mazatta Posted March 24, 2010 Posted March 24, 2010 I am looking at building a psu based off of NorthernLightX's schematic, but I am having difficulty tracking down an appropriate toroid transformer that will run on 110v and not break the bank. The only thing I could find so far that comes close to the 220v RKT 5012 used in the schematic and costs the least isthis one from DigiKey (amps seem too high though?) I have found manufacturers that specialize in these types of transformers, but they are at least twice the price of the one linked to above. Ebay doesn't seem to turn up anything useful either. The reason that I am building a psu, rather than repurposing something else (e.g. Amiga 500 psu), is that I want to build a MBFM and I don't want to use something that's 20+ years old. Has anyone in North America had success sourcing a transformer and/or building this psu? I appreciate any and all feedback! -Colin
strophlex Posted March 24, 2010 Posted March 24, 2010 I will build this for my FM too. Found these @ mouser. 553-VPT24-1040 - 25VA 553-VPT24-2080 - 50VA The instructions say 50VA, but I think 25VA should be enough. Not sure though. Anyway, these transformers can be used with either 115V or 230V outlets.
nILS Posted March 24, 2010 Posted March 24, 2010 50VA means >2A per rail. That's a lot. That's way too much for an mbFM. You won't need more than a few mA per rail as the only thing the +-12V supply is driving is a bunch of TL074. So to be on the safe side and have more than enough reserves let's say 300mA so a 300mA * 12V * 2 = 7.2VA toroid will do.
strophlex Posted March 24, 2010 Posted March 24, 2010 50VA means >2A per rail. That's a lot. That's way too much for an mbFM. You won't need more than a few mA per rail as the only thing the +-12V supply is driving is a bunch of TL074. So to be on the safe side and have more than enough reserves let's say 300mA so a 300mA * 12V * 2 = 7.2VA toroid will do. But if you want to use the transformer for 5V too according to http://www.midibox.org/dokuwiki/doku.php?id=northernlightx ? I plan to use this schematic for my MB6582 (allong with AOUT_NG and SSM2044s) too, how much juice do you think is necessary for that?
nILS Posted March 24, 2010 Posted March 24, 2010 Look at the schems of the modules, get out the datasheets, check for max current draw of the active components, sum them all up, add a good bit for good measure, get back to us with the results :)
strophlex Posted March 24, 2010 Posted March 24, 2010 (edited) Look at the schems of the modules, get out the datasheets, check for max current draw of the active components, sum them all up, add a good bit for good measure, get back to us with the results :) Sounds like a good exercise. Edit: Had a quick look and including SIDs, PICs, LCD, LEDs and shift regs. I sum up the max to allmost 30 W. The specs of the C64 PSU seems to be 40W. Most of the current is off course drawn by the 5V rail, so it might make sence to use a separate transformer for the 5V rail... Edited March 24, 2010 by strophlex
strophlex Posted March 24, 2010 Posted March 24, 2010 (edited) mazatta: Sorry for hijacking the thread. I still propose the 25VA transformer if you are going to use it for all voltages, -12, +12 and +5V. It is more than you need like Nils says, but unless you are short on space I don't see a problem. Nils: I messured the current draw of the 5V rail of my MB6582 when it was idle. I was exactly 1A. I guess 2A should be more than enough for any situation. 10VA that is. Edited March 24, 2010 by strophlex
strophlex Posted March 25, 2010 Posted March 25, 2010 Does anybody have any comments to or experience of the NorthenLightFX PSU design? Is the voltage devider resistor a good way to limit the voltage over the 5V regulator or is there some diode based solutions that are more efficient?
Kyo Posted March 31, 2010 Posted March 31, 2010 Hi, I am also looking for a replacement for the C64 PSU. I have been enjoying my brand new mb6582 for a month and then the PSU died in a white smoke final breath... I would not normally look into building my own as I do not know anything about PSU design but I can't find a linear +9/+5V that would suit. I am now considering building NorthenLightFX PSU for a replacement. I am wondering if I can jump to building straightaway or if I should get math & electrical knowledge before I start. Any thought ? Also is it possible to customize the design just by deleting and copying/pasting power lines behind the bridge rectifier ? In order to get 2 x 9V and 2 x 5V from the secondaries. That would make a single PSU with two blocks of 2x5V, 2x9V outputs, each block supplying 2A. This seems too easy, so I guess the answer is no. :)
strophlex Posted April 1, 2010 Posted April 1, 2010 (edited) Hi, I am also looking for a replacement for the C64 PSU. I have been enjoying my brand new mb6582 for a month and then the PSU died in a white smoke final breath... I would not normally look into building my own as I do not know anything about PSU design but I can't find a linear +9/+5V that would suit. I am now considering building NorthenLightFX PSU for a replacement. I am wondering if I can jump to building straightaway or if I should get math & electrical knowledge before I start. Any thought ? Also is it possible to customize the design just by deleting and copying/pasting power lines behind the bridge rectifier ? In order to get 2 x 9V and 2 x 5V from the secondaries. That would make a single PSU with two blocks of 2x5V, 2x9V outputs, each block supplying 2A. This seems too easy, so I guess the answer is no. :) If I understand you right, I'd say it's not that easy. But still you can stick with standard values as long as voltage rating of caps and current rating of transformers and regulators are high enough. To make a PSU with several different output voltages you'd normally have a transformere with several taps or several transformers because if you feed a regulator a voltage far above the output allot of heat will be produced. The NorthenLigthsFX PSU remedy this with the voltage dividing resistors (the high power ones) so that only part of the voltage is applisd to the regulator. If you didn't see these before: http://www.avishowtech.com/mbhp/ps/ http://www.midibox.org/dokuwiki/doku.php?id=bipolar_12v_psu Edited April 1, 2010 by strophlex
Kyo Posted April 1, 2010 Posted April 1, 2010 Thanks four your reply, I had a double winding (see pic (no those are not butts ...)) transformer in mind when writing the previous post. I plan to use a R-core transformer. So it would have 2 bridge rectifiers.
strophlex Posted April 1, 2010 Posted April 1, 2010 Thanks four your reply, I had a double winding (see pic (no those are not butts ...)) transformer in mind when writing the previous post. I plan to use a R-core transformer. So it would have 2 bridge rectifiers. What voltage ratings? 2x6V? Then you could use the one tap for regulated 5v and both for regulated 9v. However, you will need a 6(V)*2(taps)*2(A) = 24 VA transformer. I the beginning of this thread I mentioned a 25VA transformer at mouser. That could be something.
Kyo Posted April 1, 2010 Posted April 1, 2010 What voltage ratings? 2x6V? Then you could use the one tap for regulated 5v and both for regulated 9v. However, you will need a 6(V)*2(taps)*2(A) = 24 VA transformer. I the beginning of this thread I mentioned a 25VA transformer at mouser. That could be something. I was thinking of 12(V)*2(taps)*2(A) = 50 VA (as of the original NorthenLightFX proposal) in order to get 2(taps)*(2*+5VDC, 2*+9VDC) from the secondaries. I am not planning on using every output at once. Just to have mb6582 on one tap and 2*SEQ v4 on the other. The idea is to design the psu to be reusable. Am I on the right track or did I miss it completly ? :)
strophlex Posted April 1, 2010 Posted April 1, 2010 I was thinking of 12(V)*2(taps)*2(A) = 50 VA (as of the original NorthenLightFX proposal) in order to get 2(taps)*(2*+5VDC, 2*+9VDC) from the secondaries. I am not planning on using every output at once. Just to have mb6582 on one tap and 2*SEQ v4 on the other. The idea is to design the psu to be reusable. Am I on the right track or did I miss it completly ? :) I think you are on the right track. I am not an expert either.
Kyo Posted April 19, 2010 Posted April 19, 2010 (edited) Here is a first draft of what I have in mind. Edited April 19, 2010 by Kyo
