvx3SsJpN7Png%3d%3d
and
http://fr.mouser.com/ProductDetail/ELECTRONIC-ASSEMBLY/EA-DOGXL160S-7/?qs=sGAEpiMZZMt7dcPGmvnkBoVrwDsRKMrKHVulqwLaEg8%3d
Best regards
Edited by julienvoirin
  • 7 months later...
I have just received negative doglcd with red backlight with help from kokipsiho.
I like it, but not entirely satisfied with it`s contrast. \
May somebody tell me how exactly can I change the contrast in driver. I see these lines, but not sure how to increase/decrease it.
movlw 0x50 ; Booster off, set contrast C5/C4
movlw 0x7c ; set contrast C3/C2/C1
Am I looking in right place?
I`m having hard times compile MB808 application to use dog driver. Can somebody please explain this in details. I tried to follow steps from Readme file.
"Assembler-Only" Applications
  1) main.asm (or main.inc): ensure, that the application includes
     the global <app_lcd.inc> instead of "app_lcd.inc"
Where do I set it and how? I don`t see anything like that in .asm files of MB808
  2) Makefile: include app_lcd.mk
# include application specific driver
include $(MIOS_PATH)/modules/app_lcd/clcd/app_lcd.mk
I believe my makefile should look like this:
MIOS_PATH = .
MIOS_BIN_PATH = ./bin
export MIOS_PATH
export MIOS_BIN_PATH
include Makefile.orig
# include application specific LCD driver (dummy driver by default)
# include application specific driver for DOG LCDs
include $(MIOS_PATH)/modules/app_lcd/dog/app_lcd.mk
  3) main.asm (or main.inc): call MIOS_LCD_TypeSet from USER_Init hook:
	;; select LCD type #7
	;; (custom LCD driver, hooks in $MIOS_PATH/modules/app_lcd/dog/app_lcd.asm module will be used)
	;; Parameter #1 and #2 select the enable pins like for common CLCD driver
	;; Note that the DOG driver switches to CLCD (type #0) after initialisation!
	;; Up to 2 DOG based LCDs are supported
	;; E input of first LCD at D.7, E of second LCD @C.4
	movlw	0x37		; E pin
	movwf	MIOS_PARAMETER1
	movlw	0x24		; E2 pin
	movwf	MIOS_PARAMETER2
	movlw	0x07
Where exactly should I put this code? I have tried various locations in the .asm file, but than I`m receiving error when compiling. I Have also tried to put it in the main.inc but receiving error again.
Posted (edited)
Sasha
I am not very confident with MIOS compile using SVN but i know that the LCD can be set using command line in Terminal OSX as i tried it several months before
I did a post in Programmers lounge several months ago, regarding to MIOS32
it is export function
Posted (edited)
Julien, the link is not OK, and search engine don`t give me any results. Can you please check it again?
EDIT: It must be because Programmers Lounge is not public forum.
I have tried this LCD with dog test application and it worked fine, after that I change just makefile to use dog driver.
After compiling, uploading and rebooting it seams LCD is working fine, but after powering down, it fails to initialize. When I upload the same MB808 code, it don`t initialize until I upload test app first, and than MB808. Again, it work until powering it down.
Edited by Sasha
Guest
Reply to this topic...
