kris Posted December 31, 2010 Report Posted December 31, 2010 hello there ive managed to cure the random signals on my new midi-box64 but now ive got a problem with some of the din inputs. half are working and half are not, the 4 chips on the first board work and the 4 chips on the second board dont. ive swapped chips from one board to the other all the chips work. ive checked connections and wires from buttons to board all okay ive checked connection from first din to the second din board, its okay ive checked theres a voltage to the second board 4.99v now ive run out of ideas so any creative input would be appreciated regards kris
TK. Posted December 31, 2010 Report Posted December 31, 2010 Hi Kris, I would propose to test the SC and RC connections between the first and second DINX4 module with the SRIO interconnection test (-> http://www.ucapps.de/mios_download.html ) (see README.txt for further instructions) The SI connection between the first and second board can only be checked with a multimeter, e.g. with a beeper function: remove the last chip of the first DINX4 module, and the first chip of the second DINX4 module, thereafter "beep" the connection between the SER input of IC4 (first DINX4 module) and the QH output of IC1 (second DINX4 module). If this still doesn't help to locate the error, it would be interesting if the second module is working when it's connected directly to the MBHP_CORE module (-> swap first and second DINX4 module) Best Regards, Thorsten.
ssp Posted December 31, 2010 Report Posted December 31, 2010 i bet more than likely you have it linked wrong, its the most common mistake to make. to stop this happening i only put one row of header pins on my dinx boards. if you look at the dinx4 board from the top (presuming you have got a smashtv board) you only put the headers on the leftmost outer holes, and the same on the j2 headers also here is one of my dinx4 boards, the first headers on J1 are only on the leftmost holes and on J2 the inner (left) holes also. try this, hope it helps.
kris Posted December 31, 2010 Author Report Posted December 31, 2010 (edited) thanks very much ssp thats exactly what i had done so now thats done yippee, but i have one button that is not working. ive tested the connection to the din board okay ive checked the ground connection okay ive replaced with another button no difference i swapped two chips around on the board no difference again any ideas appreciated regards kris Edited December 31, 2010 by kris
ssp Posted December 31, 2010 Report Posted December 31, 2010 easiest way to rule out the button is get a fine pair of tweezers or a pice of wire and touch one ned to the pin that it uses and the other to gnd, see if the lcd shows a 0 to 127 jump, if so its the button. so say your using pin 4 for this button and then its going to to gnd, then all you do is put one end of the tweezer on pin header 4 and the other to gnd (same if using a wire) and if your lcd shos a jump from 0 to 127 then its the button. one other thing make sure you have the wires going to the right terminals on the button!!
kris Posted December 31, 2010 Author Report Posted December 31, 2010 thanks for the idea unfortunately ive already replaced the button with one i tested with no change to the situation regards kris
JRock Posted December 31, 2010 Report Posted December 31, 2010 If the replacement button does the ame, and the chip swap didn't change anything then it's a connectivity issue,
kris Posted January 1, 2011 Author Report Posted January 1, 2011 (edited) youd think so but ive checked the connectivity quite a number of times now, including running a different wire from the button to the board no change in the situation. The only thing i can think of now is if one of the resistors is faulty ( could this produce this fault??) unfortunately i dont have a replacement to try at the moment as usual any ideas of where to go from here appreciated regards kris Edited January 1, 2011 by kris
Janis1279 Posted January 1, 2011 Report Posted January 1, 2011 If this still doesn't help to locate the error, it would be interesting if the second module is working when it's connected directly to the MBHP_CORE module (-> swap first and second DINX4 module) Hi kris, Are you swaped first and second DINX4 module too? Regards, Janis
kris Posted January 6, 2011 Author Report Posted January 6, 2011 fortunately janis i didnt have to as this was suggested for the problem of the second board not working which was fixed with ssp's suggestion thanks tho still not found the solution for the one button not working, now the only thing i can think of is different dinx4 board but i dont have one to hand. so i think i just make it one of the outof the way buttons that doesnt work and live with it regards kris
