kogz23 Posted January 7, 2011 Report Posted January 7, 2011 Hi there, sorry, me again! So the SEQ4 is up and running with midi working fine. I am having problems trying to get the gates and cv working. I have 8 jacks coming out of the gates provided on the CORE board. There are also 8 cvs coming out of the AOUT NG which I have hocked up. I am not getting any voltage/triggers from either the gates or the cv's. I'm using the default MBSEQ_HW.V4 file. I think I must be missing some kind of configuration setting or something else pretty obvious. Any help greatly appreciated! Cheers Al Quote
grizz Posted January 7, 2011 Report Posted January 7, 2011 Hi there, sorry, me again! So the SEQ4 is up and running with midi working fine. I am having problems trying to get the gates and cv working. I have 8 jacks coming out of the gates provided on the CORE board. There are also 8 cvs coming out of the AOUT NG which I have hocked up. I am not getting any voltage/triggers from either the gates or the cv's. I'm using the default MBSEQ_HW.V4 file. I think I must be missing some kind of configuration setting or something else pretty obvious. Any help greatly appreciated! Cheers Al In the Track ---> "Event" page are you changing the port to AOUT? There is also a cv configuration page that allows you to choose the specific AOUT model you're using. And lastly, if you look in the AOUT port section in the manual you will find what the various Event and Channel configurations do... Hope that helps a bit. Quote
kogz23 Posted January 7, 2011 Author Report Posted January 7, 2011 I have changed it to AOUT in the event page. Where is the CV configeration page? I can't find it. As for the gates, I shouldn't have to change the config from the default, should I? Cheers Al Quote
nILS Posted January 7, 2011 Report Posted January 7, 2011 I have changed it to AOUT in the event page. Where is the CV configeration page? That's described here: http://ucapps.de/midibox_seq_manual_m.html Quote
kogz23 Posted January 12, 2011 Author Report Posted January 12, 2011 Hi, so I have gone into the cv config page and set it to AOUT NG. Still no luck. No gate or no CV. Now I'm starting to pull my hair (tho I don't have much !) out. My out port is set to AOUT. Midi was working fine, but can't get no damn analog!!! Any ideas? Cheers Al Quote
TK. Posted January 12, 2011 Report Posted January 12, 2011 Mokkinger will send me his AOUT_NG module for further analysis. It cannot be excluded that you've the same issue - please hold the line! ;) Best Regards, Thorsten. Quote
kogz23 Posted January 13, 2011 Author Report Posted January 13, 2011 Hi found the problem. I was did not have the ground at the +12/-12 connected. I did this because I thought if you were using a common ground with the seq4 it should not be connected to avoid a ground loop. I connected the ground and all is well. GREAT!!! One bit of confusion though, when C-3 is playing I get 5v, as the instructions ay it should be, but I am getting c-6 from my VCO...anyway, sorry if I wasted your time with my silly mistake! Cheers Al Quote
TK. Posted January 13, 2011 Report Posted January 13, 2011 Alright, we should add "ground connected?" to our default question. ;) MBSEQ counts octaves from -2, this complies to the Yamaha standard (I don't really like it, but there were too many unnecessary "bug" reports about the octave counting in the past) You are counting Octaves from 1, this makes the +3 difference Best Regards, Thorsten. Quote
