Davo Posted September 13, 2010 Posted September 13, 2010 I seem to recall someone being able to make windows for protecting LCD windows. Who was that? Are windows still available?
philetaylor Posted September 13, 2010 Posted September 13, 2010 That was julianf. He made windows for Wilba's MB Seq front panel but he only made enough for the customers that bought panels IIRC. Cheers Phil
Altitude Posted September 14, 2010 Posted September 14, 2010 (edited) someone should just lay a ponoko one out, those would be dirt cheap and they have 2mm clear material. Personally, I just get some lexan film from mcmaster and sandwich between the panel and the LCD. They have thickness down to 0.005" , it's tough stuff, and cheap. And if you are REALLY concerned about your display, it comes in .44 magnum rated bulletproof as well :thumbsup: Edited September 14, 2010 by Altitude
Antix Posted September 14, 2010 Posted September 14, 2010 Hi, Probably , as say Altitude , the cheapest solution is the plexyglass you can buy in hardware store. If you have time with a dremel like tool you can engrave the edges to create a step to be embedded. Regards Antix
Davo Posted September 17, 2010 Author Posted September 17, 2010 I think Ponoko is the route I'll take. All you Dremel-users ought to check out the Proxxon line of rotary tools. I've come to the conclusion that Dremel is okay as long as you don't want to use attachments.
