syamajala Posted September 18, 2009 Posted September 18, 2009 i'm not getting a mios upload request from my core. I checked all the voltages on the core according to ucapps and everything seems to be fine. I also know this pic works on a different core board the last time i tried it, but when i moved it to this new core it didn't work. I haven't tried it on the old again. Also, the midi jacks i'm using seem to have a separate ground that goes around the entire case, should i connect them? i only connected the 5 connections shown in the diagram.
nILS Posted September 18, 2009 Posted September 18, 2009 1) Check again if the PIC still works in the other core2) Disconnect all other potentially connected modules from the non-working core, to limit the number of possible errors.3) Make sure your MIDI routing in MIOS Studio is correct (loop back test via 1 cable)4) Follow the instructions here: http://ucapps.de/howto_debug_midi.html Especially the "MIDI Out*" tests5) Check the wiring of the MIDI jacks6) Show pics of your MIDI jacks
syamajala Posted September 22, 2009 Author Posted September 22, 2009 i am using the midi jacks smashtv sells. Not the ones that go on the pcb, but these http://avishowtech.com/mbhp/images/MIDIJackPanelL.jpg in that picture on the far right, am i supposed to wire that to ground as well?also, by rear view in this picture http://ucapps.de/howtodebug/mbhp_core_extract_midi_plugs.gif does it mean the rear view of the jack so i am looking at the pins on the jack or do i look at the end the midi cable would plug in to. because if its the former, i may have the polarities reversed.
nILS Posted September 22, 2009 Posted September 22, 2009 Answer 1) - 5) as well ;) Since you're using external sockets, I guess checking the wiring will solve the problem. Yes, on the MIDI out socket you'd have ground connected, see: http://ucapps.de/mbhp/mbhp_core_v3.pdf
syamajala Posted September 22, 2009 Author Posted September 22, 2009 I connected the old core and put the new pic in and it works. So, I guess i'll try connecting the jacks to ground as well. I also tried the led thing on the trouble shooting page, and the led flickers when i turn the power on, but doesn't seem to do anything after that. It will only flicker again when i turn the power off. I also tried the loop back thing in mios studio by connecting the out to the in and that seemed to work as well, so i don't think there is anything wrong with the routing in mios studio. i guess i'll try playing with the wiring of the jacks.
syamajala Posted September 22, 2009 Author Posted September 22, 2009 also, i wasn't talking about the wiring of the pins specifically, if you look closely at the picture on the far right http://avishowtech.com/mbhp/images/MIDIJackPanelL.jpg there is a pin with a copper rivet. that goes to the enclosure of the jack. Am i supposed to connect that to ground?
Janis1279 Posted September 22, 2009 Posted September 22, 2009 You have the old working Core. checking the wiring to the external socket pins 4 and 5 of the both Cores will solve the problem.Answer about ground connection you will find there, too.http://www.geocities.com/JDPetkov/documents/pcref/midiport.gif
syamajala Posted September 22, 2009 Author Posted September 22, 2009 the old core uses the midi jacks that go directly on the pcb though.
Janis1279 Posted September 23, 2009 Posted September 23, 2009 the old core uses the midi jacks that go directly on the pcb though. Fine. With the multimeter and with a jack holes diameter compatible sized piece of wire , you can easy measured all pin connections.
syamajala Posted September 25, 2009 Author Posted September 25, 2009 woot woot! My FM finally works! I used a continuity checker and compared the pins on the working core with the nonworking ones and figured out i had the polarities reversed on the jacks. Now, I need to work on the CS.
