Testing a MIDIbox SID v2.0 + Analog MS-20 Filter Clone
resistor
MIDIbox SID v2.0 + MS-20 Filter Clone /// TEST @ MCL Records
Hello! my name is Fernando Dallavalle and i'm from Argentina.
This is a little test of the MIDIbox SID synthesizer v2.0. (V2.0_rc35).
The MIDIbox SID synth output has a MS-20 Filter Clone connected.
MIDIbox SID v2.0 + MS-20 Filter Clone - PART I
MIDIbox SID v2.0 + MS-20 Filter Clone - PART II
Thanks to:
Augusto de Cesare
Mariano Bonadio
Thorsten Klose
MIDIbox project http://ucapps.de
MCL Records http://mclrecords.com
+info http://shivatek.com.ar
Best regards!
Nice, did you design the pcb for the MS-20 filter yourself?
Yes i made the design in argentina :)
Main features:
. Multimode Filter LP / BP / HP.
. 2 inputs for CV control.
. Input for Keytracking (pitch).
. Input for Expression pedal.
. Line Input.
. Line Output.
. Cutoff and resonance control.
. True Bypass Switch.
. Bypass Led.
. Vumeter Led (Moog MF-101 style).
. Power ON Led
. Internal Trimpot for exp pedal calibration.
. Internal Trimpot for cutoff calibration.
. Internal Trimpot for resonance calibration.
. Input Buffer.
Shivatek:
http://www.shivatek.com.ar
http://www.vimeo.com/resistor
Edited by resistor
  • 1 year later...
I am thinking about building a MS-20 and would be very grateful of any pcb layouts for sending of to be made or if there is a way i could do myself.
I have a few friends who are much more knowledgeable than me to help out, i'm the musician they are the brains!!
thanks in advance.
regards
Spence.
