scagnato Posted May 17, 2010 Report Posted May 17, 2010 hi everybody I have a question: for the pull-up resistors in "DIN module" can I use 1/8watt resistors? Thanks Attilio
TK. Posted May 17, 2010 Report Posted May 17, 2010 P = U*U/R = 5V*5V/10000 Ohm = 0.0025W So, you could even use 1/400 watt resistors :) Best Regards, Thorsten.
Antix Posted May 18, 2010 Report Posted May 18, 2010 Hi, I used 1/8W resistor on CORE and SID too without any problem Regards Antix
nILS Posted May 19, 2010 Report Posted May 19, 2010 You'll have troubles finding resistors that won't work :flowers: If you like wearing tinfoil hats and are scared of your own shadow you might wanna use those to be on the safe side: :whistle:
SLP Posted May 19, 2010 Report Posted May 19, 2010 (edited) You're calling that a resistor? THAT's what I call a resistor! Edited May 19, 2010 by SLP
