joewhat Posted April 16, 2009 Posted April 16, 2009 Hi there im new around here.. ! :D I have bin looking at this MB project for a few years and now final started on a MBSIDv2 minimum stereo setup. i have some trouble with the optimized PSU.. i will try to explain my self.. im kinda new to electronics but i find it very exciting and i like to read and learn.. i hope some of you can help me out here.. as im a little lost.. :-[I think this might be a problem with the components I chose to build this circuit.. here is my part list: KBP208 bridge instead of the B40C800L78S09CV instead of the 7809 voltage regulator2x 2200uF 50v instead of the 2200uf/25v and 16vu1K63 instead of the 100nfu33K63 instead of the 330nfthen im using the original power switch from an C64-IIthe power plug connector and the psu from this C64-IIMy trouble is that this not working .. :///Im kinda noobish in all this but i've made some multimetering and this is my resultso... i've checked the circuit many times for any shorts or mis-wire-ring but this does not seem to be the problem.. so my mind is on wrong components..well any thoughts and guides to were i go from here is very welcome... and i hope this makes any sens at all.. let me know.. - Joe
Narwhal Posted April 16, 2009 Posted April 16, 2009 It looks to me like your components selections are good. I'm guessing the L78S09CV is bad, or something around there.Where is the vertical wire in the schematic that goes from the right of the base of the 7809 (pin 2) down to the 5V section? I don't see a wire for that in the picture of your board.Kurt
joewhat Posted April 16, 2009 Author Posted April 16, 2009 thank you very much kurt.. you have great eyes for spotting that one.. and it seems to work.. (the vertical wire was missing. !!)and then not really.. i now get around only 5vDC from the 3pin of the voltage regulator.. can this be a crazy chose of component? - and then im still confused about the low AC voltage in the circuit before it hits the voltage regulator..? is it normal that this old PSU is acting random voltage on the 9vAC output?and thanks for a quick reply.. next time i will go over the circuit even :0( thanks, - Joe
Narwhal Posted April 16, 2009 Posted April 16, 2009 In your top red box, you should be measuring __DC__ voltage, not AC. The diodes there inside the bridge are what changes the AC to DC.What kind of DC voltage do you measure there?
Narwhal Posted April 16, 2009 Posted April 16, 2009 I'm also curious what DC voltage you measure across the regulators pin 2 and pin 3.
nILS Posted April 16, 2009 Posted April 16, 2009 Just for the record and future reference:2x 2200uF 50v instead of the 2200uf/25v and 16vThe voltage rating is a maximum rating, which means that using higher voltage ratings is safe and a good thing to do.u1K63 instead of the 100nfu1 == µ1 == 0µ1 == 0.1µ == 100n, the "factor" (nano, micro, ...) is often used instead of a decimal separator.u33K63 instead of the 330nfSee above.About the 78S09. IIRC the S means it can handle 2A as opposed to the 7809 which can handle 1A.
joewhat Posted April 16, 2009 Author Posted April 16, 2009 thank you Nils.. this is very helpfull. !this might be my bridge that is broken or wrong-wired.. the vDC on the bridge -/+ output gives me 0.56vDC just under one volt.?= thats not good... (this i with the strange random right now at 5vAC input on the two ~~) and across pin 2 and 3 on the regulator then gives me the 0.0vDCstrangely enough my bridge outputs about 5vAC... here is how i have wired it. ?¯¯¯¯¯¯¯¯¯¯¯|| KBP208 || + AC - || | ¯//¯//¯¯¯\\¯\\ <- the two outer legs is output right? * * * * * * <- 9vAC output connected here from the C64-II psu
Narwhal Posted April 16, 2009 Posted April 16, 2009 You have it correct, but the datasheet for that part can always help clarify things like this for you.http://www.datasheetcatalog.org/datasheet/eic/KBP206.pdfI would disconnect any wires from the + and - on the bridge before declaring it dead. Sometimes other failures can make strange things happen there. But I can't see any reason why you would ever measure any significant amount of AC on the output of the bridge. Measuring the DC voltage across the + and - pins of the bridge when it has no other connections made to those pins should help you confirm whether it is malfunctioning or not.I'm not too familiar with the inner wiring of the DIN socket that you are connecting power to, but make sure that you are connected to the correct pins there for sure.
zgba Posted April 17, 2009 Posted April 17, 2009 Try to measure the voltages at your C64's PSU plug. These things are quite old and some of them are faulty. Measure the voltages on the PSU's power plug. It should be +5VDC on pins 3 and 4 (counting clockwise) and ~10-11VAC on pins 1 and 7.
joewhat Posted April 17, 2009 Author Posted April 17, 2009 yeah thats a good idea, i that from the start aswell. the multimeter gives 8-9vAC on the pin 1 and 7... and then i get the 5vDC on the 3 and 4 pin.i switch to checking every thing now before i mount it... so i basicly started all over..(i guess it was abit naive to solder every thing up and hope for the best)i have a fine connection thru the switch and then i connect it to the bridge. 8-9vAC connected to the bridge i get 1.59vDC out the bridge(i tried the bridge i pulled off my circuit and a brand new one and its the same 1.59vDC on both).is the 8-9vAC too low for my psu?and whats up with my bridge? am i getting the right result in DC voltage output?- joe
zgba Posted April 17, 2009 Posted April 17, 2009 Measuring voltages on unloaded PSU is one thing, on loaded - another. Try to connect another PSU (wallwart or whatever you have with similar voltage) to your circuit and measure the voltages after the bridge and avter voltage regulator. Good luck!
joewhat Posted April 17, 2009 Author Posted April 17, 2009 ok thanks alot zgba, this cleared out a few things.. i fund one power supply at with the output specs like this: 9vAC ~ 1.1A 9.9VAwhat is that [9.9VA]? - but any how.. i measure the output to be 11.1vAC and i connected it to the bridge witch gave me 9.74vDC output.so i guess my c64 psu is crap.. if i were to make a it work just for now, could i then go for a two psu connected? one being the old c64 psu for the 5vDC and the other new one for the 9vAC? - and then build the same circuit?thanks again for your help.. !- joe
joewhat Posted April 17, 2009 Author Posted April 17, 2009 thanks again... i guess it makes no difference where the power comes from.. - joe
zgba Posted April 17, 2009 Posted April 17, 2009 Using 2 PSUs is rather inconvenient. You can do it temporarily, but you should avoid it in your final design. But don't worry you have number of solutions: you can buy another C64 PSU on eBay or something like that really dirt cheap and re-use it without modifications or you can use this 9V PSU you have for +9V and +5V, but then you have to design another PSU and use some heatsinks for 7805 regulator. There are appropriate schematics somewhere in the forum, in the midibox FM section I think.
joewhat Posted April 21, 2009 Author Posted April 21, 2009 Hi there again.. im a little confused here.. i look at the datasheet for my L78S09CV voltage regulator, and how the 1,2,3 pins is set and it looks like pin 3 is ground and on the optimized psu circuit pin 3 is the 14vDC output? can any one help me about how to connect my voltage regulator? im way to noobish to make the decision that i should move away from what the circuit tells me or what so ever.. :0) here is the datasheet ive bin looking at http://www.datasheetcatalog.org/datasheet/SGSThomsonMicroelectronics/mXwqxq.pdf-joe
frailn Posted April 21, 2009 Posted April 21, 2009 See attached. This is how I understand it to work.vreg.JPGvreg.JPG
joewhat Posted April 21, 2009 Author Posted April 21, 2009 yes that is what makes the most sense to me aswell .. but i guess im afraid every thing will blow up if i try it wrong .. ugh !! but i read in the data sheet .. "making it essentially indestructible" wow.. ! can anyone confirm, hint, say anything?
frailn Posted April 21, 2009 Posted April 21, 2009 No worries. I had to build this thing three times before I got it right. But, it's good experience!
stryd_one Posted April 22, 2009 Posted April 22, 2009 I agree with frailn... The confusion here, is because the pins are numbered differently - but they are physically in the same location :)
joewhat Posted April 22, 2009 Author Posted April 22, 2009 now i agree with both of you.. today it finally work out for me.. !! and very many thank you for your answers to my questions.:!! this is an awesome project.. and i learn alot .! thanks again.. \o/? waiiyy..
frailn Posted April 22, 2009 Posted April 22, 2009 Glad to be of help! For a change, it's nice to be able to offer assistance instead of just asking for it!
joewhat Posted April 22, 2009 Author Posted April 22, 2009 :0) im glad.: ! i hope to help some one my self one day . .!
DJ Trago Posted April 27, 2009 Posted April 27, 2009 hi there im also having some PSU issues, so i thought id tag on to the end of this.basically iv built a stereo SID set-up with the optimised PSU but im not getting the right voltages at all. i think i all stems from the PSU as im not getting the 14VDC output, im instead getting 12.2VDC. the components i have used are the exact recommendation (7805, 2200uf25v, 2200uf16v ect...) but iv used a DC W005M rectifier as i was told this was fine.my SID boards are set up for the old 6581s and im running a 4 x 20 backlit display, the voltages for my ICs are too low though my SIDs are getting a low 7.5VDC and the other IC on the SID board are showing 5.2VDC and on the CORE my PIC appears to be getting nothing and neither does the other small IC.i have acquired 2 C64 PSUs (one black no vents and one grey no vents) and they appear to be inputting the correct voltagesany ideas would be very helpful!cheers, Alex
frailn Posted April 27, 2009 Posted April 27, 2009 i have acquired 2 C64 PSUs (one black no vents and one grey no vents) and they appear to be inputting the correct voltagesI went round and round and round with the optimized PSU and it turned out my C64 PSU's were to blame. At first, I thought I was getting the right voltages out of my PSU, but apparently not. I didn't discover this until I bought a panel-mount DIN female plug, plugged in my C64 PSU(s) and then tested the voltages, touching my meter probes to the back part of the DIN female plug, rather than the male plug of the C64 PSU. Only then did I get accurate readings.Just a thought based on my experience. If this isn't the problem, you might have a short somewhere on the Optimized PSU build.
