Hi
Has anyone come across LCD's larger than 40x2, like 60x2 or 80x2 ?
I was looking at the logic control at my work and it looks like the LCD is approx 60x2 (I couldn't be bothered counting the characters).
Does anyone know what the limit MISO can handle is (I should read the MBHP LCD section, no doubt that holds the answer)
The reason I ask is just a matter of aesthetics. One LCD per 8 faders would be nice.
Rowan
yes it's a 55x2.. can't find it anywhere!
By the way I think it's not a HD44780 based, because those chip handle 40 chararcter line...
And yes it's a little stupid design problem...!!!!!
Firstly, Rowan, MISO is a soup. I tried it with LCD's once but it was too crunchy ;) heheheh
I read that you can get 40x4, but I've never seen anything larger than 40 rows... As Pilo said, I think that's a limitation of the chipset...
I wonder if there would be a practical way to run dual LCD's side-by-side?
So long as the LCD is HD44780 compatible, up to 64x2 should be possible. However, I never found a distributor for displays larger than 40x2
I got a 24x8 (!!!!!!!) display recently. It seems to be compatible, but there are still some things I gotta check out. (Up to now I`m even not sure if its working!).
Holding th line...  :)
